Shogun Prairie Breaker 1 MTB
Old 07-01-22, 07:11 AM
partyanimal
Quoted: 88 Post(s)
Liked 82 Times in 34 Posts
Looking at building out a new/old vintage MTB, came across this Shogun, believe it's around a 1985/86 from the research I've done. I'd likely replace the bars and saddle (and tires) but otherwise looks in good shape. I know from past experience, depending on where and when a bike is made there's lots to consider in regards to finding parts, quirky sizing etc. Pretty sure this is Japanese built. Anyone know anything about these and if it'd be fairly easy to replace the stem/bars? What if I need to replace the BB, any weird sizing there I should know about? If it's one thing I'm confident in, it's the breadth of knowledge contained in these forums.
BTW - asking $100 for this bike, will obviously try to get it a little cheaper.
partyanimal is offline
Old 07-01-22, 08:34 AM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 6219 Post(s)
Liked 4,217 Times in 2,364 Posts
Replacement parts aren’t all that weird nor oddly sized. The stem on the handlebar is a 1” (22.2mm) which isn’t current standard but there are millions of 1” stems around in the used market. You can even find new ones. But why change the stem? The moose handlebars aren’t that uncomfortable and they are period specific. The bike looks like a time capsule so why not keep it that way?
The bottom bracket is a 1.37” x 24 tpi. It’s an “English” or BSA bottom bracket. Still common and easily available. The current bottom bracket is probably a cup and cone which can be rebuilt, although a cartridge bearing bottom bracket requires no maintenance.
$100 is too high. It’s in good shape but a Shogun Prairie Breaker isn’t anything special in the history of mountain biking. That one does look like it’s a 22” or even a 25”. That’s means it fits someone 6’3” or taller on a 22” or 6’6” and above for a 25”.
Stuart Black
cyccommute is online now
Likes For cyccommute:
Old 07-01-22, 08:37 AM
partyanimal
Quoted: 88 Post(s)
thanks, after doing a bit of research I realized it'd probably be too big. MTB sizing always throws me off. I do like the bars but kinda had a specific project in mind for it. Oh well, keep looking. thanks again for the info.
Old 07-01-22, 09:32 AM
cyccommute
cyccommute's Avatar
Mountain bike sizing is fairly easy to understand if you remember to go 3” to 4” smaller than your road bike size. I ride a 58cm road bike (23”). I ride a 19” mountain bike (49cm but you never find mountain bike listed in metric sizes).
Stuart Black
Old 01-15-24, 11:43 PM
ElGenerale
Quoted: 14 Post(s)
Liked 19 Times in 7 Posts
...(49cm but you never find mountain bike listed in metric sizes).
Unless you're looking at a Bridgestone catalog
ElGenerale is offline
