One spoke is laced incorrectly!
Old 05-18-22, 08:45 PM
dickbandit
dickbandit's Avatar
Bikes: 1980 Peugeot PFN-10, 1989 Bridgestone MB-3, 1988 Univega Alpina Uno, 1974 Velosolex Saint Tropez, 1995 Trek 830, 1986 Lotus Odyssey, 1987 Schwinn Mirada, 1987 Raleigh Elkhorn
Quoted: 21 Post(s)
Liked 99 Times in 32 Posts
As the title states: One spoke is laced incorrectly!
Finished rebuilding a 1990 or 91 Davis Phinney Serotta this weekend and was getting it ready for its maiden voyage tomorrow. When I was inflating the tires I noticed that one of the spokes on the rear driveside is laced incorrectly. It does not cross where it should, it merely passes over the other spoke and consequently does not make contact.
I did not notice this when I was truing up the wheels, which were relatively true to begin with. My first assumption was that the spoke was replaced at some point by someone with little experience-- but I'm not so sure since rim tape matches on front and rear wheels and looks like 30 year old factory tape.
Anyway, if the rear is true and reasonably evenly tensioned should I be concerned about one spoke laced incorrectly? The rims are 32 hole for what its worth.
Or... should I be anal and rebuild the entire wheel even if there is a chance it has lived its entire life problem free?
dickbandit is offline
Old 05-18-22, 08:58 PM
iab
iab's Avatar
Quoted: 3015 Post(s)
Liked 3,793 Times in 1,407 Posts
I don't think it matters, but I'm not a wheel building expert. But I do know enough about wheel building that relacing the spoke will take no more than 15 minutes of time. It's an easy fix.
iab is offline
Likes For iab:
Old 05-18-22, 09:07 PM
gkamieneski
Bikes: Pinarello Gavia TSX; Bianchi Intenso
Quoted: 167 Post(s)
Liked 92 Times in 62 Posts
You’re always going to wonder about the strength of the wheel due to a misslaced spoke. Better to just pull the spoke and weave it correctly, then true the wheel.
gkamieneski is offline
Likes For gkamieneski:
Old 05-18-22, 10:07 PM
P!N20
P!N20's Avatar
Quoted: 1079 Post(s)
Liked 1,898 Times in 931 Posts
It won't make any difference to the strength of the wheel, but if it keeps you up at night...
P!N20 is offline
Old 05-18-22, 11:14 PM
79pmooney
79pmooney's Avatar
Quoted: 4803 Post(s)
Liked 3,924 Times in 2,552 Posts
There is one real safety consideration. It is up to you to balance the risks over the hassles you may well run into trying to correct what may have worked for thousands of miles for others. This could show up at any time and the consequences could be large. Funny, yesterday yo were save but no longer.
The issue is, very simply, that you now know. Are you sure this won't erupt into an obsession that leads to psychiatrists, life-long debt, perhaps long-term inpatient care? Do your best to sit down, objectively weigh the risks and benefits and proceed from there. I have the perhaps unusual ability to simply decide that I am going to ignore it until I have the wheel off the bike and rim tape off for some other reason. Maybe get organized enough to ask at a bike shop if they have a spoke and nipple of the same length and gauge. (It is not a given that you can unscrew that nipple and reuse it. Threads may be frozen or close enough that you destroy the wrench flats getting it off and it may have been previously stressed by less than careful spoke wrench use (or a poorly fitting wrench) This being a high quality bike, the odds are the nipple is just fine. But if you dive into this without a shop handy, you just might need another nipple. The current ones "should" be the same thread but again, that risk - you might have to miss tomorrow's ride!
79pmooney is offline
Old 05-19-22, 03:34 AM
oneclick
Quoted: 1106 Post(s)
Liked 1,326 Times in 782 Posts
They are supposed to cross; fix it.
It's because the spokes share the load a bit better. On spokes that have done many miles you can sometimes see a wear mark at the crossing point.
Just do that spoke, get the rim true after and the wheel will be *slightly* better built.
oneclick is offline
Likes For oneclick:
Old 05-19-22, 07:20 AM
madpogue
Quoted: 2363 Post(s)
Liked 1,749 Times in 1,191 Posts
^^^^^ +1, treat it like any single spoke replacement. Re-lacing one spoke will take not much longer than reading this thread.....
madpogue is offline
Likes For madpogue:
Old 05-19-22, 07:26 AM
thinktubes
weapons-grade bolognium
thinktubes's Avatar
Quoted: 985 Post(s)
Liked 2,378 Times in 891 Posts
Fix it and sleep like a baby.
thinktubes is offline
Old 05-19-22, 08:24 AM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
Interlacing the spokes is good practice, and I do it, but the value is mostly at the edge case where spokes dip down toward zero tension while riding. Lots of wheels have been built without interlaced spokes over the years, and most of the time it goes unnoticed because no issues result. My 1964 Armstrong 3-speed's wheels weren't interlaced, for example.
So, if I found myself in possession of a wheel like the OP's, I would be conflicted. The OCD part of me would want to interlace the spoke because it is easy and quick to do (if it's a double-walled rim, you don't even need to take the tire off.) But another part of me might be curious to leave it be and view it as a long-term experiment to see what happens.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Likes For ThermionicScott:
Old 05-19-22, 07:28 PM
dickbandit
dickbandit's Avatar
Quoted: 21 Post(s)
Thank you everyone for your sensible words. Problems can seem so much more daunting at 10:30pm…
My compromise was to take the bike out tonight… and probably again on Saturday… knowing the wheel isn’t going to taco. And I’ll probably fix the errant spoke some evening next week.
Old 05-19-22, 08:47 PM
repechage
Quoted: 3464 Post(s)
Liked 2,829 Times in 1,995 Posts
My hunch the problem spoke is on the drive side of the rear wheel...
if so, shift small ring to largest cog ( lowest gear ) and double check the closeness of the errant spoke to the derailleur jockey cage.
if it appears very close or might contact if he rear wheel laterally deflected... don't use that low gear until the issue is resolved.
repechage is offline
Old 05-20-22, 11:52 AM
Dave Mayer
Dave Mayer's Avatar
Quoted: 1370 Post(s)
Liked 475 Times in 277 Posts
I agree that the errant spoke should be dealt with. This is a 5-minute job; you don't even have to take the tire off or even take the wheel off of the bike.
When you unwind the offending spoke, do NOT lose the nipple in the rim. Use a marker to make a mark on the spoke as to its depth in the nipple. When you rewind the nipple to the new position up against the mark, the rim will be very close to true.
Unsolicited advice: this generation of Shimano 600 is great stuff; it is clear why Shimano almost wiped out the Euro bike industry wholesale. The Shimano cogs and cassette system and shifting were a quantum jump over what even Campagnolo was offering at the time. However, your singe-pivot brakes are seriously underwhelming. Plus the brake pads that Shimano made at the time were dismal at stopping, and were only good at leaving disgusting black goo on rims when things got wet. I recommend replacing with Shimano 6403 dual pivot brakes for a major upgrade in power. Plus they self-center. Discard the original brake pads for some current Kool stops or the like.
Dave Mayer is offline
Likes For Dave Mayer:
Old 05-20-22, 12:28 PM
dickbandit
dickbandit's Avatar
Quoted: 21 Post(s)
Thanks for the procedural advice!
Already swapped the pads and shoes for more
modern ultegra shoes and kool stop black pads before I even got it on the road.
Old 05-20-22, 02:11 PM
Moe Zhoost
Half way there
Moe Zhoost's Avatar
Quoted: 986 Post(s)
Liked 880 Times in 527 Posts
Likely the incorrectly laced spoke is a replacement. Because the mechanic took the easy way over the correct way, I'd be wary about other issues, so I'd correct the lacing at some early opportunity and also check tensions and dish while I'm at it. I don't want to imply that I think it's a critical problem, though. The wheel isn't going to fail, it just hasn't yet reached oneness with the cycling gods.
Moe Zhoost is offline
Old 05-20-22, 04:54 PM
dickbandit
dickbandit's Avatar
Quoted: 21 Post(s)
It’s fixed everybody….
took ten minutes and the wheel is true, evenly tensioned and properly dished…
amen
Old 05-20-22, 06:59 PM
OldCoot
Bikes: 82 Univega Specialissima, Bike Friday Pocket Rocket, Kona Wheelhouse, Rocky Mtn Thunderbolt, Viner Strada Bianca, ~73 Bob Jackson, ~75 Volkscycle Mark100.
Quoted: 70 Post(s)
Liked 183 Times in 73 Posts
I had to laugh at 'one' spoke is laced in correctly. Not possible, unless another spoke is missing ( doesn't that count as incorrectly too?). In my experience there's always another one in the wrong place that the incorrect one ( that you noticed) should go!
Glad you fixed it!
OldCoot is offline
Likes For OldCoot:
Old 05-20-22, 07:57 PM
seedsbelize2
seedsbelize2's Avatar
Bikes: 79 Trek 930 is back on the road, 80 Trek 414, 84 Schwinn Letour Luxe,87 Schwinn Prelude, 92 Schwinn Paramount PDG 5
Quoted: 3190 Post(s)
Liked 1,841 Times in 1,161 Posts
One of my bikes has been missing a rear spoke for well over a year. Need I say more?
Good onya for fixing it.
seedsbelize2 is offline
Likes For seedsbelize2:
