Wheel out of true only while being ridden?
Old 09-06-22, 08:44 AM
chuckybb
Quoted: 10 Post(s)
Liked 3 Times in 3 Posts
My young but 6'-1" tall ridding buddy asked if I could true up his front wheel (29" wheel w/2.6 inch wide mountain tires) on his Schwinn Axum mountain bike. We lifted the bike up and spun the wheel around. It seemed very true (maybe 1 or 2mm lateral) considering the rough treatment he has shown it..He said it was looked more out of true while he was riding it. I'm wondering if this sounds familiar to anyone?
chuckybb is offline
Old 09-06-22, 09:07 AM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 5149 Post(s)
Liked 2,694 Times in 1,595 Posts
Pull the rim strip and check for cracks between the spoke holes on the inside of the rim. Wide mountain bike tires can push outward on the rim and cause it to crack. The result is a rim that seems sound without load but can be out of true when the rider sits on it.
You might also check all of the spokes to ensure that you don’t have an overly loose one (or 2 or 10)
Stuart Black
cyccommute is offline
Likes For cyccommute:
pdlamb
Quoted: 2094 Post(s)
Liked 1,337 Times in 848 Posts
It's hard to see a 1-2 mm wobble as you're riding, especially as you're rolling on a mountain. You might look carefully at the tires; a bulge in a sidewall is very visible (and often ready to blow out).
pdlamb is offline
Old 09-06-22, 10:14 AM
ClydeClydeson
Quoted: 514 Post(s)
Liked 784 Times in 455 Posts
Possibly, as mentioned above, rider is just seeing a wobble in the tire. Tires are seldom perfect, and damage to the casing will cause major wobble - usually enough to 'feel' the wobble.
ClydeClydeson is offline
Old 09-06-22, 10:47 AM
Iride01
Plz hurry Dec 22!
Iride01's Avatar
Quoted: 4873 Post(s)
Liked 3,393 Times in 2,354 Posts
As others said cosmetic flaws in the tire will easily make you believe a wheel isn't true. Sometimes the tread strip doesn't get laid straight and in the proper line before they vulcanize it on or what ever they do nowadays. Sometimes incorrect seating of the tire bead will make it lean to one side more in some places.
But I'd suppose it's possible that if the tensions on the spokes are way wonky then that might be part of the issue too when weight is put on the bike. I use to true my own wheels, but eventually realized that I could have a perfectly true wheel and some spokes be loose and others too tight. Since I didn't have anything to measure the spoke tension and didn't want to have more tools laying around for occasional use, I decided to let a bike shop handle my wheels when I need such. And I found out they don't charge much to do a really good job on them. So more time for me to do other stuff.
Iride01 is offline
Old 09-06-22, 01:18 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Bikes: Stewart S&S coupled sport tourer, Stewart Sunday light, Stewart Commuting, Stewart Touring, Co Motion Tandem, Stewart 3-Spd, Stewart Track, Fuji Finest, Mongoose Tomac ATB, GT Bravado ATB, JCP Folder, Srewart 650B ATB
Quoted: 3634 Post(s)
Liked 2,578 Times in 1,617 Posts
I'll offer a reason why a wheel might be thought of as out of true when transferred to another bike that has nothing to do with spokes or tires. The hub bearing adjustment might have shifted during the transfer. Especially with a nutted axle the lock nuts and cones can spin on the axle and thus change the bearing adjustment. One might think that the rider would recognize the flopping about wheel as a bearing issue and not a rim or tire trueness issue. But after working in a LBS one will know better than to trust a lay person's description, that hasn't been confirmed by you. Andy (not trying to say this is what's going on. Just adding info to the thread)
AndrewRStewart
Andrew R Stewart is offline
Likes For Andrew R Stewart:
Old 09-06-22, 02:30 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 1546 Post(s)
Liked 844 Times in 609 Posts
With a 2.6" tire, I'm not sure if you can see the rim well enough when riding?
Give the spokes a "pluck" test. They should "twang", not "thunk".
Squeeze adjacent pairs together firmly and see if any pair gives unusual results compared to the other pairs.
Is the tire seated straight?
Bill Kapaun is offline
Old 09-10-22, 12:36 PM
oldbobcat
oldbobcat's Avatar
Bikes: '79 Gios, '80 Masi, '06 Felt, early '60s Frejus
Quoted: 297 Post(s)
Liked 241 Times in 184 Posts
Look at the hub.
oldbobcat is offline
