Tube shifted on rim causing blowout at stem
Bikes: 2017 Raleigh RetroGlide iE
Quoted: 58 Post(s)
Liked 23 Times
Hi. I have an issue which I believe was caused by the use of the rubber rim strips that I was using on top of the factory liner.
These strips may have caused my tubes to move excessively on the rim when I was riding, and the rear tube was damaged at the stem causing a blowout.
I see no other reason for the tube shifting this much. Do you?
Quoted: 1819 Post(s)
Liked 1,693 Times
What size tire? What air pressure were you running?
Sometimes tires can creep on the rim if run at too low a pressure when you brake for extended periods
Likes For alcjphil:
Quoted: 4201 Post(s)
Liked 3,857 Times
The number one cause of a tube moving about within the tire/rim is too little air pressure. As the wheel turns there's a force acting on the tire, trying to rotate it around the rim. The tire could do this with no issue but for the valve being trapped in place by being in the valve hole. The outward appearance is of the valve becoming tilted as it exits the valve hole. Inside the tube is being pulled away from the valve, stretching the tube, and on the other side of the valve the tube is being pushed against the valve. If allowed to continue long enough the tube can become stretched that the wall give out and/or the tube becomes bunch up on its self on the other side of that valve.
Another, less common, reason to have a base of valve blow out is from the valve not being fully seated against the rim and between the tire's two beads. The tube does its balloon thing and fills the gap, causing the tube wall to get thin right at the valve's base.
A third reason is the opposite happening. The tube is trapped under the tire bead. The bead can't fit down on the rim's bead seat and thetire isn't overlapping the rim fully. As the tire/tube is filled w/ air the bit of the tube trapped under the tire bead acts as a pneumatic jack and it lifts the tire up and further out of the rim. If allowed to continue this can cause a gap between the rim and the tire bead and the tube goes all balloon like and expands out this gap. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 2604 Post(s)
Liked 1,928 Times
Wouldn't #3 blow the tire off before it let the tube rotate on the rim?
Liked 3,857 Times
Tubeless- Not in my book. Simply inflating the tire to a working pressure solves this. No need to get messy or hard to mount stuff.
Agreed and this is why #3 didn't mention any tire creeping about the rim. Andy
AndrewRStewart
AndrewRStewart
Likes For Moe Zhoost:
Bikes: Schwinn, Nishiki, Santana, Trek, Rodriguez
Quoted: 189 Post(s)
Liked 106 Times
I have always added talc powder to the tube when installing. I thought this helped the tube shift into place and out from under the tire bead. Is powder still (or was it ever) considered to be useful in this regard? Alternatively, I suppose the talc could also be detrimental (thinking of this thread), facilitating tube slippage if the tire is somewhat under inflated.
Liked 3,857 Times
Now good tube install technique will go a long ways at reducing the possibility of tire blow off at the valve. Once the tire is fully mounted one pushes the valve stem up and into the rim. This helps insure the fat wall thickness at the valve base is above and between the tire beads and not down tight against the rim's bead seat shelf. A very simple few moments. As with any initial tube inflation a slow and periodic tire seating check will confirm all is well, tire seating wise. Andy
AndrewRStewart
AndrewRStewart
Half way there
Quoted: 986 Post(s)
Liked 880 Times
Quoted: 189 Post(s)
Liked 106 Times
Jobst Brandt's opinions rate high with me. See: https://sheldonbrown.com/brandt/talcum.html
Likes For IPassGas:
Quoted: 58 Post(s)
Liked 23 Times
Yet the person selling the tube claims it is compatible.
I once got stuck deep in the wilderness with a rear wheel in which the valve stem had been torn off. No repair possible. Cause was obviously the tire rotating relative to the rim. The rim strip has too little mass to have caused this.
On these types of rides (no cell service, and nothing but bears for miles around), I carried two spare tubes, a patch kit, and a bunch of tools. After suffering the same fate with both spare tubes, I had to walk 7 miles out. Turns out my pathetic mini-pump was only capable of generating 25 psi, even if I pumped with all my might. Should have known there was a reason that I found this pump on a trailhead a few months earlier.
Got a better pump, and have never had this problem since (20 years).
Liked 1,928 Times
Likes For pdlamb:
Quoted: 58 Post(s)
Liked 23 Times
So what would you'all say is the minimum and maximum amount of air that a 26" 65lb tire should be filled to?
Liked 3,857 Times
It all depends on the tire's fit to the rim. And this is why this type of question has no answer that is correct for all the possible tire/rim combos, the tens of thousands of the combos... This is why we write about the need to pay attention to what you are doing, visually checking the tire's seating as the pressure goes up. If a shop did less and the rider suffered a blow out we would all turn our gaze to the shop... So when the rider is doing the inflation the same standard should be followed. Or the uninformed will suffer. Andy
AndrewRStewart
AndrewRStewart
Quoted: 58 Post(s)
Liked 23 Times
So how the heck does one know when a tube is properly inflated?
Tubes shouldn't be this complicated!
Quoted: 58 Post(s)
Liked 23 Times
I just measured my rims, and found that they are unusually thin. They measure 14.2875mm (9/16).
The tubes are 31.75mm (1.25) when inflated. The fit between the tube and tire when on the rim is tight enough that the stem gets caught in the bead, abraiding against it, making it impossible for the tube to sit in the bead.
Furthermore, the edges of the rims stemhole is so rough that it easily cuts into the stem!
So it looks like I will need a new set of rims (I may go tubeless). Or perhaps this pairing can be converted to tubeless?
Half way there
Quoted: 986 Post(s)
Liked 880 Times
_o_t_
_o_t_
Quoted: 836 Post(s)
Liked 1,061 Times
If memory serves the hot ticket for mountain bikes years ago was to use very narrow rims and 2"+ tires of that era were designed to work on those rims. Just guessing but maybe newer tires have a different design and don't work so well with the narrow rims.
Mad bike riding scientist
Quoted: 6218 Post(s)
Liked 4,217 Times
I’ve run across tons of tires and tubes that can’t be separated. Granted they are almost always old tires but talc in the tires helps keep that from happening and makes pulling a tube out of a tire easier.
Stuart Black
Stuart Black
Liked 3,857 Times
I'll bet a virtual beer that the valves are Schreader, not Presta. One of the reasons why Presta valves are liked by many is that the stem is narrower, providing less interference with the tire beads when in narrow rims.
I also will suggest a thick walled "puncture resistant" tube is a poor choice when running a narrow rim just for the reasons you are finding. I assume (there's that word again) you have flat issues, true? Can you describe the flats? Poke throughs or pinches? Have you tried tires with casing plys of cut resistant materials (Kevlar as example)? IME PR tubes are partial solution with many drawbacks.
BTW the PR tube's inability to fit down in between the tire beads on this narrow a rim is exactly what I was referring to in my first post.
Back in the late 1980s really narrow ATB rims (in the 559 ISO) were the shiz. Campy made some that were around that 14mm internal width. The problem we sometimes saw with these was the tire's wanting to come unseated when running low pressures and doing aggressive maneuvers which had significant side forces. The angle the tire casing left the rim was so severe the bead wouldn't interlock with the rim's hook edge well. Andy
AndrewRStewart
AndrewRStewart
Quoted: 58 Post(s)
Liked 23 Times
Schrader valves. The tube failed when it shifted, damaging the base of the valve. My tires are CST Sensamo Controls (puncture resistant liner).
Liked 4,217 Times
50 psi in a 2” tire shouldn’t shift. If you had a slow leaker flat, you could drop pressure enough to get some tube creep which might cause your problem. Additionally if the valve stem weren’t at 90° to the rim when you pumped up the tire, that can stress the valve stem as well. It’s very common to cut an angled valve stem, even with proper inflation.
Stuart Black
Stuart Black
