Derailleur spring tensions
Old 07-29-21, 04:28 PM
mdarnton
Bikes: nothing to brag about
Quoted: 48 Post(s)
Liked 116 Times in 63 Posts
My experience with shifting is very limited to the Campagnolo NR shifters on my 1970 Raleigh. Now I have had my first new bike since then, a Trek FX1, and am really amazed by the amount of spring resistance in the shifting mechanisms. Is it this way now, or is it just the way that low-end shifters are, and why does that have to be? Really, the amount of muscle it takes is absurd! If that's the way it has to be now, I hear about how great equipment is now compared with the past, but I'm not convinced, if this is an example.
Or is it as it is in so many other fields--they intentionally build low end equipment poorly to convince us to spend more bucks? If I were to tear all of this down and replace the springs with something that didn't break my thumbs, would shifting really come to an end? I can't believe that 50 years later this has to be a problem even at the bottom end.
Genuinely curious if this is the best they can come up with for the bottom end after all these years.
mdarnton is offline
Old 07-29-21, 05:55 PM
shelbyfv
shelbyfv's Avatar
Quoted: 2569 Post(s)
Liked 2,823 Times in 1,508 Posts
Do they have a period where you can return it? I doubt you'll have any luck trying to modify the shifter. Maybe try something with a twist grip if that would suit you better.
shelbyfv is offline
Old 07-29-21, 08:50 PM
mdarnton
Quoted: 48 Post(s)
I can handle it. My question is more if this really is the norm that such a simple problem should have such a poor solution. It seems like there's a lot of room for improvement.
On the other hand, the disc brakes are quite a miracle of efficiency.
mdarnton is offline
Old 07-29-21, 09:01 PM
JanMM
rebmeM roineS
JanMM's Avatar
Quoted: 612 Post(s)
Liked 263 Times in 170 Posts
This is your first experience with indexed shifting? Assuming the NR shifters are circa 1970.
JanMM is offline
Old 07-29-21, 09:34 PM
DorkDisk
Bikes: Ritchey Swiss Cross | Teesdale Kona Hot | Haro Extreme | Specialized Stumpjumper Comp | Cannondale F1000 | Shogun 1000 | Cannondale M500 | Norco Charger | Marin Muirwoods 29er | Hiawatha 3sp | Shogun Kaze | Breezer Lightning
Quoted: 469 Post(s)
Liked 631 Times in 336 Posts
Low end flat bar front indexed shifting is clunky, loud, and requires much thumb effort. Rear shifting should be considerably much smoother. Are your cables lubed/in good shape?
DorkDisk is offline
Old 07-30-21, 02:26 AM
mdarnton
Quoted: 48 Post(s)
Yes, this is my first indexed shifting experience, and they certainly do seem clunky and inelegant. I am a fossil, yes. :-) I guess my amazement is that the low end has moved so little in 50 years, or maybe gone backwards, even. Maybe I would be happier with friction shifters?
The bike is a few months old now, but I will certainly try lubing the cables anyway, thanks. it can't hurt.
After a decade or so away from riding my thought was that I would put money into a new bike rather than replacing the tubular-tired wheels on the old one, but perhaps that was the wrong decision. That's still an option.
mdarnton is offline
Old 07-30-21, 05:43 AM
Outrider1
Outrider1's Avatar
Bikes: Trek Emonda ALR 5, Motobecane Cafe Disc Comp
Quoted: 63 Post(s)
Liked 112 Times in 53 Posts
This doesn't sound right. I have a similar drivetrain on my hybrid and the shiftiing is rather smooth on both derailleurs. Can you take it back to the lbs and have them take a look?
Outrider1 is offline
Old 07-30-21, 06:38 AM
mdarnton
Quoted: 48 Post(s)
The shifting is smooth. I am referring to the resistance in the system. I remember a similar thread a while ago where people were referring to getting thumb joint problems from these systems, so I don't think it is a problem specific to my bike.
mdarnton is offline
Old 07-30-21, 07:10 AM
JanMM
rebmeM roineS
JanMM's Avatar
Quoted: 612 Post(s)
It’s been at least a couple of decades since I used downtube friction shifters but I do remember they required less hand/digits movement/effort than the twist shifters and trigger shifters I’ve used since then. Of course, I don’t have to reach down to shift.
JanMM is offline
Old 07-30-21, 07:44 AM
mdarnton
Quoted: 48 Post(s)
Yes, and I think I have reasoned it out.... a delicate derailleur, one spring, six inches of cable housing at the back, vs a big (cheap) derailleur with a big spring compensating for precision and to drag cable through several feet of higher resistance housing going around a lot of bends (none of that on downtube shifters), and a mess of mechanics at the hand end with a big spring there to keep that in order. All of this so that people don't have to think or learn a skill. Modern times, no gain.
Forget I asked. :-)
mdarnton is offline
