Addiction 2022.1
#1401
Quoted: 9653 Post(s)
Liked 6,365 Times
#1402
Bikes: 79 Trek 930 is back on the road, 80 Trek 414, 84 Schwinn Letour Luxe,87 Schwinn Prelude, 92 Schwinn Paramount PDG 5
Quoted: 3184 Post(s)
Liked 1,840 Times
Forecast is fot the coldest week of the year. Your weather must be sliding south.
#1403
Quoted: 10236 Post(s)
Liked 5,183 Times
I havnt figured out how to blow snot rockets while wearing the mask. My head felt physically lighter after the monstrosity left my face.
BTW mojo, took your sock advice. Everything was nice and warm.
#1404
Liked 6,365 Times
Bad juju happens when driving a senior Honda: Woman rear-ends car on Highway 1 then walks over to cliff and falls into ocean: CHP (ksbw.com)
#1405
Liked 6,365 Times
Glad you were able to keep the little guy warm!
#1406
So it is
Quoted: 11394 Post(s)
Liked 4,736 Times
#1407
Habitual User
Quoted: 4933 Post(s)
Liked 8,072 Times
#1408
Liked 6,365 Times
I think they figured it out using this formula: The time of the auto-to-auto impact divided by the distance to the cliff multiplied by the rate of the gravitational pull on her body plus the coefficient of friction as determined by her body mass and adding the height of the cliff and then discounting by 30% if she was blonde.
Or, they could have looked at her driver's license.
#1409
Liked 5,183 Times
#1410
Habitual User
Liked 8,072 Times
#1411
Quoted: 8271 Post(s)
Liked 9,022 Times
The weird part is the end of it, helocopter pulled her body from the ocean. Huh?
Did you see the plane crash on the RR tracks and the cops pulled the guy out just seconds before a train came? A few miles from here.
Downed plane hit by train in LA after pilot freed (yahoo.com)
#1412
Liked 6,365 Times
Likes For Mojo31:
#1413
Habitual User
Liked 8,072 Times
Holy moly! It was not that pilot's day to die. However, I think his plane is going to need a few repairs.
Likes For Eric F:
#1414
VFL For Life
Bikes: Velo Volmobile
Quoted: 28590 Post(s)
Liked 1,855 Times
#1415
Mostly Harmless
Bikes: Have two wheels
Quoted: 13706 Post(s)
Liked 4,523 Times
#1416
VFL For Life
Liked 1,855 Times
#1417
Habitual User
Liked 8,072 Times
Blue skies with an expected high of 74 today. So Cal winters are rough.
Likes For Eric F:
#1418
Mostly Harmless
Liked 4,523 Times
#1419
Klaatu..Verata..Necktie?
Quoted: 10413 Post(s)
Liked 11,874 Times
Lucky you! Me, my nose starts running as soon as the temp drops below 60. This is why I chose to be tailgunner on last Saturday's C&V ride - then I got pressed into taking point on one segment when the youngest guy gave up on what is essentially 2.5 miles of 1.5%. So there I was on the front, pulling, with my nose running, unable to courteously clear my nostrils. One can only wipe so much.
#1420
Liked 11,874 Times
#1421
Liked 5,183 Times
Sounds legit. If I ever go missing off a cliff can you represent me?
#1422
Liked 11,874 Times
It was terrible in NorCal this morning. 47 degrees. The car windows were all covered in dew. I had to clear them off before I could see to drive. Took at least 5 minutes for the heater to get too warm so I had to turn it down.
Likes For genejockey:
#1423
Liked 11,874 Times
Thanks for the compliments on the Litespeed! It does LOOK nice! Not thrilled with the performance of the 27 year old Sachs Ergo levers, however. I'm having a hell of a time getting them to shift into the largest cog. It's a balance between tension and limit screw. Obviously I don't want to toss the chain into the spokes, but I do want to be able to use the 25. Also, I now remember why I hate triples - all my doubles, the chain climbs to the big ring or drops to the small ring without issues, but this one requires overshifting. I'm pretty sure I've got the alignment and height set correctly. So, I'm debating going for the Ultimate (haha) build earlier than planned, or possibly Interim Build #2, using the 7410 Dura Ace brakes, STIs, and RD. I'd still have to source BB, cranks, and FD, but it will be cheaper than the 6800/8000 Ultegra build I plan to eventually do.
EDIT: I probably ought to check that the hanger is properly aligned, too. Hey, it was late, and I wanted to finish it up and wrap the bars!
#1424
Habitual User
Liked 8,072 Times
#1425
Liked 6,365 Times
Likes For Mojo31:
