To Patch or Not To Patch
Old 06-29-22, 01:10 PM
MudPie
MudPie's Avatar
Quoted: 114 Post(s)
Liked 119 Times in 92 Posts
I'm a tube patcher. I have a small puncture smack dab in the middle of this field of ribs, see photo. I realize that I would need to sand the patch area smooth for a successful patch. The tube is a Continental brand (700x25-ish). The rib field only occurs in a small section, so statistically a puncture in that region is small.
1. What's the likelihood of a successful patch on the ribbed section of this tube?
2. Any idea why this feature exists? I assume it's an artifact of the manufacturing process, but yet not all tubes have this.
MudPie is offline
Old 06-29-22, 01:17 PM
Rolla
Guest
Quoted: 1346 Post(s)
Liked 3,269 Times in 1,439 Posts
The low likelihood of a patch sticking there wouldn’t be worth the trouble to me. Try it and see; maybe use it for an emergency spare, but I’d be wary of depending on it for more than that. There are plenty of uses for old tubes, or your local shop can recycle it.
Rolla is offline
Old 06-29-22, 01:57 PM
Crankycrank
Quoted: 836 Post(s)
Liked 1,058 Times in 742 Posts
So many ribs like that are, of course, a royal PITA but if you want to try, just fold the tire so the rib is on the edge of the fold and sand away at the area needed. Much easier and faster than trying to sand the tube on a flat surface.
Crankycrank is offline
Likes For Crankycrank:
Old 06-29-22, 04:20 PM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 6192 Post(s)
Liked 4,190 Times in 2,351 Posts
The right patch kit will make the repair work better. Don’t mess with anything other than a Rema patch kit.
Sand the ribs down as much as possible, use a fair amount of vulcanizing fluid, and rub the patch well after you attach it. It should work very well. I’ve done this on a number of tubes…although, thankfully, there are too many tubes like this.
Stuart Black
cyccommute is offline
Likes For cyccommute:
Old 06-29-22, 04:50 PM
freeranger
freeranger's Avatar
Quoted: 426 Post(s)
Liked 694 Times in 433 Posts
Might work but I'd just put a new tube in. Not worth the time and trouble if it failed. Even if it didn't, I'd always be wondering if it would. That's just me tho.
freeranger is offline
Old 06-29-22, 04:55 PM
SoSmellyAir
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1938 Post(s)
Liked 1,460 Times in 1,011 Posts
Originally Posted by MudPie
I'm a tube patcher.
I am not.
Since we are both in Southern California, you can have my Pirelli RoadTube 700 x 23C-30C (60 mm stem); I even marked where the pinhole is.
SoSmellyAir is offline
Likes For SoSmellyAir:
Old 06-29-22, 07:03 PM
Rick
Quoted: 611 Post(s)
Liked 387 Times in 270 Posts
I agree with cyccommute on the rema patches. I have also patched tubes like that before. There was an American tube company in the 1980s named Carlyle that used rubber in their tubes. I had a tube with a large # of patches that didn't leake. Schwalbe makes a tube that holds air longer called Air Plus the secret ingredient is rubber.
Rick is offline
Old 06-29-22, 08:49 PM
dedhed
SE Wis
dedhed's Avatar
Quoted: 2738 Post(s)
Liked 3,379 Times in 2,044 Posts
I use a single edge razor blade to trim ribs.Way faster than sanding them down
dedhed is offline
Likes For dedhed:
Old 06-30-22, 07:55 AM
pdlamb
Quoted: 2588 Post(s)
Liked 1,919 Times in 1,203 Posts
I tried the razor trick, and sliced the tube. Oops!
Just grab a bit of coarser sandpaper (40 or 60 grit) and sand across the ribs.
pdlamb is offline
Old 06-30-22, 10:48 AM
Rdmonster69
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times in 216 Posts
No one has answered what the ribs are for. Its ribbed for her pleasure !!
Rdmonster69 is offline
Old 06-30-22, 11:31 AM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1784 Post(s)
Liked 1,259 Times in 868 Posts
Something like this could make the difference between success and failure on a "difficult" patch.
https://www.napaonline.com/en/p/BK_7...&gclsrc=aw.ds&
Bill Kapaun is offline
Likes For Bill Kapaun:
Old 06-30-22, 11:52 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3580 Post(s)
Liked 3,391 Times in 1,927 Posts
Agreed. Rema patches and vulcanizing fluid make for a reliable repair. I can't say the same for other brands, or mixing brands. A patch roller can help seal the patch on a ribbed tube. Roll parallel to the ribs, between the ridges:
File Type: png
JohnDThompson is offline
Likes For JohnDThompson:
Old 06-30-22, 01:17 PM
Bill Kapaun
And work from the middle out to the sides.
Old 06-30-22, 05:03 PM
urbanknight
Over the hill
urbanknight's Avatar
Quoted: 995 Post(s)
Liked 1,200 Times in 689 Posts
I don't think I've ever had trouble with ribs like that. Just sanded them as much as possible and burnished the edges of the patch well. Even if it fails, you lost 1 patch and a few minutes of time.
It's like riding a bicycle
urbanknight is offline
Old 07-01-22, 08:31 AM
pdlamb
That's a lot more trouble that I go to -- or maybe it's just in a different part of the repair. I spend my attention sanding the tube down, don't care too much about the glue, and I've never used (or owned) a patch roller. Rarely have I had a patch fail; the last one was when I didn't see the Michelin wire and a few miles down the road the wire poked right through the patch and the tube. Can't blame the Slime patch cement for that failure! (The ones I patched with Elmer's rubber cement over 3-5 years also held with no problems.)
To recap: sand the tube until it's lost all the glossiness on its surface. I use Rema patches because no one else sells packs of 100 that I know of. Put enough glue or cement on, and let it dry. Press the patch on, and I'll roll a thumb out from the middle to the edges. It's a good way to spend an hour on a cold or rainy weekend afternoon if you replace tubes on the road and save the leakers until you've got a half dozen or so to go through.
pdlamb is offline
