Removing Handlebar Bold
This seems a daft question to ask but I am having a real problem removing the handlebars from a bike. The bolt that clamps the handlebars in place has a round head. When I turn the nut clamping it together the round head, or bolt, turns as well. I thought maybe use plyers to hold it in place but I am worried I will mark the bolt head.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Photos.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
The nut is probably fused to the bolt threads. Try dripping a penetrating oil (like PB Blaster) into the nut and letting it sit for awhile. You might end up scoring the bolt head anyway, but it shouldn't be hard to find a replacement if you do.
Bikes: lots
Liked 2,932 Times
Usually those bolts are 'keyed' but on something like that (don't take this the wrong way, but 'cheap') it probably isn't. As Rolla posted it's probably corroded and stuck. I would grab that with my channel locks and not worry a bit about messing it up. If it bothers you spend the .50 cents and replace it with an allen head cap screw.
Likes For cxwrench:
Makes sense and much as I thought. No offence taken with the cheap bike. I picked a few bikes up for free to rebuild. I thought I'd learn on some throw-away bikes rather than something decent.
Many thanks for the advice.
Likes For Rob123:
Quoted: 980 Post(s)
Liked 580 Times
Looks like the bolt is accessible to the use of a hacksaw blade as an alternative.
Likes For sweeks:
Quoted: 6178 Post(s)
Liked 4,795 Times
The head looks high enough to easily get a pair of channel locks or vice grips on it. They'll probably leave marks, but if you intend to try and re-use the bolt, then wrap a piece of leather from an old belt or something similar around it first.
Likes For Iride01:
