what is your recommendation for road bike pedals without cleat?
Old 07-29-21, 08:35 PM
cycling2012
Bikes: Merida x-fit 2010;
Quoted: 67 Post(s)
Liked 4 Times in 4 Posts
what is ur recommedation for road bike pedals without cleat?
my bike is pinarello F10 ,CP SUPER RED 12S ,BORA ULTRA 50.
I often ride my bike for 30-130km,use my adidas shoes ride for 1-2 years.
so I decide use cleatless pedals.
cycling2012 is offline
Old 07-29-21, 08:50 PM
N2deep
N2deep's Avatar
Quoted: 20 Post(s)
Liked 19 Times in 15 Posts
I dont have a recommendation but a cautionary tale. I changed from frogs to platforms on my fixie and found the platforms caught the pavement in a fast corner, losing skin is never fun. Todays platforms are huge compared to cleats and significantly reduce your turn angles especially the style with the allen heads on the peripheral. I immediately put the frogs back on, no more platforms for me. Try to buy smaller platforms if possible and check your turn angles with your pedals close to the pavement. Have Fun
N2deep is offline
Old 07-29-21, 09:09 PM
chaadster
Thread Killer
Bikes: '15 Kinesis Racelight 4S, '76 Motebecane Gran Jubilée, '17 Dedacciai Gladiatore2, '12 Breezer Venturi, '09 Dahon Mariner, '12 Mercier Nano, '95 DeKerf Team SL, '19 Tern Rally, ‘21 Breezer Doppler Cafe+, ‘19 T Lab X3
Quoted: 1701 Post(s)
Liked 734 Times in 456 Posts
I’d suggest MKS GR10 in black. They’ll take a toe clip, too, if you want some security.
https://www.mkspedal.com/?q=en/product/node/74
chaadster is offline
Likes For chaadster:
Old 07-29-21, 09:13 PM
shelbyfv
shelbyfv's Avatar
Quoted: 2594 Post(s)
Liked 2,890 Times in 1,535 Posts
^^^^Those do look nice.
shelbyfv is offline
Old 07-29-21, 09:30 PM
cyclic_eric
cyclic_eric's Avatar
Bikes: 2014 Supersix Evo, 1984 Gitane TdF
Quoted: 42 Post(s)
Liked 36 Times in 25 Posts
In your photo, those look like Look-style pedals, not platform types.
If you're going with toe-clip pedals, I recommend "Giro VR Rumble cycling" shoes.
cyclic_eric is offline
Old 07-30-21, 12:03 AM
cycling2012
Quoted: 67 Post(s)
https://www.ebay.com/itm/264805160867
what about this one? in China it's about $60.
but I just want to know what is good and negative about this type for my road bike?
Old 07-30-21, 12:40 AM
Kimmo
bike whisperer
Kimmo's Avatar
Quoted: 1379 Post(s)
Liked 609 Times in 432 Posts
Pffff, nice toeclip pedals haven't been a thing since the 80s.
There's your cornering clearance.
Kimmo is offline
Old 07-30-21, 12:50 AM
Racing Dan
Racing Dan's Avatar
Quoted: 1094 Post(s)
Liked 186 Times in 127 Posts
I would suggest pinned pedals, like the one you suggested, but with less tall pins. They dig into the foot after a while. Like a XT flat pedal. A few wellgo pedals have shallow pins as well. I have some Wellgos. B-030s I believe. They are fine, but not as nice as XTs. With a flat shoe foot retention is perfectly fine and you won't slip, but of course some around here, as evidenced in the other thread, will claim it a death trap! ;-)
Racing Dan is offline
Old 07-30-21, 03:30 AM
Kimmo
bike whisperer
Kimmo's Avatar
Pedal strike blows.
Kimmo is offline
Old 07-30-21, 06:35 AM
PeteHski
PeteHski's Avatar
Quoted: 785 Post(s)
Liked 763 Times in 503 Posts
If I understand this correctly, you have been riding with trainers/sneakers on clipless pedals?
If that is true then a good low profile flat pedal will be a big improvement. I use Crank Brothers Stamp pedals, which come in various sizes. Their low profile helps to avoid pedal strikes. I haven’t had a problem with that but only use them on my mtb.
PeteHski is offline
Likes For PeteHski:
Old 07-30-21, 11:03 AM
chaadster
Thread Killer
Gold would be hot, they’re probably lightweight, and those don’t look too big, either. If you don’t want toe clips, those are likely great!
Old 07-30-21, 09:34 PM
cycling2012
Quoted: 67 Post(s)
Toe clips will increase the weight of my bike?
Old 07-30-21, 09:41 PM
Kimmo
bike whisperer
Kimmo's Avatar
Any half-decent toeclip pedals will be smaller than a typical set of flats, so no, not really.
Kimmo is offline
Old 07-31-21, 02:12 AM
chaadster
Thread Killer
Well, yeah…all else being equal, specifically if the pedals are equal weight.
Toe clips and straps don’t weigh much, but if weight is your concern, you’ll want to compare options carefully.
For example, you can get flat pedals, like Xpedo TRVS 5, which weigh 232g but don’t take a toe clip, or you could get a toe clip compatible flat like the MKS Cygma which weighs 240g and then add probably 30g - 60g/pedal in clips and straps.
So yes, toe clips add weight of course, but pedals have diverse weights, so you just have to look at each model and see. The MKS GR10 I posted earlier are not lightweights at 340g.
The other things you need to do is consider whether foot retention is worth having and consider how important weight is. If you’ve been riding around on clipless pedals without being clipped in, I’m pretty sure any flat pedal, with or without toe clips, will be a big improvement in comfort, stability, security and performance irrespective of weight.
