Alternatives to the WTB Nano 29x2.1? Wide all around tire
Quoted: 1088 Post(s)
Liked 1,024 Times
As the title says, looking for a wide do anything tire. I realize of course there will be penalties with wider tires but still want something that moves smooth and fast on pavement and can still handle a bit of single track or rough jeep trails.
I'm trying to limit the bike to 2.1 which gives better margins for mud and riding through with a broken spoke should that randomly happen. From what I've read the Nano is a top rated tire for the Tour Divide which is why I fit it to the wife's bike but now I need one for myself and I'm trying to asses if there's an equal or better that has arisen in the last couple years. This year we'll be riding the adirondacks and touring the Erie Canal with kids in the hopes of prepping to do the great divide in one of the two years following. That's what the bikes are built for and what I'd like the tires to accommodate. Any suggestions?
Maybe the 48mm Oracle Ridge, or the 2.2" Fleecer Ridge. The strongest casing FR option is 20gm lighter than that Nano.
This tread pattern will be very good in mud, have really good climbing/descending grip etc. Plus they roll pretty good on sealed roads for that knob height.
Likes For tangerineowl:
Bikes: Kona Kahuna DL Drop Bar - Sensah SRX Pro 1x11 (2012 Frame), Giant Toughroad GX 1 - Shimano Road Hydro + SLX 1x10 (2018), Diamondback Sync'r - SRAM NX 1x12 (2020)
Quoted: 160 Post(s)
Liked 97 Times
Vittoria Mezcal - Available in 2.1 and very similar tread pattern. If you need a more aggressive front tire You can do a Barzo front tire
Likes For DarKris:
Quoted: 5224 Post(s)
Liked 3,581 Times
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
I've got Nano 700c x 40 on one bike - I do love them. My other bike has Teravail Rutlands and I really love these tires. To me they are a great all-rounder, do-anything tire. They might not look like it but they roll fine on pavement, not unlike how the Nanos feel with that center tread. And they handle everything offroad I can throw at them. In 29 they are 2.2, not sure if you can squeeze those in, but great tires IMHO.
https://teravail.com/products/rutland-tire#/
Likes For pbass:
Habitual User
Quoted: 4946 Post(s)
Liked 8,085 Times
Looks similar to the Pirelli Ciinturato Gravel M. 700 x 50 is a bit narrower than 2.1, but it might be wide enough for your needs
Likes For Eric F:
Liked 1,024 Times
Likes For Russ Roth:
Liked 3,581 Times
maybe I should have bought the WTB Nano 29x2.1. just mounted up some WTB Venture 700x50 (aka 2.0") but they only measure 45mm & may not have enough of a center bead. gotta check them while riding. but new tires are always fun. & these are 120 TPI so they should feel good. I'll try them at various pressures too. the rear seems fine at 40psi but I might crank it up to 60 to see how big they get & how they roll on pavement
Liked 3,581 Times
pumped them up to max 60psi in the rear, 50psi in the front. will be interesting to see how I use them
Liked 3,581 Times
even at max pressure (60 rear, 50 front) they are not harsh or too hard
- they can not compensate enough to replace even an entry level coil shock over rocks & roots. certainly not at these pressures
- over wet spots w/ mud they get squirmy/greasy (don't remember the Nanos having this issue)
Liked 3,581 Times
fwiw - the MTB still has it's Riddlers as we wait for the temps to drop again. really good all around off road tire. pavement? not so much, but I can certainly ride some pavement to get to the dirt
Quoted: 1397 Post(s)
Liked 1,877 Times
for an MTB / off road tire that rolls well - consider the Continental Speed King
Speed King will roll as well or better than many gravel tires
Likes For t2p:
