Seatpost clamp & seat tube mismatch issue?
Old 05-15-22, 05:38 PM
the sci guy
bill nyecycles
the sci guy's Avatar
Quoted: 759 Post(s)
Liked 304 Times in 169 Posts
Didnít realize it at the time I was buying this Thomson clamp, but I just put it on and noticed the gap on the clamp where it tensions is offset from the gap in the seat tube. Is this an issue? Will it cause it to clamp lopsided?
i know all Thomson clamps are like this but this is a classic (2001) frame so Iím not sure if itíll work or not?
Twitter@theSurlyBiker
Instagram@theSurlyBiker
the sci guy is offline
Old 05-15-22, 06:40 PM
Rolla
Victimless Criminal
Rolla's Avatar
Quoted: 1139 Post(s)
Liked 2,750 Times in 1,224 Posts
I don’t think it will have any ill effect; the clamp will still squeeze the seat tube around the post. You could always rotate the clamp a little, I suppose.
Rolla is offline
Likes For Rolla:
Old 05-16-22, 10:22 AM
alcjphil
alcjphil's Avatar
Quoted: 1410 Post(s)
Liked 1,008 Times in 612 Posts
Maybe the clamping bolt should be at the front of the seat tube
That's what I would do
alcjphil is offline
Likes For alcjphil:
Old 05-16-22, 10:43 AM
smd4
Bikes: 1989 Cinelli Super Corsa
Quoted: 850 Post(s)
Liked 621 Times in 403 Posts
I'd rotate the clamp slightly counter-clockwise, so the left edge of the clamp is resting on seat tube material--not edge-to-edge like it appears to be now.
smd4 is online now
Old 05-16-22, 11:05 AM
Rolla
Victimless Criminal
Rolla's Avatar
Of course, you could always consult the manual:
Rolla is offline
Old 05-16-22, 11:31 AM
the sci guy
bill nyecycles
Quoted: 759 Post(s)
Heh i know i looked at the directions when I bought it. But it's an aluminum frame and I'm putting in a Thomson Elite seatpost, which is also aluminum...
Old 05-16-22, 11:57 AM
CliffordK
CliffordK's Avatar
Quoted: 15974 Post(s)
Liked 3,297 Times in 2,450 Posts
I'd imagine part of the offset is to either hide the bolt head, or give adequate threads.
I'd probably align the clamp with the slot, so turn clockwise slightly.
Do the instructions say anything about grease? Perhaps grease under the clamp so there is no drag between the clamp and the seat tube mast.
CliffordK is offline
Old 05-16-22, 12:20 PM
Rolla
Victimless Criminal
Rolla's Avatar
Then that would be "conventional."
Rolla is offline
