Slipping seat clamp | carbon fiber
meh
Quoted: 1110 Post(s)
Liked 1,013 Times
I got my first carbon fiber bike this year, 2021 Bianchi Infinito.
The seat clamp slipped, cutting my ride short on Tuesday, I finished my ride at the LBS to have them help me with a torque wrench. Today the seat clamp slipped again .... WTF?!?
This week has been my first rides in cold temps with this bike, 13°F today. But that shouldn't effect the seat clamp, should it?!?
I'll contact the shop where I bought the bike this weekend. Just interested to know if this is a common issue, or just a personal issue.
Quoted: 1163 Post(s)
Liked 442 Times
You say the seat clamp slipped? Or was it the seat post that slipped? Not sure if the Bianchi Infinito uses a round post or some special cross section (such as a D shape) post. Definitely contact the shop again to let them know it is still slipping. This is one of those types of things that you just have to keep looking at until you resolve the problem. They can put carbon fiber grip past on the post and also torque the seat collar up to the torque spec. Different seat collars have different torque specs. Some factory seatposts are not of the highest quality and may be slightly undersized.
Could you post a photo of the seat collar and the seatpost?
Get some carbon grip from your local bike shop.
https://www.rei.com/product/801108/f...-gel-175-fl-oz
Likes For Airfehr:
meh
Liked 1,013 Times
It's an integrated seat clamp that isn't holding, letting the seat post slip down. It's a D-shaped seat post.
Here's the integrated seat clamp
And the strider set up
meh
Liked 1,013 Times
Liked 442 Times
Hypno Toad - the shop will know the correct procedure to tighten up the internal wedge (or they should). You hear about slippage issues with internally wedged seat posts quite a bit.
Likes For masi61:
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
apply the paste to inside of the frame, just about 1" depth should be fine. wrap some tape around the seatube, where the bottom edge of the tape is at where you want to install the seatpost down in in the seatpost. This will prevent going too far and having to back out. Assembly paste can scratch or mar surfaces, so this would prevent any marring in a visible area on your exposed seatpost.
Likes For Sy Reene:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2581 Post(s)
Liked 5,637 Times
I have that bike and have not experienced that issue, but I do torque the bolt to spec listed next to the bolt. I am guessing when your bike was assembled, they used some type of anti-seize instead of the paste recommended above so make sure all the old gunk is completely cleaned out first.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Quoted: 427 Post(s)
Liked 699 Times
Same ? popped up not too long ago: Sinking seat post Giant Revolt Advanced 2, D-fuse. - Bike Forums
Advocatus Diaboli
Liked 1,532 Times
meh
Liked 1,013 Times
Ok ... So I didn't work very hard to search for other threads on the subject ... ... meh
Advocatus Diaboli
Liked 1,532 Times
EDIT: for sake of convenience, this post in one of the threads seems to outline what worked in this particular instance. May be worth considering if applicable to your circumstance https://www.bikeforums.net/20653228-post22.html
Likes For Sy Reene:
