Best saddle for zwift
Hi- First off, Happy Holidays!
My bike came with a stock saddle. It’s fine for outdoor riding. I do 25 mile rides and in the city I do a lot of stop and go riding so there’s not as much stress in the crotch area because I get a break every 5 blocks or so.
Riding zwift is non-stop and my crotch gets sore even with padded shorts if I ride over a half hour. I need to lose about 15 pounds which will alleviate some weight adding to the stress.
But I think I need a more comfortable saddle and I’m willing to spend some money. Any recommendations? Looking for long ride comfort. Thanks
Quoted: 10236 Post(s)
Liked 5,184 Times
Saddles are pretty personal. What works for one person might not work for you.
With that being said:
I was gifted an ISM prologue. I have routinely ridden for two to three hours at a time and have never been bothered by it. When it wears out I plan on getting a new one.
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
Just plan on buying 5-6 saddles (used will probably be easiest on the wallet), trying them all out, and selling the ones you don't like.
There's not a single person here who can tell you which saddle is comfortable. Case in point, I think the ISM Prologue recommended above is an absolutely horrendous saddle, and I barely made it through one ride before selling it, but lots of people raved about it so I bought it used and sold it for nearly what I paid. No big loss.
I've tried probably a dozen saddles over the year, from Selli Italias to Selle San Marcos to Specialized to ISM to Fizik to Bontrager, etc., etc. Currently I'm riding 100 gram full carbon (no padding) saddles from China. Some things work for some, other things work for others. Just try a bunch until you find the one that works for you.
Should Be More Popular
Quoted: 22597 Post(s)
Liked 8,925 Times
Likes For datlas:
Klaatu..Verata..Necktie?
Quoted: 10424 Post(s)
Liked 11,898 Times
I have noticed that the structured workouts tend to be harder on the tuchus than free riding, because you remain seated the whole time. I've taken to standing up on hills a lot more than I do IRL - basically whenever the grade goes over 5%, whereas IRL I tend to climb seated until the grade's more like 10%.
I had the same problem. I have been using the trainer to dial in my bike fit adjustments (saddle position, etc). I never experienced too much discomfort on the road because as you suggest, you are stopping often or can more easily get out of the saddle. The trainer really seams to exacerbate poor fit. Initially, I would get pretty numb around 30-45 mins. Now I can go a couple of hours on the trainer (taking occasional out of saddle breaks) after adjusting my saddle position.
Sunshine
Quoted: 10963 Post(s)
Liked 7,490 Times
As others have said- nobody here knows what saddle will fit you best. People will happily name random saddles, but that means nothing.
Go to a shop that has test saddles you can test. Try a few on your bike and then make sure to ultimately buy one from them.
Or buy a few different shaped saddles on amazon/ebay for cheap and try them out. Then buy a quality saddle that has the same shape/design as the cheap saddle that fits.
Personally, if I had no idea what to use, I would lean heavily on a local shop with test saddles.
You say your crotch hurts, but that could be for different reasons than others- you may need a cutout in the saddle, you may need a saddle with a different radius, you may need a saddle with a thinner nose, etc etc.
Likes For mstateglfr:
Quoted: 6963 Post(s)
Liked 10,963 Times
I would pay for a good, "professional", bike fit rather going down the rabbit hole of finding the right saddle first if you haven't done so. The second thing I invested was on a rocker, DIY. With a rocker, the longest I have ridden was just over five hours (time recording 5:14:14 & time moving 5:01:38) and my rear was not the limiting factor. W/O the rocker, I was getting pretty uncomfortable at the three hour mark and had to rest the next day. I'm still using my stock saddle and been lucky with all of my stock saddles since mid 80s. And yes, I have paid for more expensive saddles that were just more expensive for name and weight. Comfort-wise, no so much.
I tried the standing up approach, 45 secs every 10 mins and that seemed to work fine. So thanks for the tip. Guess I’ll keep this one until spring. Then I want to check out some other saddles and experiment when I can get back to outdoor riding.
zwift really kicked my a$$ today but that that’s a story for another thread. I’m on week 2 of a 12 week training program. Lucky there is a pause button or I wouldn’t have made it. Lol
NYC
Quoted: 1169 Post(s)
Liked 107 Times
My road saddle is a SLR Superflow. Absolutely kills me on the trainer though.
So I pulled the saddle off my Peloton bike to give it a try... it's still a fairly road bikey shape, but with actual padding (and heavy as a brick which matters not indoors).
I thought it might work out well and so far it has.
I'm thinking of picking up a used or unused Peloton saddle on ebay to put back on the Peloton bike.
Likes For nycphotography:
Bikes: bikes
Liked 1,429 Times
In addition to the above advice (which is all excellent), be sure to visit a shop that can measure your sitbones width in order to steer you toward a saddle of the appropriate width. A Specialized dealer should have this, and I believe they also allow returns (even of used saddles) in a 30-day window. (At least, they allow that for online purchases - I would bet that retail stores will offer it, too.)
STOP THE SIT BONE MADNESS!
But, measuring a boney land mark, that actually doesn't come in contact with the saddle, is not the solution.
Liked 10,963 Times
Food for thought:
Even though I have narrow sitbones, I find that a wider saddle almost always feels better, as long as my inner thighs don't rub on the sides while I'm pedaling. But I do just fine on the width suggested by the Specialized system.
A couple of recommendations:
- Trainer Ride Position - I have noticed that I not only ride the tops more on the handlebar, but my hip position is more upright when on the trainer. I think this is due in large part to the elimination of the elements, meaning that you naturally no longer feel the need to get lower and more aero on the bike. It is amazing how riding upright puts so much more pressure on your rear end, and that coupled with not necessarily being off the saddle (at intersections or starting back up to speed - which helps to reduce the consistent and constant time on the saddle), means your sitting on the same pressure point for longer, and more consistently.
- Saddle height - nothing scientific, but I have seen others comment that you should slightly lower the saddle height while on the trainer. I do not condone nor am against this, as bike fit changes can cause other issues (knee for example), so do that at your own risk. But I will admit, when on the trainer, my bike just feels "bigger". I wonder if anyone else has noticed this.
- Saddle Width - as someone mentioned above, narrow saddles when in a more aggressive position may be optimal, but on a trainer, a wider seat might be considered a more optimal approach. I am going to switch from my 143MM Specialized Romin to the larger 168MM saddle on my single-speed and see if that helps.
- Chamois Cream - i normally never use chamois cream when outside (it helps that it is so dry here in Colorado, that moisture evaporates which helps reduce chaffing). However, in the basement on the Kickr, it has been a different story, and it seems to have helped to use chamois cream.
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
Food for thought:
Results matter
Results matter
Liked 1,938 Times
Mine were a lot more money. OK. What is it, where'd you get it?
Results matter
Results matter
Bikes: bikes
Liked 1,429 Times
Just a generic saddle from China. They have them on ebay and aliexpress. Here's one I bought: https://www.ebay.com/itm/TOSEEK-Full...72.m2749.l2649
Likes For rubiksoval:
Liked 1,938 Times
Results matter
Results matter
Bikes: 2015 Felt Z75 Disc, 2008 Fuji Cross Comp, 2010 Trek Navigator 1.0, 1974 Raleigh Sports, 1974 Schwinn Le Tour, 1981 Schwinn Super Le Tour, Surly Cross Check, 2021 Giant Talon 2
Quoted: 202 Post(s)
Liked 71 Times
Trying to keep up
Bikes: Pinarello Prince, Orbea Onix, Ridley Fenix
Quoted: 79 Post(s)
Liked 136 Times
