Real Colnago or Fake ????
Old 09-26-21, 09:05 PM
bikemike73
Quoted: 211 Post(s)
Liked 199 Times in 147 Posts
Just wondering if this Colnago is real or fake?
If real...what is the value.
Never seen a BB without the ace of clubs.
Decals do not look right.
Forgive me for the poor pics
Appreciate any and all help.
Thank you
bikemike73 is offline
Old 09-26-21, 10:20 PM
xiaoman1
xiaoman1's Avatar
Bikes: A few too many
Quoted: 1360 Post(s)
Liked 2,175 Times in 1,180 Posts
Hard to tell from the poor pictures but the lug work as well as the stamps on the rear drops are suspicious looking to me. JMHO, Ben
Voltaire
xiaoman1 is offline
Old 09-26-21, 11:20 PM
3alarmer
Friendship is Magic
3alarmer's Avatar
Bikes: old ones
Quoted: 26374 Post(s)
Liked 10,341 Times in 7,185 Posts
...if you're thinking about buying it, you probably want to get better pictures or an in person inspection. I've only seen one or two of them, but the lugs on the ones I've seen were filed to thin them.
3alarmer is offline
Old 09-26-21, 11:27 PM
Vitma
Bikes: Emonda, 79/80 Colnago Super, early 80s Eddy Merckx, end 70/beginning 80s Somec Super Corsa, Santa Cruz Bronson
Quoted: 46 Post(s)
Liked 63 Times in 34 Posts
Could it be a late Colnago Superissimo or C96?
Vitma is offline
Old 09-27-21, 12:38 AM
CliffordK
CliffordK's Avatar
Quoted: 18347 Post(s)
Liked 4,496 Times in 3,343 Posts
The fork appears to be "genuine" Colnago, but also appears to have deep pitting. It is possible the fork is not original with the frame.
I don't see any issues with the logos. You're probably into the early to mid 1990's for a time period.
I think I have a mainstream Colnago from the mid 90's without a bottom bracket cutout. I'll have to check models, but under bottom bracket cable routing with a plastic guide is easiest to do without the cutout.
Obviously make sure you have some clover cutouts on the lugs, probably the top tube/downtube lugs at he head tube. Also it should have either a clover on the seat stay caps. Possibly a "Colnago" script on the caps. Also a clover on the rear brake bridge.
CliffordK is offline
Old 09-27-21, 01:29 AM
Mackers
Quoted: 194 Post(s)
Liked 177 Times in 140 Posts
C90, Columbus Thron Super.
Paint will blow off with the faintest of breezes
Mackers is offline
Old 09-27-21, 03:14 PM
lostarchitect
incazzare.
lostarchitect's Avatar
Bikes: See sig
Quoted: 40 Post(s)
Liked 55 Times in 38 Posts
Ultra terrible photos, but I have seen a lot of fake Colnagos, and never once have I seen one where someone went through the effort to carve "Colnago" into the dropouts. Based on that alone I'm 99.9% certain this is real.
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
lostarchitect is offline
Old 09-27-21, 08:47 PM
bikemike73
Quoted: 211 Post(s)
Thank you for all the responses.
Much appreciated
What would this be the worth ?
Old 09-27-21, 11:00 PM
3alarmer
Friendship is Magic
3alarmer's Avatar
Bikes: old ones
...I can't tell you a value without better pictures. I see some rust on the chrome fork, but it's easy enough to prime and paint that to match the frame, once you treat the corrosion. It's a common problem with chrome fork Colnago's I have encountered. If the rest of the paint is good, and it's not some dreadful mismatch of components, with that issue to drive down the value. I would think you're looking at $600-700. But without better photos, that's just a WAG.
The brand name is a positive, because it seems everyone wants a Colnago. I did too, until I got one and discovered it was a solid ride, but no more so than some other bicycles I've owned and ridden.
3alarmer is offline
Old 09-28-21, 07:32 AM
DMC707
DMC707's Avatar
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,123 Times in 746 Posts
Originally Posted by 3alarmer
. everyone wants a Colnago. I did too, until I got one and discovered it was a solid ride, but no more so than some other bicycles I've owned and ridden.
Yep - a collection of tubes joined together by a set of lugs . Just like any number of ITalian bicycles
A Colnago just allows you to yell "Ciao Bella !!" a few decibels higher when you see a lovely lady on the sidewalk as you pedal past
DMC707 is offline
Old 09-28-21, 01:45 PM
repechage
Quoted: 3462 Post(s)
Liked 2,825 Times in 1,994 Posts
Downmarket Campagnolo, rough condition, usually indicates surprises when you take things apart.
$650 then you can tell if Colnago is for you. Assuming it fits.
not the correct size? smile and wave.
repechage is offline
Old 09-28-21, 01:58 PM
CliffordK
CliffordK's Avatar
Originally Posted by repechage
Assuming it fits.
What is that? Maybe 55cm or 56cm?
So, good for around 5'8 or so to 5'11 or so, give or take a bit.
Old 09-28-21, 10:01 PM
zukahn1
zukahn1's Avatar
Quoted: 789 Post(s)
Liked 1,736 Times in 629 Posts
I would agree it has Colnago dropouts Colonogo seat stay markings under atone of iffy but nice looking paint and no doubt fork. So legit but not great may have been bent and rrebuilt. the pic of the rear would seem to indicate it's out of alignment could be the image or wheel/ set but looks a good 20-30m out of line to me. So you need to check this before you buy.
zukahn1 is offline
