Crank axle keeps loosening up.
Old 07-28-21, 06:42 PM
robertj298
robertj298's Avatar
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 556 Post(s)
Liked 257 Times in 122 Posts
I've taken the bottom bracket apart and put it back together 3 times. I've adjusted
the adjustable cup 3 times and locked it tight. I ride 2 blocks and the axle wobbles.
Any suggestions?
robertj298 is offline
Old 07-28-21, 07:51 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 3011 Post(s)
Liked 1,336 Times in 934 Posts
We can't see or touch the bike... improper assembly, cross threaded cup, really badly pitted axle/cup, damaged lock ting threads, more??? Andy
AndrewRStewart
Andrew R Stewart is offline
Old 07-28-21, 09:14 PM
robertj298
robertj298's Avatar
Quoted: 556 Post(s)
None of the above, I've done 10 of these and it's a pretty straight forward job. The only thing
I noticed on this one was the cage fits pretty tight against the axle cone and yes I have them in the right direction.
Maybe the cage is slightly bent. I'll try putting the bearings in loose tomorrow.
Old 07-28-21, 09:22 PM
Russ Roth
Quoted: 641 Post(s)
Liked 498 Times in 378 Posts
Could also be the wrong cage?
What part is coming loose after riding? You're saying the axle starts wobbling but is the fixed cup and the lock ring still tight to the frame the way they should be or is one of them working their way loose? If they're staying tight then as you say, something is wrong with the bearings somehow, installing the cage backwards due to your experience would seem to be an absent-minded thing to do but the best of us have done similar things when distracted. Do the new bearings exactly match the old ones, are the races clean and even and is the spindle straight?Any of these being off could result in adjusting wrong and having it come loose under load.
Russ Roth is offline
Old 07-28-21, 09:34 PM
robertj298
robertj298's Avatar
Quoted: 556 Post(s)
The inside of the bottom bracket is the cleanest I've worked on. The axle and cups and cones look new.
I don't think the bike had many miles on it so I just cleaned everything and regreased everything and used the original bearings .I've made stupid mistakes
before but I checked the cage orientation 3 times lol
Old 07-28-21, 09:57 PM
Andrew R Stewart
BB face(s) off alignment? Miss matched axle and cups? Andy
AndrewRStewart
Old 07-28-21, 10:05 PM
robertj298
robertj298's Avatar
Quoted: 556 Post(s)
Possible but by the condition of the bike and the history I would bet everything is original even the original seat looks new
Old 07-29-21, 05:33 AM
shelbyfv
shelbyfv's Avatar
Quoted: 2594 Post(s)
Liked 2,890 Times in 1,535 Posts
More ideas here https://www.bikeforums.net/classic-v...ing-loose.html and https://www.bikeforums.net/bicycle-m...direction.html
shelbyfv is offline
Old 07-29-21, 11:16 AM
SurferRosa
Señor Member
SurferRosa's Avatar
Quoted: 1912 Post(s)
Liked 2,170 Times in 1,208 Posts
In his third (c&v) thread on this subject, he had the bearing retainer in backwards.
^ This.
SurferRosa is offline
