Water Fasting : the next day
#51
Quoted: 538 Post(s)
Liked 466 Times
The world has definitely been focused to the negative to a higher degree the last couple of years. I have to do my best to tune out of everything for a bit every day. Do what you can to make some time to unwind every day my friend. I wish you all the best.
Likes For RH Clark:
#52
Quoted: 538 Post(s)
Liked 466 Times
Media/entertainment avoids showing things that don't make money. "Invest money on the winners, not the losers". Bad news, sad stuff, the "reality" makes people indulge less in spending and that's not good for the economy. Once in the blue moon, they would promote "investing" on the less fortunate but only to avoid getting accused of being greedy and cold.
The big problem is not everyone can have at least middle class lifestyles. The planet simply don't have the resources for it. But the last thing this world needs, is further shift resources away from those in dire in need of it because of greed fueled by media / entertainment / internet "pollution".
I would not have known about the dire African situation have you not mentioned it and if I did not make a search. All the random stuff I get bombarded with are middle class and rich celebrity stuff. I never even click those links. They force feed this garbage on everyone.
Likes For RH Clark:
#53
hoppipola
Bikes: fausto coppi
Quoted: 512 Post(s)
Liked 227 Times
The problem with the experience you shared with us, you are very tired the next day.
I can't afford such depleted state because I still have a day job where I still needed to engage >120% of my few remaining brain cells. I'm simply unable to work my brain feeling fatigued or even feeling sick.
#54
hoppipola
Bikes: fausto coppi
Quoted: 512 Post(s)
Liked 227 Times
Thank you for the advice, but i have been unable to stay in zone 2 or even low 3. That would mean very long commute times that i can't afford.
#55
hoppipola
Bikes: fausto coppi
Quoted: 512 Post(s)
Liked 227 Times
Is it possible that the tiredness i experience the next day comes from the quantity of food that i eat at night, which prevents my body to enter autophagy during the sleep ?
If that's the case, maybe eating less (less carbohydrates at least) would fix the problem. There's also the possibility to eat in the middle of the day, and skipping dinner...
RH Clark You mentioned once hitting the wall after a 24 hours fast : can you relate what exactly happened that day ? maybe other factors made you hit the wall, because in my experience fasting actually prevents that from happening. That's the main reason i do it when i ride.
#56
Quoted: 538 Post(s)
Liked 466 Times
On this particular day however, I just pushed things way too far. I had fasted calories for close to 30 hours when I started that ride. Somewhere around 30 miles in, I knew I needed to eat. I was feeling strange in my head. I couldn't continue my ride. I actually had to lay down on a park bench for over 2 hours. I did get some food when I stopped and ate at that time, but I think I had depleted myself so much that it took 2 full hours before I could get back on the bike and get back to my vehicle. I was really unable to even stand for a while when it happened and would have likely sought professional help if it had been possible during those first 2 hours.
My guess is that you are in ketosis during your fasted rides. You fast enough that your cells are more adapted to burning fat than carbs. There are many studies that suggest humans may get a sort of supercharged burst during that state. It is hypnotized that it is a survival mechanism built in to provide the enhanced ability needed to hunt down wild game even after extended periods without food. I have personally noticed a "feeling" of heightened focus and energy many times around the 20-hour mark without calories. This only happened though after I had adapted to burn ketones. It took me months initially to become adapted where I didn't feel hungry or week without carbs every few hours.
#57
hoppipola
Bikes: fausto coppi
Quoted: 512 Post(s)
Liked 227 Times
I had worked very diligently for 2 years to lose weight. I had lost 180 lbs at that time and at 6'2 and fairly muscular, I only weighed 170 lbs. I was riding 100-150 miles a week riding some amount every day. I was trying to rid my belly of loose skin from going from a 48" waist to a 29" waist. To accomplish this, I had adopted a 22-2 intermittent fasting protocol. I would only eat any calories during that 2 hour window every day, usually around 2pm. I had been eating like this for nearly a year at the time and was quite adapted to it. Just like you mentioned, I always seemed to have incredible energy during my fast.
#58
Quoted: 538 Post(s)
Liked 466 Times
I was consuming around 30% of my calories as fat at the time. I had been quite a while without food though and had much smaller amounts of fat on my body. If I am not mistaken the body stores fuel in the muscles and liver even when totally adapted to burn fat. It is my understanding that you convert your own body fat into that fuel to be used immediately. I think I had simply burned through every last bit of that stored fuel and it took me 2 hours or rest and food to be able to get my levels back to normal.
#59
Quoted: 6193 Post(s)
Liked 4,808 Times
You either need to make time to go slower or you'll suffer under your current regimen.
Though typically when I am tired the next day that is usually when I can see that I didn't adequately hydrate. Though that happens when I'm doing a lot of other stuff outside in the heat and it's not as convenient to get water or fluids as it is when I'm on a bicycle.
Over time, if you continue to just use water, your energy conversion rate of fats might improve and let you achieve a faster pace without depleting all your glycogen stores. But from what I read, it's not something that happens overnight, might be over years of such training.
Even a very lean person at the lower limits of their BMI just before being anorexic have plenty of fat to draw from. Fat just doesn't convert to usable energy as fast as the limited glycogen stores do. But because they are limited, the body reserves them for when you are doing harder efforts.
#60
Quoted: 96 Post(s)
Liked 292 Times
Originally Posted by holytrousers;[url=tel:22619003
22619003]You are right RH Clark , but i'm not an occasional rider and i can ride the whole week when i don't fast.
That's one plausible explanation, so you think that my body continues to digest into the next day and that's what keeps my energy low?
Suggested reading:
