tricks to get early Shimano cassette un threaded?
Quoted: 2337 Post(s)
Liked 2,821 Times
I have an early durace 6 speed UG cassette where you need to unscrew the small cog using the double chainwhip approach.
The cog is on TIGHT I used some PB blaster on it
any ideas? tricks?
it may be i need to enlist a helper
any ideas? tricks?
Quoted: 1572 Post(s)
Liked 643 Times
I assume you are aware of the trick of crossing the two chain whips so that you can squeeze them together like a scissors?
Really Old Senior Member
With the PO applied, tap the cog with a small box wrench or similar.
You want to "ring" it so the vibes help suck in the oil by capillary action.
No whacking hard!
Are you trying to orient the chain whips so you can "squeeze" the handles together?
There's always a propane torch to try to heat the cog (without heating anything else) but I'd use that as a last resort.
No whacking hard!
Likes For Bill Kapaun:
Liked 2,821 Times
the squeeze handle is a new one for me....will try that and see if I can find my favorite freeze off
Quoted: 1943 Post(s)
Liked 2,164 Times
I can’t vouch that this will work, but one of my chain whips allows me run 1/4” rope through it. Once I have it wrapped around the tire enough turns to keep it from slipping, and tie it off, it leaves both hands to remove the cog. Maybe add a pipe as an to the chain whip on the first cog for leverage.
I haven’t done this with a cog removal, but use it to remove lockrings with two hands so the tool doesn’t slip out.
John
John
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 675 Post(s)
Liked 741 Times
If you try out the way to hold the whip handles as suggested above, and it's still not coming and you suspect corrosion, try a drop or two of DOT3 brake fluid on the threads, carefully away from any paint. The other day I tried it on a tie rod end on a car after an hour of PB Blaster and MAPP torch heat, and it came right off.
Friendship is Magic
Bikes: old ones
Quoted: 26402 Post(s)
Liked 10,374 Times
...I just took one of these off today. Freeze Off is good, but a small plastic bottle (that is acetone resistant, like the ones that Tri -flow comes in) with a little plastic applicator straw, filled with a 50/50 mix of acetone and ATF, is what I used. Mine jumped right off of there and saluted me.
There is a suggestion for removing rear sprockets here:
https://www.sheldonbrown.com/heroic-repairs.html
