"Consumables?"
#51
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
#52
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
#53
Tragically Ignorant
Liked 9,098 Times
I've certainly heard it used in a lot of contexts throughout my adult life, including to refer to car items like oil and tires, but I think I only heard it applied to bike chains and the like in the last few years.
#54
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
#55
Tragically Ignorant
Liked 9,098 Times
#56
Quoted: 4227 Post(s)
Liked 2,488 Times
Cracks around spoke holes and spokes pulling through isn`t an issue with modern quality rims which were build and tensioned properly...What really wears out aluminum rims are bikes with rim brakes which are ridden a lot during winter when there is a lot of slush, salt and grit on the roads.
#57
climber has-been
Quoted: 3422 Post(s)
Liked 3,559 Times
The failure mode is fatigue cracking.
In fact, anything made of aluminum will eventually fail, if it is stress cycled enough times.
Ride, Rest, Repeat. ROUVY: terrymorse
#58
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 414 Post(s)
Liked 910 Times
The rim failures I read about with regard to being 'consumable' were due to wear on the braking surfaces over time. The reason I said I'd believe it is because my brother said he could see light through a friend's rims once due to such wear. I don't count spokes pulling out as 'wear', but I suppose that is semantics. Handlebar failures caused by sweat is a new one for me, too.
#59
Mad bike riding scientist
Quoted: 6212 Post(s)
Liked 4,211 Times
Stuart Black
Stuart Black
#60
Jet Jockey
My winter bike sees very few miles, but the chain is destroyed by road salt every year. My nice road bike sees many fair-weather miles, and chains last a very long time.
The irritating pedantry of this forum at times is why I visit so infrequently anymore.
Good night...and good luck
#61
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2577 Post(s)
Liked 5,625 Times
I have a set of 1980s Mavic rims with untold thousands of miles on them and they are severely cupped. Don’t use them any more as they are on a bike I seldom ride, but have often wondered what would happen when they got too thin. Fortunately never had to find out. Consumable? Definitely.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
#62
Bikes: lots
Liked 2,932 Times
#63
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Sure, just about anything MIGHT need to be replaced during the typical life of a bike,
But consumable almost certainly WILL need to be replaced.
Likes For Kapusta:
#64
Jet Jockey
On the other hand, before disc brakes became ubiquitous, I saw bikes that saw lots of winter use have the brake surface ground to aluminum paste by the rim brakes grinding them with a wet slurry or salt and sand.
#65
Grupetto Bob
Liked 5,625 Times
I know it’s technically not on the bike, but cycling gloves and shorts are consumables as well.
#66
Bikes: lots
Liked 2,932 Times
It's not that rare. I don't know if you work in a shop or not but I see cracked rims all the time. It's also not always whether or not the wheel was built 'properly'. There are lots of crap rims out there. One of the wheels from this week is on it's 3rd rim, second rebuild.
#67
That's my bike. Only original parts on it from when I bought it new are the frame, spacers on the steerer tube, the stem, and the seatpost. Everything else has been replaced, sometimes more than once (on my third handlebar and fourth set of wheels, for instance).
#68
Grupetto Bob
Liked 5,625 Times
Considering the markup on individual parts, I wonder what is most expensive in the long term; buying a complete bike or doing it your way. (I know not everyone can afford a new bike when the old one gets tired)
#69
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
Depends on where you're starting from, as well as how long a time the component replacements are spread over.
One of my favorite bikes is my 1997 Cannondale F-1000. It was about an $1100 build back in the day, LX/XT, and a lot of period '90s goodies (Ringle, MachineTech) It's has had a number of different bar and stem setups over the years, a couple -three chains and about half a dozen sets of tires. Right now, the shock is showing signs of needing another rebuild, and the rims are starting to show their age.
So I'm looking at spending $500-$700 on the old sled, which won't get me much in a new bike; an equivalent to that old CAAD-3 would run me somewhere in the neighborhood of $1800, which is a much harder pitch to my finance officer.
Now, I don't see, like the post you responded to, the wisdom of taking, say, a 10-year-old Sora bike and doing a full R7000 upgrade and new wheels and all the bits and bobs, when you still end up with a mid-level alloy GIANT.
#70
Jet Jockey
I’m not saying it doesn’t happen. I’ve definitely seen it when friends come to me with their OEM wheels and ask me to fix it…then end up with one of my own builds.
A few years back I was having a heck of a time with the Pacenti rims. Had to be exceedingly careful in the build, or they would definitely develop cracks.
#71
Quoted: 1182 Post(s)
Liked 833 Times
This might look like a 2013 Bianchi Volpe, but it is what is left of my 2006 Volpe pictured below. Every part on the 2006 except the bars, shifters and stem have been replaced, including the frame under warranty. Some components have been replaced multiple times: chains, chainrings, bottom brackets, cassettes, cables, jockey wheels, wheel bearings, saddles, pedals, and water bottle cages.
I've put a lot of miles on Volpes
This was the reason for replacing the headset.
#72
Tragically Ignorant
Liked 9,098 Times
So I take it you don't subscribe to the theory that once the frame is replaced, it's no longer the same bike. I'd be thinking of that as having taken some of the 2006 bike's parts and putting them on a new bike.
I could probably come up with some legal scenario where it would be important whether it was defined as an upgraded old bike vs. a new bike incorporating some old parts, but I think both answers are equally logical.
I like your bike, btw.
#73
Quoted: 2601 Post(s)
Liked 1,925 Times
That said, that's a reasonable case that you're arguing.
Likes For pdlamb:
#74
Tragically Ignorant
Liked 9,098 Times
I figure a bike whose frame is replaced under warranty by the "same" model (yeah, I know it's likely changed in a few years) is the same bike. It's only if I acquire another frame and move the parts over that it becomes a different bike.
It's probably a perspective thing--you may be the only person to whom that particular bike would seem to be the same one because you've used it the same way throughout its entire transition. Someone else would probably think that it's a 2013 bike, not the 2006 bike because they weren't there.
BTW, I'm going to guess that if, hypothetically, you had tried to sell it in 2014, you wouldn't have been telling people it was a 2006 bike, and I think that would be entirely honest and fair to call it a 2013 bike with some 2006 parts on it. I also think it's completely reasonable that for your own purposes, it's really the 2006 bike. I love questions with 2 completely different, plausible answers that are contradictory.
Likes For livedarklions:
#75
Liked 833 Times
I think of it as a new bike, but I liked the old one better. The frame welds were finished much better on the 2006. I have 2 other touring bikes, a Surly LHT and a Cannondale T2, but the Bianchi is still my favorite bike. However, part of the reason for that might have something to do with sentimental value.
Likes For Doug64:
