2x9 upgrade to 1x11 on old Stumpjumper?
Old 01-18-22, 12:06 PM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 2691 Post(s)
Liked 1,502 Times in 982 Posts
Take a moment and consider a couple things
1. 1x and boost create a lot of advantages, but not all of them apply to retrofit. One of the reasons is that it simplifies suspension optimization for anti-squat (against pedal bob) by tying down the front end of the upper chain run. For triples (looks like a 2004 SJ FSR was) they were optimized around the 32 ring. But if you use a 32 front then 32-11 is a pretty low top gear for a 26er. SRAM X1 11 speed used a very cool special cassette and a special hub to get a 10-42 range that's barely appropriate with a 32 front. If you are installing 11-46, or 11-52 12 speed, you do get the range but it's all heavier especially on an old style freehub. For a 26er you will want a 36 ring that might not play so nice for anti squat.
2. Kapusta is referring to the portion of the dropper post that goes within the seat tube. Depending on your frame size you might just not have very much total length. Droppers are also always zero offset so you get to worry about fit at the seat end too.
Genesis 49:16-17
Darth Lefty is offline
Likes For Darth Lefty:
Old 01-18-22, 01:56 PM
Kapusta
Cyclochondriac
Kapusta's Avatar
Bikes: Soma Fog Cutter, Surly Wednesday, Turner 5-Spot, Canfielld Tilt
Quoted: 2344 Post(s)
Liked 1,981 Times in 1,101 Posts
Originally Posted by 3speed View Post
Nah. The road stuff feels better than the mountain stuff. …brifters, that is. The bar ends have too much play and ghost shift. I think they’re their worst product. I’d actually say their brifter groups and bar top shifters(like old school mtb shifters, not trigger shifters) are decent.
You have clearly never used Advent or Advent X. But that does not seem to stop you from voicing a strong opinion about them.
Kapusta is offline
Likes For Kapusta:
Old 01-18-22, 11:36 PM
3speed
Quoted: 362 Post(s)
Liked 28 Times in 22 Posts
Yes, the quote that you used makes it quite clear that I'm not very familiar with their offerings.
It's OK that you like micro**** and I don't. We don't have to like the same things.
3speed is offline
Old 01-18-22, 11:43 PM
3speed
Quoted: 362 Post(s)
Take a moment and consider a couple things2. Kapusta is referring to the portion of the dropper post that goes within the seat tube. Depending on your frame size you might just not have very much total length. Droppers are also always zero offset so you get to worry about fit at the seat end too.
I can't use ~half(maybe more?) of them due to length, but there are still numerous options. It's a large size frame, so maybe not as much of a problem as it would be with a small or medium.
3speed is offline
Old 01-20-22, 12:37 AM
3speed
Quoted: 362 Post(s)
Alright. Here痴 the before. Realized maybe I値l weigh it too, just for fun to see if that changes at all. No idea if it値l go up or down. Maybe up since I知 adding a dropper and beefier tires, but also ditching the triple(though bigger cassette) and shorter stem, so maybe it値l stay close to the same? I値l probably start tearing it down this weekend.
3speed is offline
Likes For 3speed:
Old 01-20-22, 10:36 AM
cyclezen
OM boy
cyclezen's Avatar
Bikes: a bunch
Quoted: 269 Post(s)
Liked 264 Times in 186 Posts
Schweet ! Nice touch with the radiator background ! and old school hardwood floors ! That stuff was Built to Last !!! And still looks/works so nice.
BTW : Those CST Caballeros were the """Schizz """" back in '06 ! I think I still have 2 NOS hanging in my tire stock... Iff'n you're in need... LOL!
yeah noticed that kink in the seattube the other night, when I looked at the '04 stumpy FS online. But it might work with a 100mm dropper - if you have the 'leg' for the seatpost height...
my Epic does have a straight seattube, so I was able to fit a 125 dropper...
same drivetrain as my Epic...
looks like the same fork, and should be able to take a 27.5... makes a huge diff. !!! will be a fun ride when you're done!
Ride On
Yuri
cyclezen is offline
Copyright ゥ 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
