Addiction 2022.1
#6001
Quoted: 10060 Post(s)
Liked 5,040 Times
Real life, actual, on the road crit? You're braver than I am.
Sorry about the brake rub. I already gave you the only advice I had. I have almost exactly the opposite problem - long free stroke. It's really jarring going from my rim brake bikes to the disk bike, especially because I like to keep my pads really close to the rim.
Real road crit. It’s at Langley speedway, so literally around a big circle.
#6002
Quoted: 9525 Post(s)
Liked 6,267 Times
Most of my morning 20ish mile rides are in the 700-1000 range depending on the route. If I tried hard I could probably double that, but the route would be a bunch of up and down parallel roads.
gotta do at least 30 to get decent elevation just because of the distance to get to the bigger hills.
There is one local stretch that has some better rollers, but its been torn up for resurfacing. The work recently finished, so I'm anxious to get back on it. Weather has not been cooperating though when I've been in town. New, smooth asphalt should be nice.
#6003
Klaatu..Verata..Necktie?
Quoted: 10244 Post(s)
Liked 11,596 Times
That's probably safer than downtown or office park crit. Fewer potholes, no hard, sharp curbs, no streetlight poles to run into.
#6004
Liked 5,040 Times
#6005
Liked 6,267 Times
#6006
Fat n slow
Quoted: 3229 Post(s)
Liked 2,034 Times
Same here re parallel roads. There are times I'll ride in circles just to get some up hill segments in.
My favorite is about 1000 feet over 2.3 miles. It’s pretty fun
#6007
Liked 5,040 Times
#6008
Quoted: 8185 Post(s)
Liked 8,844 Times
Likes For big john:
#6009
VFL For Life
Bikes: Velo Volmobile
Quoted: 28433 Post(s)
Liked 1,831 Times
A Velo Vol office park crit would be epic.
#6010
Liked 8,844 Times
Likes For big john:
#6011
VFL For Life
Liked 1,831 Times
#6013
Liked 6,267 Times
#6014
Mostly Harmless
Bikes: Have two wheels
Quoted: 13640 Post(s)
Liked 4,449 Times
#6015
Liked 8,844 Times
Passed these rocks today.
The area looks like this except today there was a bit of snow higher up.
Anyway just 3 of us did the ride and it was nice.
Likes For big john:
#6016
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12635 Post(s)
Liked 7,528 Times
Ladies' gym pic of the day. Check out that shag carpet!
Likes For LesterOfPuppets:
#6017
Liked 6,267 Times
#6018
Bikes: 79 Trek 930 is back on the road, 80 Trek 414, 84 Schwinn Letour Luxe,87 Schwinn Prelude, 92 Schwinn Paramount PDG 5
Quoted: 3076 Post(s)
Liked 1,784 Times
#6019
Quoted: 20791 Post(s)
Liked 9,436 Times
If you've tried all of that, and you've done a semi-competent job of it, then I'd be looking for a bit of rotor runout/warp. If you spin the wheel in the stand, will the rotor audibly kiss the pads? If so, do your best to locate that high spot and then give it a little tweak with a rotor truing lever or with an adjustable wrench. Be gentle if they're Shimano IceTech - they don't need a lot of persuading.
#6020
Liked 11,596 Times
I re-did the Half Monty tonight. Last time I did it, it gave me an FTP of 228, which is 28w less than I got from the last Ramp Test I did on Zwift, which was disappointing. So, last night I did a workout called "Primers", which is supposed to be good for big efforts the next day. And tonight I did "Igniter" as a warmup. Of course, this was all based on a FTP of 228, so they were easier than they would have been.
The Half Monty consists of a Ramp done in Erg Mode, and then a 20 minute sub-threshold ride done in "level" mode where you have an HR target to maintain.
So, comparing last week and this week, I went one step farther on the Ramp. On the 20 minute sub-threshold effort, the HR targets were the same as last week, but I ended up putting out about 26 more watts for 20 minutes to maintain it. The overall result was that my new FTP is 250w, 22 watts higher than last week and only about 6 w less than I'd done on Zwift. When I looked at HR and power, it was interesting - my max HR was just the same, but I hit it at 346W instead of 333. And as I said, I had to put out 26 more average w to maintain exactly the same average HR.
It does make me wonder. I doubt I've magically grown 22 w worth of FTP in 7 days, but higher power at the same HR, compared with 7 days ago is intriguing.
Likes For genejockey:
#6021
Liked 11,596 Times
#6022
he said member
Bikes: yes please
Quoted: 2754 Post(s)
Liked 1,929 Times
Officially signed up for my first crit today. Already nervous about it.
I cannot get my front disc on the cervelo to stop rubbing. I have tried everything. I even took the pads out a pressed in the pistons. I’ve tried loosening the caliper and re centering it, I don’t know what else to do.
Pads prolly need to be replaced soon too.
#6023
Quoted: 18319 Post(s)
Liked 15,288 Times
Wordle to your mother.
Wordle 243 3/6
Wordle 243 3/6
#6024
Liked 15,288 Times
Happy National Cabbage Day!
#6025
Liked 5,040 Times
replace the pads and measure the rotor thickness. Pistons might be out further than they can compensate for, so they kinda hang out there in space. That's why there's rubbing. Excessively worn rotor will present the same. Pistons have to move so far out to make contact they can't retract enough to clear the rotor.
This makes sense. And both the front and the back are doing it, so I wonder if they are both just worn. 8891 miles on them.
I was hoping to get new tires before the race but brakes are kind of important.
