Looking for insight, getting fed up
Rhapsodic Laviathan
I keep getting punctures on the inside of innertubes- the rim racing portion. These patches I have are not holding, those damn lil round black&orange patches. The rim not only has a rim strip, but also has electrical tape assisting it. I'm on my last patch and do not want to keep spending 7 bucks on tubes every few days.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2567 Post(s)
Liked 5,599 Times
How are you applying the patches? Rough up the area with sand paper, use a generous amount of glue and let completely dry, apply patch without touching the adhesive side of the patch?
I would sweep my finger on the inside of the rim looking for anything sharp or a spoke protruding. I would note the position of the tube relative to the rim at the puncture site and investigate there
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
I am potato.
Quoted: 1782 Post(s)
Liked 1,621 Times
My first thought is patch application. You are abrading the tube & letting the vulcanizing compound ("glue") completely dry before applying the patch, right? Yes? Good.
Secondly, how much spoke is sticking up beyond the spoke nipple? It should be zero. A bike shop can fix this. If the spokes are too long they can nip off the bit sticking up. How is your spoke tension, BTW?
Third: I'm going to guess you have single wall rims. The proper rim strip for single wall rims is a good thick cloth based rim tape like Velox or similar. Tubeless tape is too thin for this application. The plastic banding they use on shipping pallets &/or a thin band of rubber often used just isn't as good at cloth based rim tape. Do they work? Yes. They"re just not as good. Try switching to Velox. Maybe 2 layers if problems persist.
Good luck,
base2
edit: You can patch a tube about a bazillion times. The tube & patch simply expands to the tire casing & goes no further. Unless you have a gash or catastrophic tear from a blow out, or the nipple seperates, you need not spend $7.00 every single time. Vulcanized rubber patches literally become part of the tube they are attached to. The "quick patch" stick-on ones, not so much.
Good luck,
base2
Likes For base2:
Bikes: 2018 Jamis Renegade Exploit, 1996 Trek 930, mid-90's Dean El Diente, 2010 Scott Addict SL, 1998 Trek 730, Xtracycle EdgeRunner 30D, Xtracycle Swoop, 1992 Trek 790
Quoted: 87 Post(s)
Liked 106 Times
Are the holes consistently in the same location on the tube? I got several flats on one wheel, no obvious cause to me - I'd just find the tire flat when I went to ride the bike. The hole was always near the valve, on the side of the tube facing the rim. When I went to my LBS to buy yet another tube, I mentioned the problem to the mechanic. He asked some questions about the bike (I hadn't ridden it there, due to the flat tire) and he noted that that particular bike had come with narrow rims. I'd had trouble seating the tire bead right near the valve due to this. He suggested that I was pushing the valve up, into the tire, so the bead would seat, and that this allowed the tube to fold over on itself (making sort of an S shape next to the valve). Then, once inflated, the sharp bend stretched the tube until it failed. Now I use the valve stem nut (Presta valve) to lock the valve against the rim, and I haven't had another flat.
You might not have the same issue, but mechanics have a lot of knowledge - might be worth bringing your wheel to your local shop and asking for some help, if you can't identify the cause.
Likes For nathand:
Quoted: 426 Post(s)
Liked 696 Times
Another vote for Velox rim cloth tape. Also, use a cotton ball or used drier sheet to go around the rim--they will snag on anything and if there's something in the rim, you'll find it! I've found that some "glue" just doesn't work as well. Rema vulcanizing fluid is what I've found holds best. You say the hole is always near the valve--are you using the nut on a presta stem, and tightening it down on the rim--if you are, don't do that. If you want to leave the nut on, move it up on the stem, can always put it down toward the rim when inflating.
Likes For freeranger:
Take off the wheel and take it up on the highest hill in the area make sure nothing is in the way then gently give it a roll and go home problem solved
Quoted: 1364 Post(s)
Liked 1,676 Times
The vulcanizing fluid must dry before applying patch. Feels wrong, but it's right.
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,202 Times
As for what is causing the puncture, by all means check the rim tape for any burrs. Get a cotton ball and run it around the inside of the rim. Any burrs will catch the cotton and pull out bits that are visible. Two other tricks to finding a chronic problem is “clock” the tire and tube. For the tire, align the label of the tire with the valve stem. It makes finding whatever is causing the puncture easier. The other trick for the tube is to mark the tube with a direction at the valve stem (use a silver Sharpie marker). If you install it consistently the same way, you can find the object puncturing the tube easier.
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 383 Post(s)
Liked 690 Times
I've never had luck patching a tube on the inner diameter. Gave up after a couple of times realizing it doesn't work well.
Puncturing on the inside of the tube? You might have a metal sliver stuck in the tape. Happened to me once, less frustration to just replace the tape. What is it, about $4. Also check the inside walls of the rim for burrs.
Likes For kahn:
climber has-been
Quoted: 3413 Post(s)
Liked 3,542 Times
Get some Velox rim tape in the width that your rim calls for, install it. No more punctures on the inside of your tubes.
Velox Bicycle Rim Tape
Ride, Rest, Repeat. ROUVY: terrymorse
Last edited by terrymorse; 05-30-21 at 08:38 AM. Reason: changed from Zefal to Velox tape
I am potato.
Liked 1,621 Times
While I agree with the need for good preparation, “vulcanizing fluid” is not “glue”. True vulcanizing fluid has a chemical activator in the fluid that is used in concert with another chemical in the patch to make rubber bonds. “Glue”, especially rubber cement, is missing the activator in the fluid and the chemical in the patch.
The silver Sharpie® on the tube is actually a really good idea.
I am dubious about the poorly manufactured rubber claim. Sample size of one, & all that. However I can't completely discount it either. Recently (starting the year before last) I've had issues with Continental Supersonic tubes. For whatever reason the area around the valve stems tend to tear out. Even when knowing how delicate they are & acting accordingly, it seemed to make no difference. Truth be told, it is this frustration that drove me to tubeless.
edit: And yes, Rema! It's hard to beat Rema patches & vulcanizing compound bought in bulk on Amazon or elsewhere. I find i much prefer the smaller diameter patches, but to each his own.
Likes For bruce19:
Quoted: 340 Post(s)
Liked 275 Times
Had two flats this year, all on the inside of the tube. Same wheel. Put on a new tube in the field. Filled it with CO2, but did it too fast. Tire filled up and deflated within a minute. Walk of shame. At home, found both holes in the same place. No roughness on the rim, but I added a second layer of Velox. I patched both tubes, and so I have the patch and tape there now in the area where it leaked. I beiieve the original happened because I went from 1.75" Kenda Kwest to 2.0" Big Apples, and stayed with 80 PSI, More compressive force inside the tire? Running 40 PSI now.
Rhapsodic Laviathan
Rhapsodic Laviathan
Rhapsodic Laviathan
Rhapsodic Laviathan
“Black and orange” patches describe almost every patch out there. Just because they are the same color doesn’t mean that they are all the same. Many of them...well, most of them...are just bit of rubber and rubber cement. Rema Tip-Top are different from all the rest. Instead of depending on rubber contact cement, they actually perform chemistry to make new rubber bonds that are stronger and less likely to fail...especially on the inner curve of the tube.
I don’t agree. Most of my flats over the last few years have been on the inner part of the tube. I know how to apply rim tape and I use double wall rims. I also know how to check for foreign objects in the tire and wheel. I can find nothing in the rim tape nor any tears the tape but I’ve been experiencing more and more of this kind of puncture. Right now my working hypothesis is that it’s the tubes. I went for years with the same rim tape only to have the tubes start to fail on the inner part. I’m not particular about the brand of tube I use but I’ve seen this kind of puncture across a wide range of tubes on many different bikes. I think it’s the compounding of the rubber being used now. Maybe they aren’t blending the rubber properly or they are using poorer quality rubber. But given that the problem has occurred for me over a range of tubes and on different bikes, I’ve got to say that it’s the tubes.
As long as you use the proper patch kit (*cough*Rema*cough*), I fully agree.
Liked 4,202 Times
I think we are in agreement. I put the word glue in quotes & parenthesis to address the potential that the OP might have been using the terms interchangibly in his/her own conventional vernacular. Wet application/adhesion problems would indicate an absence of knowledge in this particular area.
Stuart Black
Stuart Black
Liked 4,202 Times
I think that's the other problem; it seems to just be rubber cement. It doesn't even burn like proper vulcanizing adhesive, that bonds the material together. There's a large patch on the old tube that gets a bubble in it, if inflated outside a tire where it looks like it'd split open and never does. One of those don't question it ordeals. I think this discussion has gotten me right on track.
Let the glue dry and then apply the patch.
Stuart Black
Stuart Black
Half way there
Quoted: 985 Post(s)
Liked 879 Times
On the rare occasions when this has happened to me, and when all sensible efforts have failed to resolve, I break out my fiber reinforced packing tape and run a strip tightly around the rim. Then run your preferred rim strip on top of it. This has always fixed things for me. The downside is that the fiber tape may be difficult to remove if you need to.
Also, Rema TipTop is a patch system that you can rely on.
Good luck.
Good luck.
Even a non-sharp discontinuity can erode through a tube. I had a similar problem once with a thick boot. As for running your finger around inside the rim, maybe a cotton ball, to reduce the likelihood of blood.
Likes For Pratt:
I'll just add that it's not just spokes that can make a hole. If the tape doesn't *completely* cover the spoke holes, the edge of a hole can cut the tube too. Sometimes it's hard to see it happening because the tape LOOKS ok and only exposes the edge of the hole under pressure.
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times
came here to post this.
Mind you I can still get “flats” (like a nail puncture) with tubeless but much less likely and it is really self repairing for most everything but a sidewall gash. I’ve hit a couple nails or glass shards, which I pulled out, let the sealant do it’s thing, added back air, then was back on my merry way.
Quoted: 6177 Post(s)
Liked 4,794 Times
Have you figured out why you are flatting so often? In the last 10 years, most of my flats were poor installation, some worn out rim tape, few were road hazards or punctures.
