A Dummy Builds a Lynskey GR300
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 1826 Post(s)
Liked 1,153 Times
I don't really need another bike, but I don't have a dedicated gravel bike, so I thought, why not? If I am being honest with myself, I am pretty darn bad at wrenching. I am thankful that nearly 30 years ago a guy named Lew White taught be basic bike wrenching. He was the perfect mentor fro me. I have built seven bikes in my life. All of them have been flat bar bikes of a mountain or commuter type design. Never have I dealt with drop bar builds or drop bar shifters. This is going to be a first. I have a hunch I'll end up at the local shop getting them to bail me out. I am certain I'll cuss some along the way. But I am excited about what I am going to end up with.
The first of the parts have started rolling in. I managed to apply rim tape to the rims without the need for an emergency room visit, so I am off to a good start. I'll mount the tires in a few minutes.
Likes For Paul Barnard:
Thread Killer
Bikes: '15 Kinesis Racelight 4S, '76 Motebecane Gran Jubilée, '17 Dedacciai Gladiatore2, '12 Breezer Venturi, '09 Dahon Mariner, '12 Mercier Nano, '95 DeKerf Team SL, '19 Tern Rally, ‘21 Breezer Doppler Cafe+, ‘19 T-Lab X3
Quoted: 2091 Post(s)
Liked 1,157 Times
Unfortunately, no badge is awarded for Worked On Drop Bar Shifters for those! Gevenalles earn the same, 40 year old badge as Works On Shifters.
Likes For chaadster:
For The Fun of It
Liked 1,153 Times
Got the Vittoria tires mounted. This is the third set of different Vittorias I have used. They are TIGHT.
Likes For Gravel Rider:
Likes For grubetown:
Likes For kttyrrell:
Sunshine
Quoted: 8266 Post(s)
Liked 5,079 Times
I didnt ask in an earlier thread you started- why do you need to have mechanical disc brakes? I am not criticizing, I just saw you mention it as a must and am curious.
Disco Infiltrator
Quoted: 2768 Post(s)
Liked 1,584 Times
For The Fun of It
Liked 1,153 Times
Simplicity. That and I have them in two applications already, and am very happy with them. Hydraulic brakes have done two things to me that mechs haven't. I have grabbed too much brake and dumped. I have had a brake malfunction that necessitated a shop visit...while I was on vacation. Both are clearly the consequence of my shortcomings, but I don't see myself getting much better at threshold braking or working on hydraulic brakes, so mechs it is.
For The Fun of It
Liked 1,153 Times
I got my SLX 11-42 Cassette in and got it installed. The handlebars arrived today. Things will be at a standstill for a while now until the frame comes in, then I have to wait for GRX derailleurs and cranksets to come in stock. Seems like middle of November is when businesses are expecting them.
Bikes: Fuji Sportif 1.7C, Shogun Metro AT, Jamis Durango SX, Miyata Alumicross, Fuji Special Road Racer, Mongoose ATB, Fuji SST 1.0 Team, Gitane (?), Specialized Rockhopper SS, Univega Gran Turismo, Univega Supra Sport Mixte, Nishiki Tri-A, Diamondback Coil
Quoted: 75 Post(s)
Liked 120 Times
Good luck, and give that bar wrap a try. Most tape these days is pretty forgiving, if you screw up you get do-overs! And as far as the overall build goes, good luck, and don't be so hard on yourself. Just the fact that you appear to be using all new parts (or close to it) is a huge advantage. Most of my builds are 90% soaking, sanding, or scrubbing, 5% assembly, and 5% fiddling to make wildly unrelated components work well together.
Likes For PugRider:
For The Fun of It
Liked 1,153 Times
Sourcing parts for this build has been interesting. I have always been able to score killer deals from various merchant's clearance bins. No such joy anymore! TRP Spyke brakes are hard to find. I picked up the second to the last set an Ebay vendor was showing in stock. 11 speed chains are also very hard to come by. I have located everything but the GRX crankset.
Sunshine
Liked 5,079 Times
good looking blue graphic
Likes For mstateglfr:
For The Fun of It
Liked 1,153 Times
Well, I have screwed this up royally. I finally got the crank in a few minutes ago. It didn't slide into the bottom bracket easily. I had to tap it in. I had installed the spacers in the bottom bracket. It apparently didn't need all three. No big deal, I'll tap the crankset out and remove two. Nope. Crankset will not tap back out. I am throwing in the towel and taking it to the shop. For the life of me I cannot figure out why the Shimano GRX crankset wouldn't slide into the Shimano bottom bracket fairly easily.
Expired Member
Quoted: 2990 Post(s)
Liked 3,836 Times
FWIW, I installed a GRX crank in my old Bianchi a couple of months ago and it was a noticeably tighter fit than any other HT2 I've dealt with. It took more than a tap to seat it. Also, even w/o spacers the spindle length out the NDS seemed marginal. In your situation, I'd secure the frame, protect the end of the crank and give it a substantial whack.
Likes For shelbyfv:
Bikes: 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C being made an all arounder.
Quoted: 186 Post(s)
Liked 275 Times
For The Fun of It
Liked 1,153 Times
Expired Member
Liked 3,836 Times
No spacers. It was a Shimano HT2 68mm bottom bracket. 105 or Ultegra, whichever was available.
