Free wheel noise
Free wheel noise
Old 11-14-23, 12:37 PM
dirtydozen
Quoted: 106 Post(s)
Liked 8 Times in 6 Posts
Free wheel noise
Hello,
I did a couple of climbs 2 weeks ago and during the descents my freewheel would make a weird noise (like a very noisy hub).
It doesn't happen systematically when I am in free wheel, I can spend 10sec and then noise comes, sometimes noise comes just after 2 seconds as well.
What is consistent though is :
1) as soon as I pedal the noise is gone instantly
2) if I pedal backwards it makes the same noise instantly and i can feel it's not smooth
Do you guys have any ideas what could be the reason ?
thanks
dirtydozen is offline
Old 11-14-23, 12:45 PM
eduskator
eduskator's Avatar
Bikes: SL8 Pro, TCR beater
Quoted: 983 Post(s)
Liked 583 Times in 438 Posts
It's hard to say without a video / sound clip. Also, what do you mean by ''its not smooth''?
My freehub sound isn't always constant either (it changes depending on a few factors, including the temperature) but I don't feel like there's anything wrong with it.
eduskator is offline
Old 11-14-23, 01:09 PM
datlas
Should Be More Popular
datlas's Avatar
Quoted: 22583 Post(s)
Liked 8,923 Times in 4,156 Posts
Probably one of the pawls in your ratchet is stiff and/or needs lube. I suspect plenty of YouTube videos explain how to disassemble and grease this.
Originally Posted by rjones28
Addiction is all about class.
datlas is offline
Likes For datlas:
Old 11-14-23, 01:14 PM
frdfandc
frdfandc's Avatar
Bikes: 2013 Jamis Dragon Race
Quoted: 58 Post(s)
Liked 37 Times in 30 Posts
Need to know what kind of sound it makes to try and pinpoint what's going on. A video or sound clip would be very useful.
frdfandc is offline
Old 11-14-23, 04:39 PM
Chandne
Bikes: 2022 Moots RCS, 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Ibis Ripmo, Trek Top Fuel, Specialized Levo SL, Norco Bigfoot VLT
Quoted: 464 Post(s)
Liked 182 Times in 118 Posts
Pull the cassette off and take a look. It may need a good cleaning and some grease but make sure nothing is broken.
Chandne is offline
Old 11-15-23, 04:21 AM
choddo
Quoted: 682 Post(s)
Liked 453 Times in 338 Posts
Does the top of the chain go slack when this happens, as if the cassette is being pushed forward a bit by the rotation of the wheel?
Is it a Mavic wheel?
choddo is offline
Old 11-15-23, 03:17 PM
aliasfox
Bikes: Lynskey R270 Disc, Bianchi Vigorelli
Quoted: 299 Post(s)
Liked 156 Times in 131 Posts
I had this happen on my old Mavic Ksyrium Equipe. First time, the wheel freewheeled much more loudly than before, like something snapped inside the freehub and was buzzing every time it freewheeled. It eventually started taking longer to engage (think more than 1/4 turn of the cranks, maybe a full revolution before it engaged). Took the wheel to the shop, they diagnosed it as a failing freehub, and put on a working freehub from another Mavic that had come in (for the cost of labor). The 2nd freehub started failing a few weeks ago, with the symptoms you described - upon coasting, the top of the chain would go slack, and even a small amount of backpedaling (2-3 rotations) would cause the chain to go slack enough that the bike would try to shift gears. As this was already the 2nd freehub, and the rims were pretty worn down, I bit the bullet and bought new wheels. Ksyrium S wheels this time, no complaints so far.
aliasfox is offline
Old 11-15-23, 03:33 PM
Iride01
Iride01's Avatar
Quoted: 6185 Post(s)
Liked 4,803 Times in 3,313 Posts
If the top run of the chain isn't going very slack, then I'd tend to not worry about it. Probably you just have a noisy hub that gets noisier and changes sounds somewhat as you get faster. Maybe the lube is getting pushed more out of the way and isn't cushioning the pawls every blow they make in the rachet mechanism.
If it's a problem that is about to happen, then you'll probably be able to realize exactly what needs fixing when it becomes very evident to you for the same amount of money or less than you can "fix" potential causes.
Iride01 is offline
Old 11-15-23, 04:07 PM
big john
big john's Avatar
Quoted: 8271 Post(s)
Liked 9,022 Times in 4,468 Posts
Could be freehub bearings.
big john is offline
