Weird dent in fork blade. Is it toast?
Quoted: 753 Post(s)
Liked 737 Times
I brought home another basketcase, this time a Schwinn Passage.
I knew it had some major problems, but I was only after the frame. When I started cleaning it up I found this dent in the back of the fork blade. It looks like some one pinched clay and left a mark with their thumbnail.
I have a fork from a similar vintage touring bike I can use, but I was wondering If this fork really needs to be condemned, and if there where any guesses as to what left this kind of mark.
I cant get a good closeup with my phone and I was edge lighting the dent with a flashlight, so this is worse than it looks in person. The opposite rust patch is part of the "pinch" and the blade has been left slightly narrower.
Quoted: 4199 Post(s)
Liked 3,851 Times
I guess a steel fork blade failure mode would be slow enough, due to this type of stress riser and cross section shape deformation, that someone who was clued in could monitor daily to avoid the worst case scenario. Will this fork be used by said person? Andy
AndrewRStewart
AndrewRStewart
Quoted: 753 Post(s)
Liked 737 Times
Its not something I would pass along to another rider. At first I thought it was damage from a cutting disk, from someone cutting a chain, but then I saw the pinch. I think it will end up in the destructive testing pile. I have wondered if filling defects like this with brass has any effect on a stress riser like this.
Randomhead
Liked 3,694 Times
I couldn't make myself ride that. That's just the way I am.
My criteria is if I know for sure there is no reason to suspect it would break. In this case I couldn't say that.
Quoted: 321 Post(s)
Liked 263 Times
As for theories about how it happened, maybe there was a light bracket or something on there with a poorly-designed clip that was very enthusiastically tightened by somebody. If it was on the frame nothing to worry about but caution is warranted when it comes to forks. Would probably be OK but would you want to take that risk? I think these Schwinns are just mild steel so could easily be repaired.
Quoted: 753 Post(s)
Liked 737 Times
Quoted: 321 Post(s)
Liked 263 Times
Hi-Ten is basically mild steel, so you could just weld it-- you can weld Cromoly obviously as well but you have to think about heat cycles and things a bit more, and because it's thinner you really want to use a TIG. This fork is probably thick enough you could just buzz it with a MIG-- obviously clean the area up first.
Quoted: 753 Post(s)
Liked 737 Times
Quoted: 321 Post(s)
Liked 263 Times
That's interesting. So physically filling the dent with a weld, and the heat penetration, would improve the structural integrity? That's interesting idea, as if the dent/notch was filled, the slight flattening of the fork blade would be very hard to see under paint. the idea of an "invisible repair" is tempting, but feels a little sketchy at the same time.
Likes For guy153:
Quoted: 753 Post(s)
Liked 737 Times
I pulled the fork and its a Tange "51" . That makes me feel better about the idea of replacing it, as it was not "made in the USA" like the Tenex frame.
I will give the mig welding a try though. There is a local "wizard" class welder and I can add this to the collection of small repairs I need to take over.
Quoted: 18372 Post(s)
Liked 4,507 Times
TIG welding?
Randomhead
Liked 3,694 Times
Yes, OP would want it to be TIG welded
Quoted: 753 Post(s)
Liked 737 Times
Tig welding. Noted, thanks.
Quoted: 753 Post(s)
Liked 737 Times
Likes For bark_eater:
