27" wheels for old but not fancy bikes?
I've seen loads of discussion on 27" tires, but less so on sources for 27" rims/wheels.
I only see two manufacturers for 27" wheels, new (Sta-Tru, Wheel Master). Both seem to put me up to $100 if I want to replace both wheels. Is there any difference between the two (at that rough price, both seemed to use UCP spokes)?
Are there other, affordable sources for proletarian wheels?
Does it make more sense just to hunt down other cheap old bikes with 27" rims in reasonable true and just cannabalize?
While I might consider new wheels for my old Trek, seems crazy to put in $100 on wheels for old bikes worth $40 if that.
(... he says with some regret, having just dropped $175 at LBS so daughter's beaten up Schwinn World Tourist would brake and shift better...)
(Do folks simply convert to 700C and avoid the issue?)
Quoted: 767 Post(s)
Liked 1,898 Times
Here is one option that I have personal experience with.
https://www.velomine.com/index.php?m...dasohd40dpbl32
This is a nice set at an affordable price. The brake tracks are machined, and enhance braking performance to a degree. I have had these on a few bikes and never had a single complaint.
There are also sets that use Sun rims that are wider. Both make for a nice way to get an old bike back on the road.
Likes For BFisher:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I prefer to think in terms of Total Cost of Ownership. If I get a great deal on a bike or frame, it doesn't hurt me that much to put some money into good wheels, or quality drivetrain parts. If you are one of those "I bought it for $X, so I can't put more than $Y into it" types then you'll paint yourself into a corner fast.
Likes For ThermionicScott:
Thanks- these look better than the other two - maybe for the Trek & Cannondale.
Quoted: 405 Post(s)
Liked 430 Times
I can't think of a Trek old enough to wear 27" shoes that wouldn't be worth a couple hundred bucks in decent running order.
If toy're looking for new hoops, just convert the bike to 700c and never worry about tire availability again. Plus, you usually get more room for wider tires. It's only 4 mm difference in brake reach, so many bikes won't need new brakes. Unless you're doing an "as-sold" restoration, there's no reason to stick with 27" wheels if you're replacing the wheels anyway. And gently used, top-quality 126-spaced 700c wheels are available everywhere for small coin.
Now, to answer the question you actually asked, I've had 1 Sta-Tru wheel. It was just about exactly like very other cheap replacement wheel I've ever seen or owned... as long as you tension the spokes and repack the hub as soon as you take 'em outta da box, they work well and last for several years of moderate use. If that Sta-Tru hadn't been a singlespeed, it'd still be on my bike today. I got like 60 bucks for it on Craigslist, even.
--Shannon
--Shannon
Likes For ShannonM:
Right. I'd say my Trek from 1981 is fully depreciated, so I can put more into it to keep it on the road (it was neglected in favor of the $40 Specialized Hard Rock with slicks that didn't need anything - including my time for maintenance). I kept telling my wife that going to the bike auction held by the local PD was "just for parts", now I have two bikes in storage, two hanging from the ceiling, two on the walls, and my side of the garage is 'unusable' because of four bikes on the floor. I think I just need to stop buying bikes, then I don't have to find parts... TCO mentality is fine, until your spouse asks you "how are you going to ride five bikes".
--Shannon
--Shannon
Phyllo-buster
Quoted: 2297 Post(s)
Liked 2,054 Times
$100 for any decent set of wheels is a bargain, regardless of the frame it's going on.
Likes For clubman:
Quoted: 4510 Post(s)
Liked 6,377 Times
Likes For merziac:
Quoted: 5888 Post(s)
Liked 3,471 Times
The velomine wheels are fine but if your brakes will reach, you might as well go with 700 c
Quoted: 1872 Post(s)
Liked 692 Times
I mean I'd send you all my 27" wheels but when you're looking at $100 for a set the shipping basically makes it a non-starter.
2019 Salsa Warbird
2019 Salsa Warbird
Extraordinary Magnitude
Quoted: 2607 Post(s)
Liked 1,699 Times
If you've got a bike that you like riding; don't be a Mad Man- if you can afford it- use the good ****.
IMO- if you've got 27s on there, and they're good, and you don't really want to change- get good tires and go with it until you need new wheels. If you need new wheels, if your finances allow it- go to 700C. There's just a WORLD of better tires than Paselas, Sand Canyons and Continentals. If it's a Trek with 27s on it, it's probably not a "performance" bike, so you'll be able to run wider tires and make the ride even better for yourself.
Commence to jigglin’ huh?!?!
Quoted: 634 Post(s)
Liked 1,277 Times
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
I can't think of any reason to put any money into anything 27" it's dead with slim tire choices that can and will dry up instantly.
If you had a bunch of 27" stuff laying around and can build your own wheels the case for 27" get better, but longer reach brakes makes more sense long term to me.
Those points above are really important. Bikes like 410s and 412s are well renown bikes with great reputations that are built well, ride well and command decent prices despite being at the lower end of the hierarchy.
I think the same seller, who was on CL also had a bunch of new take off 27" wheels from various very early 80's Trek bikes. They were listed in NJ.
A buddy bought a set for $200, they were basically brand new 1980 Trek 412 or 512 wheels with Rigida 1320 rims, Campy hubs, and original skinwall tires.
I wouldn't have thought the tires would be much good but he's been riding them all summer with no issues.
The guy had something like 20 brand new bikes still in the box, most were tall frames. I haven't seen the listings for any bikes in a while but I do see him listing some wheels from time to time. I think the guy buys out old bike shop inventories in the NY/NJ area.
Most folks around here though simply will not put more than a few dollars into fixing any bike, I've gotten a few really nice bikes lately after they realized a good set of tires would run them over $50. More if you want anything decent. They toss a vintage Raleigh or Schwinn to the curb and go buy a new something with tires that hold air.
The selection of 27" tires is still decent but its mail order only these days around here. The few bikes shops that are left just don't stock anything, 27" or other.
All through last year though there didn't seem to be any shortage of high end tires, just those that were affordable, so if your after better quality tires, the supply of expensive tires didn't seem to be hampered by the pandemic.
Quoted: 960 Post(s)
Liked 1,626 Times
I have had really good satisfaction with Machine Built wheels. When I get them I check them over carefully. Often I have had to make adjustments, mostly due to spoke tension. Of course we don't know what these wheels are going through during transport. One rear wheel I got I just loosened all the spokes and re-dished it. It was still a bargain for me due to the unavailability of economical hand built wheels...
Quoted: 2337 Post(s)
Liked 2,818 Times
Just got a new to me bike with 27's wheels are in great shape (and interestingly enough are early shimano cassette) so I just got new velox tape, conti tubes and paselas. If they ever die I will move to 700c, but for now and the use as a run errand bike work great
Phyllo-buster
Liked 2,054 Times
Likes For clubman:
Liked 1,699 Times
Not that I disagree that the Trek 410-412 bikes were great bikes, but it wasn't but a few months ago I was reading the replies to a guy who was looking at a new old stock Trek 412 and he basically got jumped all over about it being a low end bike not worth more than a few hundred bucks.
Likes For The Golden Boy:
I don't know the thread you're talking about- but if it's like the people that buy out unsold entry level inventory and try to sell them for $600-$1000... I'm not up with selling prices, but historically, a decently set up Trek 410/412 has been worth a couple hundred bucks. It's not a $40 bike, but it's not made of gold- it's a respectable, utilitarian frame that makes for a solid mid-level bike. Trek's "entry level" in the late 70s early 80s was a CrMo main frame with HiTen stays and fork. They're not museum pieces, they're not prestigious racing models, they're not particularly rare- so even a pristine one just isn't worth a whole lot more than "a good bike with a Trek head badge on it."
Bikes: Still have a few left!
Quoted: 467 Post(s)
Liked 532 Times
Check your local CL under "Bike Parts". When I needed a 27" rear wheel for one of my bikes, a guy had offered a brand new set of 27" Alex rim wheels for $25/each.(he bought wrong size by mistake) Was nearby, and when I told him I only wanted the rear, he said I was the only person responded to ad, so take both for $25. Later used the front on another bike. That was few years ago and given depressed vintage prices now, you may find a wheel for $5. DonLast edited by ollo_ollo; 08-05-21 at 07:27 AM. Reason: correction
Likes For ollo_ollo:
