Headlamp for night riding
Quoted: 25 Post(s)
I posted a question for lights to use for night time riding
a lot of you recommended using two lights
so I brought a handle bar mount ( olight 3500) have not used it yet
So now I am thinking of a head lamp instead of a helmet mount. So I can use the headlamp for other things at night
Just wondering if anyone uses a headlamp and how it performs for them
don’t really want to mount a flashlight on my helmet
Quoted: 4479 Post(s)
Liked 2,075 Times
I have used a headlamp in addition to a bar mounted light. but I used it around my neck so that I could see things like my bike computer. didn't keep it on for riding purposes. I think I remember I was able to wear it on my forehead just under my helmet but it didn't fit well enough to keep it there. if your are thinking of strapping it to you helmet, then maybe that would work. but a bike specific model might be better. I know a cpl of my lights came with additional accessories (head strap) so the lights could be used off the bike. those lights have external batteries so I never used them as head lamps. I have a cpl of decent headlamps for use around the car at night etc. it is handy to have one around my neck for seeing things. but I've since rigged a bike specific helmet light. so, can you get something to do both jobs? probably but I can't point you to one. there are lots of options for bike specific helmet lights tho. maybe just get one of those & a headlamp for home use
check out the Magicshine ALLTY Mini Front Bike Light
Cateye Volt series comes with a nice helmet mount.
Headlamp with a strap won't work very well with a helmet.
Quoted: 588 Post(s)
Liked 443 Times
I've seen the hardcore mtb'ers here riding at night on very technical black diamond terrain with a bar mount light, as well as a helmet mount light that connects to a battery that's stored in their backpack. A quick Google found this article: MTB helmet lights
Likes For Riveting:
Bikes: lots
Quoted: 1391 Post(s)
Liked 1,931 Times
The ideal setup is both. I use the brighter light on the handlebar and the less bright light on the helmet mount. You want the bright light lower so it will cast some shadows and you can see the terrain. If you have the brighter light on the helmet it's so high up that it washes out the terrain...you can't see small bumps, rocks, etc as well. The helmet mounted light is for sharp turns and being able to look where your bike isn't pointed.
If I were going to ride w/ only 1 light it would definitely be on the handlebar.
Likes For cxwrench:
Just Pedaling
Quoted: 89 Post(s)
Liked 129 Times
Likes For SpedFast:
OM boy
Bikes: a bunch
Quoted: 262 Post(s)
Liked 254 Times
Been using a Ledlenser for some months - https://www.rei.com/rei-garage/produ...neo6r-headlamp
now in REI outlet...
not really on any trail, just local unilluminated bike path and dirt path... works great for me - good spread of light vs spot,
good, strong light level, even on 'low'. stays put on head, and USB rechargeable, supposed to be waterproof - hasn't really rained much out here...
comes with a chest strap, if you want to use that as alternate - target market is focused on runners group, but seems to work well for any activity.
This will become my primary for backpacking...
Ride On
Yuri
Ride On
Yuri
Quoted: 315 Post(s)
Liked 83 Times
With the ledlenser, are you attaching that whole thing to your helmet? Or how do you wear it? I wish I could find a 200ish lumen neutral white 18650 or other helmet light, to have only one light for nontechnical dirt/gravel paths.
Just Pedaling
Quoted: 89 Post(s)
Liked 129 Times
I'm not saying buy from ebay, but if you put in a 200 lumen headlamp search the possibilities will make your head spin. Find one you think will work and do some research on it, especially what the reviews say. There are lots out there. I had a 180 lumen until my latest crash. I decided to go 600 lumen when I replaced it and what a world of difference. Of course it has lesser settings so you don't need to have it super bright all the time. I also prefer using rechargeable bats over USB on headlights because they seem to last longer than the built in bats. Tail lights I'm the opposite on that. Have great luck with USB recharge tail lights for both brightness and longevity of charge. Good luck
Likes For SpedFast:
OM boy
Bikes: a bunch
Quoted: 262 Post(s)
Liked 254 Times
Before the LEDlenser I used another USB rechargeable head lamp, which has a HUGE headband adjustment !!! Prolly large enough to fit my motorcycle helmet !!! LOL! Also has a good amount of light, last long, very serviceable... I did add some Silicone beads (squeeze tube stuff) on a few spots on the headband, to assure band would not slip, while riding... works fine
Having a hard time finding THAT particular light again on the web... It has both WHite and Red light modes.... and will FIT any helmet size, no problem!
... I now prefer the LEDenser because the light beam is broad and nicely shows good peripheral vision. I can;t seem to 'out-ride' the light beam, at any reasonable speed, except fast road downhill.
I also use a handlebar light along with headlamp...
Thing with the other assortment of these rechargeable headlamps is that some have a shorter band adjustment... I have one which is fine on any head, but would never fit on a helmet...
Here's a pic of the headlamp with the HUGE band adjustment range (you may need to put a few dabs of silcone along inside perimeter of headband to stop movement...)
USB rechargeable headlamp
Hope this helps...
Ride On
Yuri
Likes For cyclezen:
Quoted: 24 Post(s)
Liked 8 Times
Currently OLIGHT RN1500 on handlebar and Outbound Lighting hangover on helmet... waiting for OL to release their detour light or might spring for the EVO handlebar light.
Quoted: 25 Post(s)
Thanks for responding
I brought the olight 3500 1/2 off
briefly tried it tonight (didn’t use it long)
seemed bright
i think I want a light for my peripheral vision also
seemed bright
Likes For LeeG:
Clark W. Griswold
Quoted: 2791 Post(s)
Liked 1,952 Times
Bright isn't the only thing make sure you have something with a useful beam pattern. Certainly these days it is brighter is better and not as much attention is posed to the actual pattern of the beam. You can be bright as hell but if it puts the light in a poor space it won't help you much.
A headlamp for camping probably also is not ideal because it would push your helmet out of the way or maybe not mount as well to it. Having tried in the past I was not happy with the results.
