Looking for info/advice on using a rando bag
Sunshine
Quoted: 10963 Post(s)
Liked 7,490 Times
I have considered buying a large rando bag for a the last couple years, but held off because the pandemic killed 90% of the reason I wanted the setup which was to commute to work, and work is currently a few steps away.
This would go on a modern steel Black Mountain Monstercross frame that I turned into a commute/tour/whatever bike. It has bar end shifters with cables running under the tape, cantilever brakes with the front cable stop in the fork, and a Jandd Extreme front rack.
I would like to use the Jandd rack as a platform and just add a decaleur to the headset spacers.
The Restrap Rando bag's attachment tech is super cool, but it requires some goofy cross bars to be permanently attached to my rack which isnt a great look or convenient.
Ive also looked at a 15L Swift Merlin(used to be Ozette 2) bag and the Acorn Tall.
QUESTIONS-
- Are there any large bags that are more convenient than others to attach and remove or are most all bags about the same amount of fuss when it comes to attaching and removing?
- How vital is a tombstone? The Jandd front rack doesnt have one. Im pretty sure if a tombstone is mandatory, Ill just strap a dry bag to the top of the front rack and call it good, or switch to my rear rack and run a pannier bag. Either of those options are free and simple to attach/remove gear.
- If this is doable, am I missing anything besides a decaleur bracket for the setup?
QUESTIONS-
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
As I understand it, the weight of the bag needs to be supported by a platform of some sort, i.e. a rack although I've seen a strong fender used. The decauller is there to stabilize and secure the top of the bag. I've run a couple french style handlebar bag with a variety of front racks and either a ready made decauller or a non-removable one I rigged up out of a strong old reflector bracket.
I haven't kept up with all the modern bags, but to use a decauller you'll likely have to drill/poke holes in it to attach it. My old LaFuma has a leather strip to help provide some durability where the bolts go through.
Quoted: 5888 Post(s)
Liked 3,471 Times
That's a long rack. You could just pick up a Jandd duffel rack pack if has enough volume for you:
https://www.jandd.com/detail.asp?PRODUCT_ID=FDRP
Sunshine
Liked 7,490 Times
thanks!
Quoted: 3810 Post(s)
Liked 6,692 Times
For my commuting needs, I went with a custom bag from WaxWing and a custom decaleur and rack from @gugie.
Likes For nlerner:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4681 Post(s)
Liked 5,799 Times
QUESTIONS-
QUESTIONS-
Likes For gugie:
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
How much do you plan to carry?
I try to keep my cargo to a minimum for commuting, so I've found a small handlebar or trunk bag is sufficient unless I need to carry a laptop. If I need to carry my laptop, I generally resort to a trunk bag with fold out pannier-style pockets. Otherwise, any rando bag smaller than that portable house @nlerner has strapped to the front of his bike is likely to be too small.
For just a lunch, clean shirt, tools, and a tube or so, I can get away with a small bag like this:
I use that one with a VO decaleur and a Nitto rack. I've managed to eject it once on a rough gravel road when I wasn't using the tombstone. This bag didn't come with a loop for a tombstone, so I fashioned one out of velcro, which comes in handy because the Nitto tombstone doesn't leave room for a traditional slip-over attachment with the size bike I ride.
On paved roads, you're probably not going to eject the bag, but the VO decaleur has a reputation for failing, so if you're going to use one like that you may choose to use the tombstone to minimize stress on the decaleur.
For anything approaching actual rando use, you'll obviously want a significantly bigger bag. In that case, The one bike I have equipped for that type of use has a custom rack and decaleur from @gugie. I use it with a VO bag, which is quite floppy even with the tombstone loop deployed.
This is pretty easy to take on and off the bike.
My Bikes
My Bikes
Sunshine
Liked 7,490 Times
Waxwing Bags sells RaClips which would help eliminate that.
Front bags are basically always a hack(except for when custom designed to the frame and rack), but those two bits of tech together are really slick and make the setup more integrated looking.
thanks for the info!
Liked 6,692 Times
RaClips plus the Dock-It system is a really sweet setup!
For more rando-type riding, I go with smaller bags. I just got a new compact rando bag from Acorn that fits to a front rack without decaleur. It’s really smartly designed:
https://www.acornbags.com/collection...31410202804358
Quoted: 525 Post(s)
Liked 931 Times
Is it an optical illusion or am I just really high? That is the largest handlebar bag I've ever seen. It looks big enough to haul pony kegs.
Likes For Dylansbob:
Liked 6,692 Times
Hah! Well, I can’t speak to how high you are, but I do think the camera angle makes the bag seem bigger than it actually is. FWIW, it did not make Dave Cain’s top four biggest bags he’s ever made: https://www.waxwingbagco.com/blog
Likes For nlerner:
Quoted: 753 Post(s)
Liked 737 Times
Couple things I've read that might be relevant. The Black Mountain Monstercross is a mid trail bike that runs to high trail with large diameter tires. I run a large Jandd bar bag on a a second lower faux handle bar mount on a high trail bike. Its not great with any kind of load. I have it as low as possible with out cutting into my headlights beam, which is mounted on the fork crown. Moving down to a front rack would probably be an improvement and let the light be mount off the rack. On the Jandd racks, there are two versions, the standard and I think the "extreme". The standard might not have clearance to go over fat 700c tires and fenders, and the extreme might raise your bag unnecessarily.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,699 Times
I have an old Acorn "Boxy Rando Bag" from before they had different sizes. If you would have asked me back then, I would have chosen a bigger bag. However, having this bag for several years, I can get what I need in it- I have a tendency to pack way too much stuff- the size keeps it down some. I also have a larger saddle bag and panniers- so if I do need to bring big stuff- I can bring a whole change of clothes- which wouldn't fit in a front bag anyway. My bag is secured by the strings to the bars and velcro straps on the bottom- the 'tombstone' on my racks don't work with this bag. While I think I'd like something a little more stable and secure and less kludge-y- it's really been fine.
IMG_2377 by Dave The Golden Boy, on Flickr
IMG_1703 by Dave The Golden Boy, on Flickr
New Hat by Dave The Golden Boy, on Flickr
Commence to jigglin’ huh?!?!
Sunshine
Liked 7,490 Times
The rack is the extreme version. It clears large tires and fenders fine.
Having weight so high up is a possible concern I've thought about, but figure it's an experience worth trying.
Thank you all for sharing your options here! In my opinion, you guys didn't mention the most important part, you need sections inside, as many as possible, so I recommend you get a bag with multiple sections inside, so you will be able to group up your food and other items at the proper area, and they didn't shuffle between eachother during your cycling.
Disraeli Gears
Love that build, though!
And, what in the heck is that contraption behind the bike?
Liked 6,692 Times
The object in the background is some funky sculpture my mother-in-law bought many years back. It's sort of fallen apart and just lives against the fence there. Keeps the riff-raff away, i suppose.
The top of a handlebar bag used to attach to the handlebars, one attachment on each side of the bag. Not only would this provide lateral stability to the bag (which were quite heavy when on camping trips), this attachment method also prevented the bag from falling/sagging downward.
In picking a bag, be sure it can hold a full-sized notebook, a laptop maybe even a loose leaf binder. If any of those need to be carried and have to be put in the bag spanning the diagonal of the bag, it really limits the utility of the bag. If you cannot close the bag with those inside, it really limits the utility of the bag. If they don't fit at all, you have the wrong bag.
Friendship is Magic
Bikes: old ones
Quoted: 26418 Post(s)
Liked 10,380 Times
That’s what I have on the house-sized bag shown above. Super stable, and really easy to get on and off the bike.
The old Cannondale QR bar bags are great, but you can only find them used now. They came in a couple of sizes, in the QR attachment models, but they are usually overpriced on e-bay.
But I much prefer these bags with some sort of internal stiffening to the ones that require a separate wire support, which often necessitates some kind of additional lower support to keep them from bounding around. None of them are as big as those honking old style front bags, that you see resting on front racks.
Cznnondale bar bag
Topeak bar bag
Same Topeak bar bag, different mount.
Not lost wanderer.
Quoted: 885 Post(s)
Liked 990 Times
I went with a bit of a different method than nlerner, I wanted to keep some stuff away from fluids or food. I wanted a bag to keep some stuff in like my camera or first aid kit. Tools and flat repair stuff is in the tool roll.
The bags are Acorn; compact rando, tool roll and a now discontinued trunk bag. Racks are part of the gugieficatizion I had done earlier.
Tool roll, love these as they are quite sturdy and hold a lot of stuff.
Side load trunk bag. Great bag holds the right amount on the back.
The compact rando bag
Sunshine
Liked 7,490 Times
I ended up just getting a Wald 139 basket, zipping it to my front rack, and using a Swift Motherloaf bag that was on deep discount. Overall- pretty inexpensive solution that works.
I love the setup, the steering is fine even though its a large bag, and its really simple. The bag's versatility is great as we have used it for grocery runs and library books, in addition to carrying my stuff for work.
The Wald 139 rack is huge, but the 137 isnt large enough as I need to fit a 15" laptop. If Wald made a 138 basket that'd be super.
Likes For mstateglfr:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3887 Post(s)
Liked 6,482 Times
Likes For SurferRosa:
