Rims too tight -- sandpaper them down?
#126
OP gone?
The OP hasn't come back with a report on how the experiment went, has he?
Are we all assuming he was killed in the attempt?
Likes For tgot:
#127
That's the only reasonable assumption to make. Fortunately, the next time someone asks this question we will now have this thread to point them to so they can understand why it's a bad idea.
#128
Wrench User
Analogies
I have followed this thread since it started, but did not chime in because it seemed like the OP was asking for validation to do something ill-advised. I honestly hope the OP's fever broke moments before sandpaper/grinding wheel/lathe touched aluminum and they found some different tires or wheels. Whatever their fate, it seems the OP is gone and this thread becomes an informative and cautionary post to those who come after. To that end, anyone have any good analogies for this scenario?
I landed on it being akin to a skydiver intentionally fraying their parachute backpack straps because the pack was difficult to take off when on the ground.
Likes For bmalmquist:
#129
Quoted: 942 Post(s)
Liked 527 Times
The problem is the logic behind modifying a non wear/disposable item (rim) over a wear/disposable item (tire). Conte 5000's are known to be tight on many rims to begin with. With respect to the OP, there is one of two things going on.
1. The rim is out of spec - return it or exchange it. Chinese or not $400-$500 is still $400-$500.
2. The rim is in spec - Use the tricks to mounting tight tires (putting them in hot water, soap them up, mounting technique, etc...) or change tire brands if its more important to be able to remove and mount by hand on the side of the road.
Modifying the wheel is not a good idea for many of the reasons listed on this thread. What you need to be considering is why are Chinese rims cheaper? Are they the same quality (materials, workmanship)? If your answer is no then that's more reason not to modify them.
#130
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,992 Times
Likes For veganbikes:
Likes For oldbobcat:
#132
Duke Ulysses
Bikes: An old orange one for dirt, and for the other stuff: a white one, a kinda mint green one, and a black one.
Quoted: 165 Post(s)
Liked 175 Times
So, how did it go?
#133
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1944 Post(s)
Liked 1,468 Times
Likes For SoSmellyAir:
#134
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Likes For Rolla:
#135
how much does a 622mm 500g rim compress (change diameter) if average spoke tension is ~120kgf DS and ~70kgf NDS for 32 spokes?...
73GPa modulus in compression...
a rough estimation would be 0.7mm. maybe wheel was a sloppy build. they all add up. improper tire mounting technique, rim/tire combo (one or the other being non standard)... and spoke tension variance along with low average spoke tension.
oh wait... chinese carbon rims. i dunno the modulus for that, someone else knows perhaps?...
later edit: CF about 7 times stiffer (in compression) than aluminum (considering modulus and density differences).
then it's trick or treat.
#136
Quoted: 97 Post(s)
Liked 40 Times
The diameter/circumference of the outer edge of the rim does not determine the tightness when installing a tire. If the depth to the bottom of the inner part of the
rim is greater, then on the other side of the rim, the beads of the tire can be pulled down into the rim deeper making the rire easier to mount by giving more slack on the
side of the rim you are trying to push the beads over on.. Further, some rim designs differ in the distance between where the bead of the tire seats and the outer most
edge of the rim. Clearly some rim designs would be easier to mount than others even when the bead ridge measurements are the same dimensions.
Likes For preventec47:
#138
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Likes For Bimmer69:
#140
Quoted: 18375 Post(s)
Liked 4,510 Times
Ok, a little late here.
I'm not sure I'd be too excited about modifying a $1000 pair of rims. However, might as well make sure the wheels work for a person.
As far as accurately measuring one's progress. If the wheel was trued to start with, one could use a truing stand with a dial micrometer to monitor the hop.
I think one could get fairly close simply eyeballing it with respect to the bead hook. Or, grind a block to fit inside the rim to use to measure one's progress.
I'm not convinced taking say 0.5mm off from beyond the hook would make a rim with a fully inflated tire suddenly start blowing beads, assuming there is adequate material to not compromise the hook. If it does blow beads, then the tire is way too loose already.
#141
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
#142
Quoted: 236 Post(s)
Liked 171 Times
I have some new rims that are super tight with my preferred tires. I'm very experienced, and still broke two tire levers getting them on there (which I ultimately did). The tires aren't tight on any of my other wheels. I think it's the tubeless-ready idea biting me in the ass. Manufacturers are deliberately making them tight by adding a tiny amount to the circumference of the rim. But I'll *never* get those things on out on a ride! It doesn't matter what tricks there are in the shop to mount a tire if you're screwed from the get go on a ride in the middle of nowhere. I have to be able to get the thing mounted in seconds not hours.
My question: Has anybody ever sanded down the outside of the rim? Wet/dry sandpaper, 100 grit will take them right down, then 600 grit to smooth them. Aluminum is soft, WC wet/dry sandpaper is hard, this will work very quickly. People regularly sand out ding marks and such. But I've never heard of anybody sanding down a rim to improve tubeful tire fit in "tubeless-ready" rims.
Has anybody ever tried it?
Please do *not* reply to this thread with other advice for getting tires onto the rim, I'm asking a very specific question. I know *all* the tricks already thank you. This is maybe a new one.
Cheers,
Jon.
Cheers,
Jon.
#143
Duke Ulysses
Quoted: 165 Post(s)
Liked 175 Times
Im starting to get worried
#144
Go Ride!
Bikes: Klein Quantum Pro, Klein Attitude, Azuki SS, Merckx AXM, Klein Quantum Race, Klein Quantum
Quoted: 109 Post(s)
Liked 155 Times
Jon…your patience is admirable—you asked a question you knew was outlandish and kept your head when the ******** started to fly. Think about where that tire is bedding—that’s what’s too ‘big’— maybe compare that measure with the other rim? Best of luck!
#145
Liked 2,164 Times
In light of the actual measurement of a micron, yes I agree the OP can certainly remove a “few” of them from anywhere on a rim.
John
John
Likes For 70sSanO:
#148
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Likes For JohnDThompson:
#149
good cheap fun
OP thanks for posting instead of just doing it. Always enjoyable to read threads like these.
They're your wheels, do what you want.
Likes For trucklet:
#150
Quoted: 980 Post(s)
Liked 582 Times
Brake wear causing rim crack.
Using a straight-edge to assess rim wear.
