Stiffer mtb shoes - recommendations?
Old 11-02-21, 08:00 AM
MinnMan
MinnMan's Avatar
Bikes: 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 3418 Post(s)
Liked 2,377 Times in 1,443 Posts
I know MTB shoes have more flex than road shoes by design - that's what makes them better for walking and hike-a-bike.
I periodically suffer from plantar fasciitis , and when I do, I avoid my mtb shoes - they aggravate the PA much more than stiffer road shoes. (yes, I have properly fitting insoles in all of them - that's not the issue).
My current MTB shoes are an inexpensive set of Giros.
I've considered just putting 2-bolt cleats on a set of road shoes. I don't actually do any mountain biking, but I use mtb pedals and shoes for gravel. For some gravel, road shoes and even road pedals are just fine. But other times, I appreciate having mtb shoes.
Maybe there are some MTB shoes that run on the stiff side?
Any recommendations? Ideally in the range of $150-$200?
MinnMan is offline
Old 11-02-21, 08:34 AM
prj71
Quoted: 2038 Post(s)
Liked 627 Times in 413 Posts
https://www.specialized.com/pe/en/2f...=300582-187385
prj71 is offline
Old 11-02-21, 08:39 AM
Flatforkcrown
Flatforkcrown's Avatar
Bikes: N+1
Quoted: 92 Post(s)
Liked 391 Times in 154 Posts
https://www.adidas.com/us/the-gravel...es/FZ5446.html
I have these and like them.
Flatforkcrown is offline
Old 11-02-21, 11:46 AM
Kapusta
Cyclochondriac
Kapusta's Avatar
Bikes: Soma Fog Cutter, Surly Wednesday, Turner 5-Spot, Canfielld Tilt
Quoted: 2344 Post(s)
Liked 1,979 Times in 1,101 Posts
Are you looking for clipless MTB shoes? Pretty much any higher end shoe designed for XC racing is going to be pretty much as stiff as a road shoe.
Kapusta is offline
Old 11-02-21, 12:33 PM
MinnMan
MinnMan's Avatar
Yes. Any specific suggestions?
MinnMan is offline
Likes For MinnMan:
Old 11-02-21, 12:48 PM
caloso
caloso's Avatar
Quoted: 2864 Post(s)
Liked 2,843 Times in 1,310 Posts
I have some Specialized S-Works mtb shoes and they are as stiff as their road version.
caloso is offline
Old 11-02-21, 12:49 PM
Kapusta
Cyclochondriac
Kapusta's Avatar
No, I have not shopped for that kind of shoe recently. But really, any shoe geared towards XC racing is likely to fit that bill. What you are looking for is not at all uncommon.
I assume you are going to need to try on a shoe to see if it fits well, so you can verify its stiffness then.
Kapusta is offline
Old 11-03-21, 02:26 PM
1xGuy
I wear the Giro Cylinder shoe, and have for a couple years - is a pretty good balance of weight, stiffness and you can still hike it some too if needed...but definitely an XC style shoe
Downside is that the uppers are part mesh so they don't insulate well or keep your feet dry in wet conditions - so may be more a summer shoe in your neck of the woods?
I know you said you ride Giros but not sure if these are a step up in stiffness or more of what you are looking for...but I will look for another pair when they wear out
New here so can't attach a link, but they are easy to find
1xGuy is offline
Old 11-03-21, 02:36 PM
scottfsmith
I like bike
scottfsmith's Avatar
Bikes: Roubaix Comp 2020
Quoted: 174 Post(s)
Liked 190 Times in 123 Posts
I have Fizik Infinito X1's, the MTB version of the Infinito R1. Yet another lightweight, stiff MTB shoe to try. I only got them because there was a cheap lightly used pair available so I didn't do a lot of comparing. Still, I have been very happy with them.
scottfsmith is offline
Old 11-06-21, 01:57 PM
Calsun
Quoted: 186 Post(s)
Liked 102 Times in 81 Posts
The Shimano ME5 mountain bike shoe is quite stiff and has good trip around the recessed cleat are that makes them safe for walking around when off the bike. In a traditional road bike shoe I love my new Giro Cadet shoes. These are both good for my average width feet. I bought 10 pairs and returned 8 pairs. Even with the Shimano ME5 shoes their E45 was the size of a E44 with any other shoe.
Calsun is offline
Old 11-17-21, 09:23 PM
roskobosko
Quoted: 36 Post(s)
Liked 6 Times in 6 Posts
I went from Giro Jackets to Five Ten Freerider Pros and it was a huge improvement for me, stiffer, more support and way more traction, a much stickier sole compound that keeps them from slipping. Some may not like that but it works for me.
roskobosko is offline
Old 11-29-21, 10:46 AM
bmwpowere36m3
Quoted: 24 Post(s)
Liked 8 Times in 8 Posts
Shimano RX8 or Specialized S-Works Recon... currently using the RX8's. I have wide feet, so these fit amazing and super stiff. I can ride my gravel bike 4+ hrs with no discomfort. Downside it cost, but the quality and fit are top-notch.
bmwpowere36m3 is offline
Old 12-08-21, 03:38 PM
Symox
Bikes: '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 258 Post(s)
Liked 153 Times in 95 Posts
You can try replacing the footbeds with something stiffer like from Superfeet
Might be a cheaper solution
Symox is offline
Old 12-18-21, 08:58 AM
scubaman
Quoted: 32 Post(s)
Liked 67 Times in 36 Posts
Bont cycling shoes - road and mountain - have completely rigid (and heat-moldable) soles.
scubaman is offline
