Go Back  Bike Forums > Bike Forums > Fitting Your Bike
quadriceps cramps due to the saddle too inclined?
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Old 07-10-21, 06:45 AM
3dbiker
Quoted: 19 Post(s)
Hello everyone in the last granfondo I did I had problems with quadripicites and vastus medialis after about 3/4 of the race. I could no longer push even downhill. Once the race is over, after 2 minutes of rest, everything is over so I think that this type of problem is due to the position? what do you think?
I am 176cm tall with an inseam of 82.3cm, and foot size 45.5 I pedal with a 73.5cm high saddle very advanced with an inclination of -5.6 ° and cleats all advanced. Bontrager for that type of saddle recommends an incline of -2 ° in your opinion the kind of problem I had what it could be due to:
- saddle too inclined at the bottom
- cleats too advanced
- saddle too advanced
tanks
3dbiker is offline
Old 07-10-21, 08:21 AM
Iride01
Iride01's Avatar
Quoted: 6193 Post(s)
Liked 4,809 Times in 3,317 Posts
Saddle too low. What type bike?
Though until I read your specs, I'd just assume you don't ride much and your quads just need to get use to the new amount of riding and fact you were probably pushing to keep up with others.
Or did you measure your saddle height to the BB? I feel that measuring saddle height to the pedal furthest away makes the most sense. Then crank length is not necessary to know.
Iride01 is offline
Old 07-10-21, 03:21 PM
philbob57
Quoted: 715 Post(s)
Liked 613 Times in 377 Posts
Are these new settings for you?
philbob57 is offline
Old 07-10-21, 06:55 PM
Carbonfiberboy
just another gosling
Carbonfiberboy's Avatar
Quoted: 3889 Post(s)
Liked 1,938 Times in 1,383 Posts
Agreed, saddle probably too low. Try the heel-on-pedal method (google if you don't know it). Calculation says 75 cm. Why so much tilt? I've had to use up to -7° when fighting a really bad saddle sore, but it sure wasn't comfortable. I usually like ~1/8" tilt, whatever that is.
But also IME cramps are all about training status. If one has done enough intensity for enough duration, one just doesn't cramp anymore. My recipe is a 4-5 hour hilly ride once a week, done at intensity which leaves one hardly able to walk at the finish. About 4 months of that, after doing the usual endurance and interval work, seems to do the trick. Plus enough weekly endurance hours to balance that out.
Results matter
Carbonfiberboy is offline
