Early Dura Ace Hub Questions
Old 09-18-22, 06:35 AM
Jicafold
Quoted: 286 Post(s)
Liked 85 Times in 63 Posts
Good morning. So I have this early model Dura Ace rear hub. I an unsure what model it is. Dura Ace painted lettering has worn off. Dust caps say "Dura Ace" Uniglide freehub has evenly spaced splines, I am told only an early Dura Ace casssette fits. So my questions are:
A. What model hub is ths?
B. What cassette fits it?
Thank you.
Jicafold is offline
Old 09-18-22, 06:52 AM
rccardr
aka: Dr. Cannondale
rccardr's Avatar
Bikes: Bob Jackson, Wizard, Pegoretti Duende, Merckx ProSLX, Pelizzoli, Cannondale ST, Schwinn Tempo, Schwinn Voyageur, Canyon Endurace, Richard Sachs, Davidson Discovery
Quoted: 1838 Post(s)
Liked 2,042 Times in 794 Posts
Check with Velobase for sure, but I would say DA 7200, which I believe came in both freewheel and freehub styles.
Any UG cog will fit that hub pattern but you’ll need a special ‘reduced internal diameter’ first cog to tighten everything down. They got as small as 12 teeth.
Cogs are out there, lots on eBay..
You can also slightly modify any HG cog with a file or Dremel tool to fit all but the first position, by widening the single narrow notch.
rccardr is offline
Likes For rccardr:
Old 09-18-22, 08:46 AM
Dean51
Dean51's Avatar
Bikes: '82 Ron Cooper, '84 Allez, '86 Tommasini Racing, '86? Klein Quantum, '87 Ciocc Designer 84, '95 Trek 5500, '98 Litespeed Classic, '98 S-Works Mtb
Quoted: 207 Post(s)
Liked 197 Times in 90 Posts
I have purchased 1st position cogs for these early DA hubs from Loose Screws. Brand new and good turn-around time on the order.
Dean
Roll Me Up and Smoke Me When I Die
Dean51 is offline
Likes For Dean51:
Old 09-18-22, 11:42 AM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 1546 Post(s)
Liked 843 Times in 608 Posts
Uni Glide.
Other than the screw on end cog, you can take HG cogs and widen the narrow spline to make them fit.
The flat cogs can also be flipped to "double" their life.
Apparently, Dura Ace screw on cogs have a different thread diameter than other Shimano screw on cogs. (flat cogs have same spline though)
I've never dealt with these, but maybe Andrew Stewart, FBinNY or others can fill in the details.
Bill Kapaun is offline
Old 09-18-22, 02:38 PM
Iride01
Plz hurry Dec 22!
Iride01's Avatar
Quoted: 4855 Post(s)
Liked 3,382 Times in 2,344 Posts
No FH-xxxx stamped in the hub between the two spoke flanges? Then we'd all know better what is being dealt with. I think it was usually 180 opposite of the Shimano Stamp. But it might have been a label or ink printing that wore off instead of being stamped into the aluminum.
Iride01 is offline
Old 09-19-22, 05:47 AM
Jicafold
Quoted: 286 Post(s)
It only says Shimano on the aluminum portion of the hub.
Jicafold is offline
Old 09-19-22, 06:07 AM
Hondo6
Bikes: Yes
Quoted: 225 Post(s)
Liked 207 Times in 150 Posts
I'm fairly sure that rcdardr is correct that it's from the Dura Ace EX 7200 family. However, Shimano documentation archives list 4 different FH-72XX hubs:
FH-7250: 5 speed, 120mm OLD
FH-7260: 6 speed, both 120 mm and 126mm OLD
FH-7261: 6-speed, 126mm OLD
FH-7271: 7-speed, 126mm OLD
The FH-7261 and FH-7271 had what Shimano termed "Direction System" hub flanges. Essentially, these appear to have been stepped flanges that allowed all spokes to be inserted from the inside of the flange without mutual interference when crossed. (Shimano claimed it improved wheel strength, but it didn't catch on and appears to have been discontinued.) The stepped flanges are shown in diagrams and/or pictures found in Shimano's documentation.
Your hub doesn't seem to have those stepped "Direction System" flanges, so it's likely either a FH-7250 or a FH-7260. Lack of those same stepped flanges also rules out it being a a Dura Ace AX FH-7360 or FH-7370-R that's missing its NDS aero dust cap, since both of those hubs also had the "Direction System" flanges.
Since the FH-7260 was made in both 120mm and 126mm OLD versions, you'll need to measure the length of the freehub to ascertain which it is. If I recall correctly, a Shimano 6 or 7 speed freehub should have a length of around 30-32mm. A 5-speed freehub would be significantly shorter, probably by at least 5 mm (not sure, never seen one and couldn't find any info on width of a 5-speed Shimano freehub).
Per the Shimano docs, the smallest available screw-on last cog was an 11T cog. I've read elsewhere that that allowing the use of an 11T smallest cog was the reason the Dura Ace used smaller internal diameter threading for the early Dura Ace freehubs.
To find the appropriate available Shimano docs, follow the link above. Or you can enter the model numbers above manually (e.g., "FH-7250") in the appropriate data field on the webpage linked above. (There's no separated exploded view for the FH-7261 and FH-7271; those exploded view diagrams - along with that for the corresponding front hub - are are found in one of the two SI docs that come up on the search.)
If it's a 5-speed, I'm thinking you've caught a unicorn. But you're not out of luck; according to the late Sheldon Brown's cassete/freewheel spacing cribsheet, 5-speed and 6-speed used the same cog spacing and width. So you should be able to use loose 6-speed Uniglide cogs and spacers on it to gear it as you like. Using modified 7-speed Hyperglide cogs for the largest 4 might (or might not) also be a possibility if you use 7-speed spacers and add a 1.5mm or 1.8mm spacer behind the largest (7-speed cogs and spacers were each a bit narrower than 5 or 6 speed cogs/spacers - if I've done the math right, using 7-speed cogs and spacers 4 cogs and 3 spacers would be 1.65mm narrower than their 6-speed counterparts). But you'll definitely need a threaded smallest cog in either case.
Hope this helps. Best of luck.
Hondo6 is offline
Old 09-19-22, 06:19 AM
Hondo6
Bikes: Yes
Quoted: 225 Post(s)
I'm pretty sure Shimano has done all three of those when it came to marking their hubs with model numbers. And I've seen at least one where the hub marking was on one of the dust caps - I've got a pair of old FH-HG20s with the model number stamped into the metal NDS dustcap.
Hondo6 is offline
Likes For Hondo6:
Old 09-25-22, 10:55 PM
Jicafold
Quoted: 286 Post(s)
Thank you so much. You are a weath of information that is appreciated.
Jicafold is offline
