Fenders for my 55mm x 700c tires ?
ignominious poltroon
Quoted: 2239 Post(s)
Liked 3,434 Times
Seems to me that you really don't have the room for fenders, going from the little I can see in side photo and your comment on toe overlap
My 26inch touring bike, surly troll, has the advantage of tons of room for up to 2.6 or 2.8 inch tires, but also for not having any toe strike even with my fenders set up with ample mud clearance space between tires and fenders.
My commuter with fenders and 700, and platform pedals has a bit of toe strike at times, but it doesn't cause a problem.
An old bike I had one with fenders had bad toe fender overlap and when it was brand new, within a block of the bike store, my foot hit the front fender, jamming it in the wheel and bending the fender into the front tire, folding the fender up, ruining it-- so do be wary, toe fender strike can be slightly annoying or can fold the fender under the wheel if fender is flexible enough.
Ps, I just put my 2inch ( 50mm) slicks back on my bike and use about 35 psi in them. Pressures slightly higher with loaded panniers.
I do only weigh 135.
Just watch pressures on these 55mm tires, over inflating defeats the purpose and ride experience.
What pressures are you trying, what is body weight?
In retrospect, I think 650b wheels might work better. These are "borrowed" from another bike that really didn't need 3 wheel-sets, and I can see where having a dynamo hub could be nice.
Quoted: 3459 Post(s)
Liked 1,465 Times
On my bike with 57mm wide tires, I run 45 psi rear and 35 up front when on an unladen bike. I weigh about 180 plus or minus 5 pounds. More pressure if loaded for touring, maybe up to 55 in rear with a heavy load.
I'm about 190 so maybe 200 lbs fully clothed, etc. I think they are at about 45 psi at the moment, but that was to make sure they seated properly. They roll fine but I think I can go a bit lower.
Have fun experimenting.
Liked 3,434 Times
Here is what the Rene Herse website says for these tires:
Liked 1,465 Times
I am really surprised that they would say the same pressure in front as in rear. That company used to promote what they called the "15 percent tire drop", that looked at how much weight you had on each tire. I often ran higher pressures than they suggested, I treated their 15 percent as a minimum. Their suggestions maxed out at 37mm tire width, which was about the widest that most 700c bikes could take at that time. But I felt that their calculation had way too little pressure in the front wheel so I ran a much higher pressure. Later they changed their theory on front and suggested higher pressure was needed for braking, as braking would shift some of your weight to the front wheel. This article is before they suggested to raise the pressure higher in the front tire.
https://www.adventurecycling.org/def...SIRX_Heine.pdf
I typically run the front at about two thirds to three fourths as much pressure as I have in the rear. There was one exception, in West Texas I was on some really rough chip seal for a week and I dropped my front pressure to maybe 55 percent as much as I had in the rear to reduce the vibration in my handlebars.
Re wide tires and rough roads-- I've shown this photo a bunch of times, but I was so glad to have wider tires (45-50mm) similar to the RH stuff when I did some long trips 4, 5 years ago.
This chipseal road in mid Mexico was the worst chipseal I've ridden on, and wider tires at proper pressures saved my hands that day.
And then there are sandy loose surface roads too.
Liked 3,434 Times
Having said that, I typically use the Silca tire pressure calculator as a guide.
Liked 3,434 Times
Here is the Silca Tire Pressure calculator results for 55mm tires and the same combined weight of 260lbs (I don't want to take 30+ lbs of gear, I am just putting in some numbers and that is what I used last time for the RH calculator).
Liked 3,434 Times
So RH recommends a substantially higher tire pressure, which I would not have guessed. I think this is possibly because the sidewalls are so thin.
I've also noticed with my 42mm treaded tires that they work substantially better (no slipping) in loose gravel/dirt if they are inflated higher than recommended, which is completely counter-intuitive and contradicts their own recommendation to let air out for gravel.
The pressure calculators only get you so far.
I note pressures, but very much go by feel.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Ever since I went down this rabbit hole years ago, I've been content with using a 45/55 weight distribution for my tires, and the new Rene Herse Tire Pressure Calculator unwittingly delivers that for me. I just use the "soft" recommendation in front and the "firm" recommendation in the back.
I like the idea of going by percentage drop, but am too lazy to calculate it. I think I wind up with a similar drop front and back without actually calculating it though.
I don't usually get very scientific with tire pressure. I used to just run them quite hard. In some cases a bit harder that the label listed as maximum. I noticed that over the long term rides tended to be a little faster on some of my regular around home rides when they were a bit softer due to my laziness in topping off pressure. Then I started watching the data more closely and found that didn't seem to be true for really smooth pristine surfaces. Since then I have tried to run the higher pressures on really nice surfaces and lower ones on slightly to very much rougher ones. I am pretty sure it works out better for both performance and comfort.
I suspect that rolling resistance on a glassy smooth surface is actually better with a tire that is inflated quite hard, but it is possible that the performance increase I observed was due to rider comfort.
Liked 3,434 Times
For a long while I ran my RH tires too soft. When you do this, the sidewall will occasionally collapse, and it degrades the tire. You can see this as dark cross-hatching, especially on the inside of tan sidewalls.
I've seen this, but from what I've seen, you really need to ride a lot under pressured to get that to happen. I've never had it myself, but have seen it on other people's tires
Liked 3,434 Times
Liked 1,465 Times
I do not remember the rear pressure very well, that was four years ago, maybe high 70s or low 80s. Front, first day had high 50s for pressure, between 55 and 60. My hands really took a beating, my GPS started acting up and I was afraid that the vibration was damaging the GPS electronics. Second day, dropped the pressure to between 40 and 45 in front. But, did not change the rear pressure, as my folding bike with a tall extension to the seatpost and the sprung Brooks Conquest did a great job of smoothing out the road buzz from the rear. And that low 40s up front worked out so well for smoothing out the road buzz on my handlebars that I stayed with that for the rest of the week. My GPS still occasionally has problems from that day.
Likes For djb:
I have 55mm 700c RH Antelope Hill tires and a (small bit of) clearance. Is this hopeless, or are their any fenders I can get that would work? (The frame is a Soma Saga Disc.)
[Yes, I know getting narrower tires is the correct answer, but I've now sunk a fair chunk of change and time into my beach cruiser blimps, including setting them up tubeless.]
Here is what I am dealing with.
Also how long have you been using that Brooks C17 Cambium, is there a reason why you have it?
Bikes: Merida Speeder
Quoted: 233 Post(s)
Liked 165 Times
Full fenders probably won't fit, but have a look at SKS Velo 65 Mountain 29. Failing that, check out some of the SKS or Topeak MTB fenders and have a look at racks etc for zip tie mounting points, instead of mounting them as per the manufacturer's suggested method.
Even get some coroplast, corrugated plastic snadwich, like Real Estate sign plastic, and line the inner side of the rear rack. You could then maybe find a single front fender.
Liked 3,434 Times
If you have tools or materials already https://www.rei.com/blog/cycle/diy-bike-fenders but there are plenty DIY methods of making your own fenders
Is there a reason why you ask?
You are funny, I would never tour with such suspension especially because it will probably be heavy. It’s a google search image! I was thinking of getting one as I do not want a leather seat but it being waterproof is already a bonus for me!
Liked 3,434 Times
I actually bought it for the bike with the B-17 on it, since it matches the color scheme and is a bit sleeker-looking, figuring I would use the B-17 to tour. But I thought I would put it on a different bike first, since the one with the B-17 is absolutely perfect, and I am worried I would never get it back into the ideal position if I don't like the C-17.
Here is the other bike with the B-17 (copper rivets).
Likes For Polaris OBark:
Some people like the c17 fine, for me it's ok, not great but ok.
Like with lots of things, it depends--completely personal depending on the individual.
Try before you buy. If I left on a tour tomorrow, I would switch it out for my heavy but otherwise perfect B-17. I've only just started playing around with it, but these don't break in. There is no reason it should feel any different at 10,000 km than on day 1.
