Go Back  Bike Forums > Bike Forums > Framebuilders
put my bike frame in the pizza oven
Framebuilders Thinking about a custom frame? Lugged vs Fillet Brazed. Different Frame materials? Newvex or Pacenti Lugs? why get a custom Road, Mountain, or Track Frame? Got a question about framebuilding? Lets discuss framebuilding at it's finest.
Old 02-11-08, 04:33 PM
thatcher
thatcher's Avatar
at 440 degrees for an hour. trying to level out the steel by uniformly heating n cooling everything at the same temp. useless or great idea?
thatcher is offline
Old 02-11-08, 06:00 PM
veganboyjosh
don't forget the garlic.
that will help with the vampires, too.
veganboyjosh is offline
Old 02-12-08, 10:58 AM
SamHall
good for powdercoating.....not hot enough to make any difference with the steel.
SamHall is offline
Old 02-12-08, 11:57 AM
NoReg
Liked 2 Times in 1 Post
Bad idea. Shouldn't hurt anything structurally, but I think that if anything you will pull it out of alignment. Any time you want to mess with alignment you better have a means of measuring the results.
You are also high enough to oxydize the whole surface which probably just means a little more prep time.
You could powdercoat your own frame in there, I just wouldn't eat the pizza thereafter.
NoReg is offline
Old 02-12-08, 03:43 PM
Creakyknees
ride lots be safe
Creakyknees's Avatar
Quoted: 12 Post(s)
"level out the steel "
Meaning what?
Creakyknees is offline
Old 02-12-08, 05:07 PM
thatcher
thatcher's Avatar
just lower the steel temps evenly. sorry. bad tech talker.
thatcher is offline
Old 02-13-08, 01:22 PM
jackcoke
Electric ovens suck for making pizza so I'm glad you found a good use for them. Wood fired is the only way to go for pizza...imo.
jackcoke is offline
Old 02-14-08, 12:13 PM
testtube
My boss/CEO, a material scientist who used to run a frame building class at the university, did this with his home built frames. I think it had something to do with driving the hydrogen out of the steel, as to the specific purpose of this I am unclear (avoiding hydrogen embrittlement?)
He loves to chat about this stuff so I'll ask him for details and report back...
testtube is offline
Old 02-14-08, 05:56 PM
silent1
Heat treating steel requires much higher temperatures, a little over double of what the pizza oven will do.
silent1 is offline
Old 02-15-08, 11:06 AM
jeffz
Are you trying to accomplish what a cryogenic type process would do? What you are asking sounds more like annealing to me. I don't think I would do it...
jeffz is offline
Old 02-15-08, 03:51 PM
Cassave
Cassave's Avatar
Quoted: 34 Post(s)
Liked 18 Times in 11 Posts
Post bake of 375 F +- 25 F is required after chrome plating of steels at
Rockwell C40 or above to reduce hydrogen embrittlement.
See fed spec QQ-C-320
I can't think of any other reason to do it.
Cassave is offline
Likes For Cassave:
Old 02-15-08, 06:00 PM
jeffz
Does that reduce the hydrogen from the steel or chrome plating?
jeffz is offline
Old 02-15-08, 06:11 PM
testtube
I looked up Hydrogen Embrittlement
The electroplating process can introduce Hydrogen ions into the steel through diffusion from the electroplating bath. The Hydrogen ions will eventually recombine to form the more stable diatomic Hydrogen creating pressure within the steel that may introduce cracking.
The process described by Cassave is used to drive the Hydrogen out of the steel.
I think this is why my boss pizza-ovened his frame as he had electroplated it (I think with Nickel) in leiu of painting it.
testtube is offline
Old 02-28-08, 02:32 PM
physh
Heating to 440 can relieve stress in the frame, but it probably needs to be heated for more than an hour. If there is stress from welding/manufacturing, it could cause the frame to warp.
Heating above 300 degrees is known as tempering, look it up on google, you'll find a lot of information.
physh is offline
Old 03-20-08, 12:29 PM
alecw35
Bikes: Many
hey if my mum was heating it up it would be ok
she always burns pizzas
alecw35 is offline
