Upgrading to disk brake question.
Really Old Senior Member
How are you going to mount the calipers?
You need the proper frame/fork.
Likes For Bill Kapaun:
Habitual User
Quoted: 4934 Post(s)
Liked 8,074 Times
Does your frame and fork have the mounting tabs for disc brakes?
Likes For Eric F:
Quoted: 1074 Post(s)
Liked 295 Times
All new calipers I’ve seen have been sold ”loaded” - incl brake pads.
Once those wear out, remove them from the caliper and go shopping for new ones according to shape. If you’d bought a recognized brand, you could have used the make&model to buy new pads. That might not work this time.
You’ll need new wires too. Compatible levers. Perhaps adapters if your frame/fork is IS mount. Some zip ties to secure the wires.
Quite likely new spokes.
Expired Member
Quoted: 3660 Post(s)
Liked 5,407 Times
Liked 295 Times
Mechanical disc brake calipers are available for two different cable pulls.
Flat bar brake levers are available in two different cable pulls.
Habitual User
Liked 8,074 Times
This mount okay or they make something more reliable?
Likes For Eric F:
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 217 Post(s)
Liked 155 Times
Edit: especially if you are getting the 180mm calipers.
It may be the case that the fork is not designed to withstand the loads of disc brakes, and using the mounts may break it. Many people here will advice to ride the bike for now and save for a new bike which comes with disc brakes right away and which is not a department store bike.
Disk brake uses cable thickness more than 1.6mm, do you have link?
Quoted: 581 Post(s)
Liked 921 Times
Bad idea from the World Famous King of Bad Ideas and Pointless Questions.
Frames and forks made for disc brakes are engineered to handle disc brakes and the extra loads the apply to the middle of stays/fork blades. Frames and forks made for rim brakes are not engineered to handle these forces.
I thought you were busy upgrading your bike from 5 speed to 6 speed? Why the sudden jump to 1990s technology?
Likes For ClydeClydeson:
Quoted: 1062 Post(s)
Liked 665 Times
I'd give it a poor chance of actually being satisfactory and working well enough to trust the brakes. The brake mounts will require spreading the frame, and depending on how thick they are, will interfere with full engagement of the axles with the dropouts. Any flexing between the mounting bracket and the frame / fork may cause them to work loose over time. And it may be quite frustrating to remove and replace the rear wheel to fix a flat tire. This has the looks of an aftermarket accessory that is not fully engineered for your bike.
What's wrong with the brakes that are already on the bike? This "upgrade" may be a step backward.
Habitual User
Liked 8,074 Times
Likes For Eric F:
Liked 295 Times
It seems like you missed the point entirely.
I’ll try again:
1) different levers make the cable move different amounts as the lever moves through its stroke
2) different calipers require different amounts of cable movement to work right.
3) If you don’t match levers to calipers, you are unlikely to get good function from your brakes.
I don’t know what bike you’re starting with, what parts that are on it. I don’t know what cable pull you have. I Haven’t checked the specs of the brakes you want to buy. I don’t know(for sure) what cable pull your calipers require.
Brake wire diameter is your least concern.
I’ll try again:
Liked 295 Times
For disc brakes to work, the alignment and positioning of rotor and caliper is VERY important. I have a hard time seeing how those mounts can be accurate enough.
Likes For dabac:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Do you have disc brake wheels? Where will you mount the rotors? And if you have a non disc brake frame how will you get those wheels in the frame? This is one of the worst of all bad ideas. You must be trolling.
Likes For cxwrench:
LR÷P=HR
Quoted: 865 Post(s)
Liked 1,198 Times
PimpMan,
I have a 90's MTB that at the time scared me so badly with poor braking my knee jerk reaction was to swap out the OEM Coda brakes for Shimano XTR.
Problem well and truly solved.
Truth be known, had I simply replaced the Coda brake blocks/pads for a better performing product I'd have likely been fine.
But hey.. I wanted XTR and that's what I got. Plus it was a simple switch that the frame was already designed for.
You are embarking on a completely different technology that your frame is not designed to support.
This would be a tough and expensive swap and possibly unwise for a seasoned mechanic.
You might want to reconsider your approach.
Barry
Barry
Bikes: TRIMMED DOWN THE HERD
Quoted: 1090 Post(s)
Liked 935 Times
Are you running cantilever or v-brakes? If cantis, just throw on a decent set of v-brakes and you'll be just fine.
This reminds me of some TROLL type of thread.
Likes For 2cam16:
Quoted: 2337 Post(s)
Liked 2,819 Times
Bluntly an really stupid idea, super cheap parts, retrofit for something never designed for disk. basically throwing money away. hubs are quick release, there is a reason the standard for disk now is through axle
Only wants to listen to those that agree with them and ignores good advice even though they they don't apparently have the knowledge to tell the difference.
They want to slaughter the pig & tan the hide before they start installing the lip stick.
Usually, people like this make my ignore list, but this poster may be a "Best Of".
Quoted: 1088 Post(s)
Liked 1,022 Times
Hate to jump on the bandwagon, but its a bad idea. The hubs you picked are quick release, the disc adapters require bolt-on hubs to add some stability to the adapter. The adapters aren't really meant to work well and aren't a great solution. Cost-wise, you still need new spokes assuming you're keeping the stock rims since that style disc hub will have taller flanges and require shorter spokes and then there's the matter of building the wheels. If you want to stop better as others have mentioned buy v-brakes but buy a set with brake levers included, just get a decent set of tektros which should set you back about 20 for the front and 20 for the back, can still use the stock wheels.
i value all advice etc, but after all its a bicycle that i ride top 25 KM/h, not a motorcycle, perhaps i buy a new front fork that supports the disk brake caliper and for the rear i think frame will handle adapter no problem.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4337 Post(s)
Liked 2,979 Times
Its an MTB fat strong front fork, i think its okay to use caliper.
