Brooks saddle question
I've never had a leather saddle before but I picked up a Schwinn super sport today that had a Brooks professional saddle. Is this salvageable? I'd like to try riding with it. Seems sturdy enough and in spite of the cracks on the surface it doesn't seem to have any cracks that go all the way through it or anything.
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,201 Times
Don’t think if Proofide as being a softener nor should you apply anything that softens the leather. Proofide helps preserve the leather and acts as a little bit of waterproofing…but only a little. If you ride in the rain or leave the bike out in the rain, cover the saddle with a Brooks cover or a plastic bag. Try not to ride it if it is wet.
Stuart Black
Stuart Black
Likes For cyccommute:
I’ve got one that looked like that when I got it. I put a coat of Obenauf’s (you could use proofide)on it, top & bottom, and have been riding it for years. I can’t say that’ll be your experience, but I would definitely give it a go. Maybe take the first couple minutes on it gingerly just in case. Good luck.
A bit rough but It shouldn’t need much. Get some Proofide and smear it on the top and bottom. Let it sit for a while (overnight would be enough). Maybe apply some more and then ride. Apply Proofide about once a year.
Quoted: 2323 Post(s)
Liked 4,935 Times
Yep. I'm with the others. Treat to some Proofhide and then give 'er a go. I think it'll be fine.
Steel is real...and comfy.
Likes For jamesdak:
Phyllo-buster
Quoted: 2296 Post(s)
Liked 2,046 Times
Agree...that saddle has tons of miles left of it.
Likes For clubman:
Quoted: 4509 Post(s)
Liked 6,374 Times
@cyrano138
Pics of the bike man, pics of the bike!
Treat and ride the Brooks, it may out live you, keep in mind your backside has to break into the saddle and vice versa, many struggle to get there.
I always feel you will/should know fairly early on and keep in mind this is a Pro, thicker leather and tougher for some to get there with.
These can be very subjective and very minor adjustments can yield big results IME, both good and bad so you have to stick with it.
Tilt and height are not the same and I almost always end up with mine nose up even with drop bars.
Think of it like football being a game of inches.
@cyrano138
I got it as a possible upgrade for my 86 le tour. It looks to be a 58 which is about the biggest frame I can ride, so I'm going to fix it up and see which one I like better and then sell the other one. It's not perfect. It has some paint defects and some very light surface rust underneath in those spots but other than that it looks to be a good functional bike and I've heard good things about the super sports.
What originally caught my eye was the crank set which seems to be a 144 BCD sugino double, and I thought hey I can use this for one of my fix gears, which would be worth 80 bucks alone to me. But looking at the bike and seeing how nice it is I don't think I have the heart to part it out.
Yeah, I've always wanted to try a leather saddle so I'm pretty excited about it. So the bike is obviously not cleaned or has not had anything done to it in a long time. My understanding is that it sat in storage since the '80s. Seems to be all original stuff. I'm not sure about the brakes or the brake levers but pretty sure everything else is original.
Quoted: 603 Post(s)
Liked 1,062 Times
Very nice 84 Supersport, I’ve got a Pearl white one, same year, bought it new, lots of miles, great ride. Love the warm grey with green decals, would have picked that color scheme, but shop didn’t have it in my size. Enjoy!
Tim
1984 Schwinn Supersport
Tim
Likes For tkamd73:
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 582 Post(s)
Liked 697 Times
Not a real Brooks expert, but I have had a few. The professional is thick leather, so as others have said, it should last fine. On the other hand the thick leather on it makes it less compliant, and more likely to be uncomfortable. They are all different. I have 2 B17s, and one is fine and so far, one is not. I have a couple vintage B15s that are my favorites. Good luck with nice bike and saddle.
verktyg
Quoted: 1036 Post(s)
Liked 1,237 Times
Old Brooks Pro Saddle
cyrano138 As merziac said... Sometime a slight adjustment of as little as 1/8" of an inch (3mm) in saddle height and or 1° in the angle can make a big difference for me... but then I suffer from the Eddy Merckx Syndrome:
Eddy adjusting his saddle on the go... (I don't do this but if I haven't been riding for a while I may stop several times and make minor adjustments)
What I look or feel for is a balance in the pressure between my pelvic bones, my feet and my hands. If I haven't been on a bike for a while or with a new or different saddle, after MY butt is broken back in (2-3 rides) I'm set to go. When everything is adjusted right for me, it feels like the bike's not there.
Ischial Tuberosities - They're wider in most women and narrower in most men. That's why seats designed for women are wider in the rear.
Back to Brooks Pro saddles... This is the original saddle on my almost all original 1967 Peugeot PX-10. It has the same kind of cracking on the top surface as your saddle. I'd keep an eye on the gouge in the rear. If it starts to change it may be a crack forming.
This is what's in Brooks Proofide:
I use an old toothbrush to get it into the tight spaces in the underside at the nose. I also use a hair dryer set on low to get the Proofide to soak in better.
A lot of products labeled "neatsfoot oil" contain petroleum based oils... Some are ALL petroleum based oil. Petroleum will damage leather!
Found this saddle in New Mexico a few years back. Someone had been ridding it this way !!!
The Tange Champion 2 tubing on your bike has basically the same wall thickness as Columbus SL tubing and it's made with the same 4130 alloy steel. It should be a great riding bike.
One last thing, the stem on your "new" bike looks a little high. Stems and seatposts should be inserted a minimum of 75mm-80mm (3").
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
verktyg
Lots of great info, here, thanks so much! I'm accustomed to doing a lot of miles in much cheaper saddles so I think this will be a nice change. Nothing on that bike has been adjusted or serviced yet. All I did was take off the chain and the "dork disk." I just needed some excuse to look over it really closely.
Quoted: 603 Post(s)
Liked 1,062 Times
That thing is sweeeet...
Quoted: 603 Post(s)
Liked 1,062 Times
Yeah, you did get a bit of an upgrade, replaced the rims on mine too. Thanks!
Tim
Tim
Quoted: 339 Post(s)
Liked 631 Times
I just posted the following to another post above yours. That saddle looks usable. If you want to get rid of the cracked surface you could try just the sanding part I outlined. I think you could do that and proof ride and it will look almost new.
I have accumulated a number of old saddles doing resto for the Bike Exchange. A while ago I read a post from someone who soaked and reshaped an old Brooks and decided it was worth a try. The one I chose was not rideable, it's side having flared out so it was almost flat. I filled the bathroom sink with warm water and submerged the saddle in it. almost immediately she leather became completely limp and pliable. I removed it from the water, patted it dry (ish) and took it out to the shop. Then I took some heavy string and wrapped it around the saddle pulling the sides back down and restoring it to it's original shape. I left it there in the garage for a while till it had dried out thoroughly, then removed the string. The saddle retained the new shape. The only problem was that the string had left marks in the leather where it was cinched down tight. At this point the shape was good but the surface of the leather was uneven, with some surface cracking. With nothing to loose, I got out the vibrating sander, put some 400 grit paper on it, and sanded the surface of the saddle. The result was a uniform Swede like surface to the leather. I then changed to 1000 grit and sanded again , resulting in a smooth but not quite shiny surface. Good enough. finally I Got out the Proof ride and coated the saddle top and bottom and then buffed the topsides. In the end the saddle looked almost new.
This should work if the leather on the saddle is not too cracked. If the nose area has substantial cracks doing this may cause it to tear off completely which will end the experiment. Also, if the saddle has deep cracks in the center the soaking may expose fatal weakening. If you have an old leather saddle that is unridable as it is why not give the soaking a try
P.S. I just did the above on another old saddle . this time instead of string I used 3m blue masking tape to wrap the saddle to avoid the string cutting into the leather. Works much better.
Bikes: Fuji Touring Series V 1985, Motobecane Grand Touring 1982, Specialized Stumpjumper 1993, Raleigh International 1972, Raleigh Grand Prix 1972, Kuwahara Count 1983, Trek Cirrus 1987, Shogun 2001 1983, Cannondale SM700 1990
Quoted: 90 Post(s)
Liked 174 Times
thats a great saddle in fine condition, just needs a small amount of proofride, these things go for $190 new and $100 used on ebay, they are argueably the best saddles
https://www.brooksengland.com/en_us/...o-special.html
Likes For ZudeJammer:
Quoted: 1607 Post(s)
Liked 2,213 Times
I have been riding this since 1973. Less often with the bigger stable. My most comfortable saddle.
P1000082 on Flickr
P1000082 on Flickr
Likes For SJX426:
