MAFAC Raid Brakes - Braze On
Bikes: '72 Peugeot PX-10, '09 A. Homer Hilsen, '78 Masi Gran Crit, '79 Echelon Spectra
Quoted: 102 Post(s)
Liked 159 Times
***SOLD***
Hello!
Up for sale is a set of MAFAC Raid braze-on brakes. I manage to misplace three of the pivot posts but they are available from Rene Herse for $14/pair. Overall, a very clean set! Bummed I can’t use them. Not pictured are the brass shim washers. They will come with the set though.
$100/shipped
____________
Hello!
$100/shipped
____________
Quoted: 786 Post(s)
Liked 517 Times
Will these attach to a standard Mafac (Racer, Comp, etc.) backing plate, or are they made to be braze-on only?
Bikes: Cannondale Synapse, LeMond Victoire, Bianchi Campione d'Italia, Kona Hei Hei, Ritchey Ultra, Schwinn "Paramount" PDG, '83 Trek 640
Quoted: 267 Post(s)
Liked 324 Times
I'm interested, but don't have an immediate use. I'd just be stockpiling them for the future. So if anyone here needs them more immediately, I'll wait a week or two.
Likes For mhespenheide:
Quoted: 1105 Post(s)
Liked 1,326 Times
The two cable-ends of the arms will be farther apart from each other, so the straddle length might need adjusting, but the mechanical advantage otherwise remains the same; I doubt the arms would interfere with each other enough (if at all) to bother; the only remaining issue would be that of how much reach provided by the braze-on post location can be replaced with that of the bridge - of which fortunately at least two sizes are available.
Quoted: 102 Post(s)
Liked 159 Times
I don't see why they wouldn't, unless the bushing doesn't fit.
Although this might be possible anyone attempting to do this needs to keep in mind that using a Racer backplate will reduce tire clearance because the Racer posts are 12mm closer together than the Raid posts.
Likes For BertoBerg:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4677 Post(s)
Liked 5,790 Times
If you need a backing plate for these, contact me.
BTW, those backing plates that Rene Herse sells are from my Atelier. Jan ran out, I had a boatload of them from the centerpull braze-on conversions I do. I should still have a few.
These are what I sent up to Seattle:
Traded Jan for a bunch of centerpull braze on posts, so it was win-win
Quoted: 102 Post(s)
Liked 159 Times
Check out www.djcatnap.com for articles on vintage Japanese & French bicycle restorations, components and history.
Likes For Catnap:
