Book Review - How to build a Bike in a Weekend
I brought this book home recently from the library out of curiosity.
After cursory skimming, it seems a reasonable reference for someone wanting to cobble together a bike from parts gathered from here and there. The book is nicely illustrated (no photos) in a shaded line art manner. I noticed that some build operations require specific bike tools (like a headset cup press and fork race setter) but the author uses his hands for tensioning the rear derailleur cable rather than use a third hand tool, which is about a $10-15 tool compared to the others which are much more expensive.
I'll add more here as time progresses if thread readers want to hear more about it.
Quoted: 2026 Post(s)
Liked 1,095 Times
Some bike tools can't be improvised but others, specifically a headset press and crown race setter, can be. Also, some headsets (e.g. Velo Orange's Gran Cru) come with a "split" crown race that can be installed by hand with no tools.
Likes For HillRider:
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,201 Times
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 1,095 Times
The last bike I built up from a bare frame took me about three months from the time the frame set arrived at my house in the fall of 2020. About three days was waiting for Frame Saver I applied to the frame and fork to dry. Then about 10 days for the parts I ordered to arrive, about two more months for the remaining parts to arrive (thanks Covid) and maybe four hours of actual work to put the whole thing together.
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
Sometimes things are just so enjoyable, you want to stretch out the time you do them. I personally spend years building up bikes.
Likes For ThermionicScott:
Bikes: yes, i have one
Quoted: 1136 Post(s)
Liked 1,179 Times
Jeeze! How can people work that slow?! This topic came up on the Classic and Vintage so I decided to time my build. 2:07 (h:m) to strip parts from one frame and swap them over to the other frame.
Likes For Camilo:
Liked 1,095 Times
I've built up a couple of dozen new bikes and a lot more if I include the ones I rebuild after complete disassembly for cleaning and overhaul. I still take a long time to be sure everything is right as I go along. I'm not on the clock and I enjoy the work. Why hurry?
Liked 4,201 Times
Stuart Black
Stuart Black
Quoted: 321 Post(s)
Liked 263 Times
Likes For guy153:
Bikes: More bikes than riders
Quoted: 1443 Post(s)
Liked 759 Times
I never have sped through a bike build. The nuts and bolts, the ball bearings, the grease in all the right spots...the sheer simplicity and efficiency of the machine is artful to me and I relish creating it as much as I enjoy using it. Interacting with the mechanics of the bike is as theraputic to me as actually riding it.
The good part about bicycles is there's not one correct way to do it, especially if you're doing it for recreation or pleasure.
Likes For hokiefyd:
Liked 4,201 Times
Depends how many curveballs you run into along the way: unanticipated incompatibilities between parts, things that are stuck or turn out to be knackered. You might need to mess around fabricobbling spacers or, in the worst case, waiting for new parts. But for someone who's never done it before a weekend is quite fast I think.
My post was more tongue in cheek but I’ve instructed lots of people on putting together bikes and a weekend (or weeks or months) to do a build is excessive. Oft times, I think that analysis paralysis in bike building is a larger problem than actually doing the work.
Stuart Black
Stuart Black
Quoted: 321 Post(s)
Liked 263 Times
Go look at the link. I had to chase the threads of the bike. Not shown in the post: I discovered that the bottom bracket was a rear 73mm rather than a 68mm. The seatpost on the two bikes are different sizes.
I once built a bike with a new frame (I had made) and all new parts (in boxes) in one go because the person it was for wanted to join in and see how everything went together.
I had already built the wheels. But this was everything else including cutting the fork steerer.
It took probably about four or five hours. Was more work than I was expecting actually. This was a 1x road bike.
Recently I rebuilt my touring bike with a new frame. Probably took longer, but over a few days, because I wanted to clean everything up properly while it was off the bike.
Yes weeks and months is excessive. You should be able to build a car in that time! I think sometimes people are taking their time getting the exact parts they want from eBay etc.
Liked 1,179 Times
Likes For spelger:
Liked 4,201 Times
External bearings. Just removed spacers.
Stuart Black
Stuart Black
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
For a new bike, with all new parts? A weekend (call it two 8-hour days) seems like an awful lot of time, unless it’s your very first time in the garage, or you’re doing something like lacing the wheels from scratch.
Truthfully, few of us enjoy the privilege of full days of uninterrupted shop time (particularly at home) so the actual time spent turning wrenches is only a fraction of the ‘clock time’ start-to-finish.
The last R&R I did took about 3 hours per bike; stripping down the donor bike, swapping everything to the ‘keeper’ then building up the donor frame with the take-off parts to get it out the door. It wasn’t a straight-through jam, though; a couple hours after work over a couple-three days.
The Raleigh C-40 adaptive bike I built with my son was about 8 hours total; done a hour or two at a time in the evening after dinner (and homework) over a week; probably 3 hours of actual assembly; the rest was repacking and truing the wheels and cosmetic stuff like paint correction and polishing all the aluminum bits.
Doing a restoration/rebuild on an old and /or neglected bike is a whole other animal. My 76 Bridgestone was at least 40 hours of work, but it had been abandoned for about 20 years, and I rebuilt or refinished almost every single piece of it; it’s about 90% of its original parts
Likes For Ironfish653:
Liked 4,201 Times
I don’t have a road crankset. I can’t see any reason to put a road crank on a mountain bike frame any way. I’ve put mountain cranks on road bikes but not the other way around.
Stuart Black
Stuart Black
Space Ghost
Bikes: Bridgestone, Fuji, Iro, Jamis, Gary Fisher, GT, Scott, Specialized and more
Quoted: 292 Post(s)
Liked 412 Times
Sometimes a build will take me a day and other times it will be years and counting.
Liked 4,201 Times
I also disagree that 90s mountain bike frames make “ideal” touring bikes. The geometry is all wrong. A mid80s might work but they have issues as well. By the 90s, mountain bikes had shortened significantly making them poor touring bikes.
Stuart Black
Stuart Black
Quoted: 321 Post(s)
Liked 263 Times
Go look at the link. I was making a mountain bike for my tiny wife.
In the section on choosing a frame by material construction, the author makes a claim that all Aluminum frames will eventually start to crack and fail with normal use (accelerate that demise with extra loading, hard riding etc). He also says that steel will last forever, providing it doesn't rust.
"Sadly, an aluminum bike will always be mortal"
So can be steel though! I've gone through three steel frames in the last decade, unfortunately.
I think the statements he makes here are very generalized.
Quoted: 321 Post(s)
Liked 263 Times
Likes For guy153:
Quoted: 321 Post(s)
Liked 263 Times
Then many hours working on the paint, with more to come!
