Need Ritchey crank end cap
Old 02-26-22, 07:48 AM
pennpaul
Bikes: Diamondback Haanjo Trail, Fuji Team Road
Quoted: 158 Post(s)
Liked 68 Times in 46 Posts
The non-drive side of my Ritchey crank is missing the black end cap you see on the drive side. The cap is threaded and screws into my crank and has a hole in the middle for the crank bolt.
I haven't had luck on eBay or on the Ritchey website. Any idea where I can one? It's really just cosmetic, but I just want to complete the bike. (The bike isn't this dirty anymore)
pennpaul is offline
Old 02-26-22, 07:53 AM
masi61
masi61's Avatar
Quoted: 924 Post(s)
Liked 283 Times in 199 Posts
https://www.ebay.com/itm/Mounting-Bo...-127632-2357-0
Like this?
i can’t tell if your Ritchey crank is square taper or Octalink or Isis. I’m assuming square taper?
masi61 is offline
Old 02-26-22, 07:58 AM
dedhed
SE Wis
dedhed's Avatar
Quoted: 2157 Post(s)
Liked 2,191 Times in 1,352 Posts
It's probably one of these.
https://www.benscycle.com/problem-so...yABEgLix_D_BwE
dedhed is offline
Old 02-26-22, 09:28 AM
pennpaul
Quoted: 158 Post(s)
It's an Octalink bottom bracket and the cap is separate from the bolt.
pennpaul is offline
Old 02-26-22, 11:06 AM
dedhed
SE Wis
dedhed's Avatar
https://www.universalcycles.com/shop...SABEgKdMPD_BwE
https://www.benscycle.com/fsa-self-e...iABEgIfY_D_BwE
dedhed is offline
Likes For dedhed:
Old 02-27-22, 08:37 AM
sweeks
sweeks's Avatar
Quoted: 814 Post(s)
Liked 352 Times in 258 Posts
That's the "self-extractor" part of the crank-fixing hardware. It's not actually necessary; the crank can be removed with a standard crank puller. There have been reports of this piece being cracked in the attempt to remove the crank by the self-extracting process. They do look nice though. I replaced mine with titanium from Toronto Cycles, sadly now apparently closed.
Split image. Top is original crank bolt and chainring hardware; bottom is the Ti replacement. Notice the original was not self-extracting.
sweeks is offline
Old 02-27-22, 12:02 PM
pennpaul
Quoted: 158 Post(s)
The first time I tried removing the cranks, I did leave the cap in place and thought better of it once the washer started bearing on the back side of the cap. I ended up using a puller and it required A LOT of torque.
pennpaul is offline
Likes For pennpaul:
