Best kind of Weight lifting for Cycling?
Expired Member
Quoted: 3658 Post(s)
Liked 5,404 Times
Folks, as usual, OP has thrown this in the punch bowl and disappeared.
Quoted: 4391 Post(s)
Liked 4,833 Times
This is the part that made me think it was just a simple fatigue issue. The balancing it out part is to do less of one thing and more of another, while not pushing beyond your total combined capacity. Rest and recovery is very important too. The easiest way to manage all this is to follow a simple structured training schedule with periods of maintenance, build and recovery.
Liked 4,833 Times
Quoted: 4227 Post(s)
Liked 2,488 Times
Likes For wolfchild:
I'll surmise that cycling is very good at developing the main muscles needed for cycling quite well, and is also good at not ignoring supporting muscles to the levels required to support the main muscles. Most forms of cycling except track, usually need endurance more than ultimate strength. Most forms of road cycling racing or time trialing doesn't require the strength and power that weight training could give because most high output situations require mostly endurance and not short bursts of high power. That's why sprinters usually don't win tours or time trials.
Would you get some benefit from weight repetitions of main cycling muscles pushing them beyond the loads they are subjected to in intense cycling training? I would guess that every training manager of a road cycling team has a clear opinion on this, and that this isn't a mystery to them. Somebody has already tested this and all teams know the answer. One factor is recovery, When are you going to place an even greater load than training is already putting on these muscles that are already getting pushed hard from the cycling? Are you going to waste a day of cycling training for a weight training day and then another day for recovery?
Maybe there is some benefit to working some of the supporting muscles for injury prevention or potentially increasing total strength by making periphery muscles stronger. There may also be some advantage to building strength of main cycling muscles outside of the range that cycling works them.
I'll guess training cycling muscles to the strength required to win road races or time trials isn't as difficult as training them to the level of endurance required, and that endurance is the main focus.
Liked 4,833 Times
They pretty much agree with everything you said in the above post i.e. strength plays very little part in cycling power output. It sounds slightly counter-intuitive but makes sense once you realise that pedal forces are very low compared to an individual's maximal strength, even when sprinting.
But this is all relative to pure cycling performance, not general fitness and health and in other activities where maximal strength may be much more important.
Personally I just follow a very simple light strength/mobility regime to compliment my cycling. The usual planks, squats, lunges, kettlebell swings and a bit of basic yoga.
Likes For PeteHski:
Quoted: 696 Post(s)
Liked 910 Times
I do 16oz curls once or twice a week.
Likes For Ghazmh:
climber has-been
Quoted: 3422 Post(s)
Liked 3,559 Times
Several weeks ago, before I started doing "big gear hill training", I was stalling out on the steep stuff. Recently, it has gotten easier.
My legs now look a bit less chicken-like, also.
Ride, Rest, Repeat. ROUVY: terrymorse
