building a full suspension bike.
I've dreamed for a while now of building a custom bike frame, and I decided that I want to make it a full suspension. I've done a lot of research on different rear suspension designs, and that for me thinking, why not use a front suspension fork as the rear suspension. It would be attached in almost the same way as on the front, and would solve the problems that each rear suspension has. I was just interested to hear what your guys' thoughts were.
Thanks,
Serge
Thanks,
Serge
Quoted: 3722 Post(s)
Liked 2,760 Times
This has been done before, Manitou comes to mind. But the issues involved with rear suspension are rather different then the front. Hub width, chain tug, direction of bump forces WRT the "fork", the need for a swing arm and the changing CS length resulting are just some challenges. Andy.
Problem (hashtag) 1 ... a front fork has a 100mm wide space to put your wheel in .. rears are 135.
Liked 2,760 Times
IIRC the bike that I read about that used a Manitou fork as the basic of rear suspension also used a crown that had clamped stanchions. So a simple machining of a wider "crown" (yoke?) was the solution back then. Today most forks have pressed stanchions/crowns. So today's solutions will be different. Andy.
Ok. Thanks. I just wanted to know if it was theoretically possible to do something like that. I'm still trying to figure out what my options with this bike.
Rhapsodic Laviathan
The best rear suspension(by design), I've ever seen on a general non specific(such as downhill, trials, etc) general purpose mtb, although it was implemented on a crrappy bike, with poor thought, is the rear suspension of aa Mongoose xr250.
Liked 2,760 Times
While I am no avid mountain biker I do find the design aspects very interesting. There are so many elements to play with, many are not understood well by the buying public. So enters the marketing department... Andy.
Rhapsodic Laviathan
Mongoose tend to use Element forks, many here may say they suck- I say they are pretty good, they are, or act progressive rate. The frame was aluminum, the rear suspension was steel(I still broke one of the control arms) and acted like a sla car suspension, or a bmw motorcycle rear suspension, eleminated the arching motion of most f/s rear ends. personally for a mountainbike that isn't a downhill, I would copy that suspension. Hell I want ti build such a suspension fir my moped.
you can zoom rhe pics in this thread www.bigboxbikes.com ? View topic - Mongoose xr250
Straightbangin
Bicycle Mechanics
17
09-30-18 06:40 AM
bjjoondo
Hybrid Bicycles
57
01-25-10 08:28 AM
