what do you use for handlebar shims
Myrtle Beach Crab
Bikes: enough one would think, but thinking isn't my strong point
Quoted: 271 Post(s)
Liked 541 Times
going to use 25.4 bars with a 25.8 clamp on my stem.. what do folks use for a shim? a strip cut from a beer can? (which of course means that i'm going to get the right beer for riding karma..) shim strip material that might be available somewhere?
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 983 Post(s)
Liked 632 Times
Not for bikes but I once bought (and still have most of) an assortment pack of brass shim stock from the local auto-parts store; I see Amazon sells something similar, using a search for "brass shim stock". That said, aluminum is lighter than brass I presume once shimming, one loses the effectiveness of any knurling on the center of the bars, to a degree.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Pedal to the medal
Whatever you use, just remember to double the thickness when doing calculations, eg a 1mm shim will add 2mm of thickness, as you're wrapping the shim around the bar. Might be elementary engineering for some, yet it is a helpful reminder.
Myrtle Beach Crab
Quoted: 271 Post(s)
Liked 541 Times
Likes For cocoabeachcrab:
Quoted: 5888 Post(s)
Liked 3,471 Times
beer cans are win win; great for shimming but first you have to drink the beer.
Likes For bikemig:
Quoted: 930 Post(s)
Liked 1,291 Times
I messed around with beer cans and thin stock sheet metal but it can be difficult to get the exact thickness you need. For the correct fit, go here: https://problemsolversbike.com/produ...p_shims_-_8466
Myrtle Beach Crab
Quoted: 271 Post(s)
Liked 541 Times
Myrtle Beach Crab
Quoted: 271 Post(s)
Liked 541 Times
... which brings up another question... what brands of beer would be good candidates for shims? and i don't really care about the shim part, but i'm seeing a new reason to drink some some beer that begs to be exploited!
Quoted: 1607 Post(s)
Liked 2,216 Times
I tried that but couldn't get the clamp tight enough. this was using a 26 in a 36.4 clamp. Just tightening it down was enough.
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
I can't drink anymore, so I have to substitute a fizzy water can.
Quoted: 4511 Post(s)
Liked 6,378 Times
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
I’ve used 12 mil (0.3mm) stainless steel flat stock 1” wide for shimming 26.0 clamp to 25.4 bars. At the moment, both bikes have stems with 25.4 mm clamps so no shins are needed.
Otto
Otto
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Pinocchio was made of wood, and he became a real boy.
Likes For Phil_gretz:
Quoted: 4722 Post(s)
Liked 3,036 Times
Not lost wanderer.
Quoted: 885 Post(s)
Liked 990 Times
If you use any drink can heat the shim to remove the plastic inner liner.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Likes For thumpism:
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Ftw:
