Understanding Shimano SPD System
I've had these shoes kicking around from a few years now. They are comfortable enough to walk in. The shoe is labeled Shimano and SPD. It has laces rather than straps. So an early model?
However I have never tried a clipless pedal system and I'm trying to figure out how it would work. Specifically how does the cleat attach to the bottom of the shoe?
I just see a recessed outline. no bolt holes or attachment points. And will any SPD pedal work with it? Thanks in advance.
Senior member
Quoted: 66 Post(s)
Liked 124 Times
That outline is a cover that pops off to reveal the mounting holes. You need standard SPD pedals (ie 5** series). SPD-SL is the road style for large, triangle "Delta style" plastic cleats, you can't use those. Laces vs straps doesn't indicate age, they make new versions with laces for a more "casual" looking shoe.
Forum Moderator
Quoted: 3090 Post(s)
Liked 6,593 Times
You need to pop off the cover on the bottom of your shoes to expose the cleat mounts. Then any SPD cleat and pedals can be used.
Quoted: 3238 Post(s)
Liked 2,084 Times
Understandable once you know that they (Shimano) leave the cover in place in the event you want to use the stiffer than a sneaker cycling shoe on a flat pedal or one with a cage and strap. Only take off the cover to install the cleats.
Edumacator
Quoted: 2439 Post(s)
Liked 3,122 Times
Funny thing is I would love to find a few covers to convert a few to just plain shoes.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I have a pair of covers that I neglected to throw away. PM me your address if interested.
Likes For ThermionicScott:
Quoted: 1088 Post(s)
Liked 1,205 Times
Nice little write up here. https://drivemybike.wordpress.com/20...ommon-systems/
You will need the cleat pictured on the right. (Pic is from that link.)
Quoted: 2482 Post(s)
Liked 2,952 Times
One small correction/clarification: the cover over the cleat slots in the soles of the earlier models of SPD shoes, such as the one in the picture provided by the thread starter, doesn't simply "pop off." You have to use, e.g., a utility knife to cut around the outline of the cover to expose the cleat slots. Most later Shimano SPD models have a bolted-on cover over the slots.
Likes For Trakhak:
Bikes: Historical: Schwinn Speedster; Schwinn Collegiate; 1981 Ross Gran Tour; 1981 Dawes Atlantis; 1991 Specialized Rockhopper. Current: 1987 Ritchey Ultra; 1987 Centurion Ironman Dave Scott Master; 1992 Specialized Stumpjumper FS
Quoted: 209 Post(s)
Liked 178 Times
Wow, I have that same pair of shoes. They have to be from the early 2000s, if not the last millenium.
They're still usable, I just decided to finally get a new pair. Great shoes.
Likes For vtchuck:
Quoted: 3464 Post(s)
Liked 2,829 Times
One was a silicone sole, total no luck.
Quoted: 1324 Post(s)
Liked 927 Times
Cheers
