Stem: Expansion wedge cracked Cinelli 1R
Old 07-11-21, 11:59 AM
Njord Noatun
New Guy
Njord Noatun's Avatar
Stem: Expansion wedge cracked -- Cinelli 1R
The expander wedge in my Cinelli 1R quill stem has cracked, and I am in the process of sourcing a replacement.
When I put it back together, is there anything I can do to reduce the risk of this happening again (obv, I won't be tightening the bolt like my life depended on it)?
Njord Noatun is offline
Old 07-11-21, 12:11 PM
3alarmer
Friendship is Magic
3alarmer's Avatar
Bikes: old ones
Quoted: 26382 Post(s)
Liked 10,361 Times in 7,196 Posts
...it's a very common issue, and appears to be related to a bad design and execution of it. The little teeth thingies on the side you don't show flatten after you tighten it, and don't grip as well. So when you tighen it more than once or twice, often you need to tighten it more than is healthy for the little wedge thing. Sourcing a replacement is often difficult for this reason as well. If you buy one used, it often comes with the teeth a little bit flattened.
3alarmer is offline
unworthy1
Stop reading my posts!
unworthy1's Avatar
Quoted: 1440 Post(s)
Liked 1,055 Times in 782 Posts
I think it's a design flaw and the cast steel part (as choice of mfg.) only compounds that.
I have a complete 1R stem if you want to buy the big enchilada and cannibalize as you wish, PM me.
It's complete, 90mm and has the "Flying C logo" cap; condition is very good.
I do not choose to part this out per my own "general principals".
A new owner can do as he/she will with it.
As for preventative maintenance I think just grease all moving parts generously and cross your fingers!
unworthy1 is offline
Old 07-11-21, 12:41 PM
repechage
Quoted: 3464 Post(s)
Liked 2,827 Times in 1,995 Posts
Make sure the bar is fresh at the clamp area
that broken part looks pretty gnarly.
I would make sure high compression grease was on that wedge interface.
there were all kinds of arguments way back regarding greasing the bar to the stem surfaces.
today, I might consider friction paste.
way back those who were in the dry assemble camp also had creaking bars.
repechage is offline
Old 07-11-21, 12:57 PM
merziac
merziac's Avatar
Quoted: 4509 Post(s)
Liked 6,374 Times in 3,666 Posts
These are on my radar and I saw a wedge recently for $39 somewhere, maybe efbay.
I think a radiusing of the serrated edges of the ridges could help, may diminish the "bite" though so....
I got a Merckx panto one that the wedge is broken on, bought a whole stem to get a wedge.
merziac is offline
Old 07-11-21, 01:45 PM
Jmpierce
Jmpierce's Avatar
Bikes: 82 Trek 710, 90 Trek 750, 86 Vitus, Nishiki Cervino, 1989 Bianchi CdI, 2 Nashbars, an Italian Steel MTB, Sears Spaceliner, and a 74 Schwinn Speedster. I also manage a fleet of Volcanic Patrol bikes, 83 of them.
Quoted: 109 Post(s)
Liked 234 Times in 120 Posts
I replaced that piece on a stem for one of my bikes. Link to the part.
https://www.ebay.com/itm/Cinelli-13-...item218a9e3142
Jmpierce is offline
Old 07-11-21, 01:53 PM
merziac
merziac's Avatar
That link takes you to a bolt, not the wedge.
I think that's the same seller I saw.
merziac is offline
Old 07-11-21, 02:06 PM
Jmpierce
Jmpierce's Avatar
Quoted: 109 Post(s)
Whoops.
https://www.ebay.com/itm/38419257242...sAAOSwuBhgsZjj
Jmpierce is offline
Likes For Jmpierce:
Old 07-11-21, 03:57 PM
3alarmer
Friendship is Magic
3alarmer's Avatar
Bikes: old ones
https://www.ebay.com/itm/29426930793...oAAOSww6pg6I3z
3alarmer is offline
Old 07-11-21, 04:00 PM
3alarmer
Friendship is Magic
3alarmer's Avatar
Bikes: old ones
https://www.ebay.com/itm/31355902664...gAAMXQnYJQ~Y0i
3alarmer is offline
Old 07-11-21, 04:12 PM
repechage
Pricey little parts they are now.
Old 07-11-21, 05:15 PM
3alarmer
Friendship is Magic
3alarmer's Avatar
Bikes: old ones
...testify. It got me to thinking that maybe, back when they were making them, the wedge was considered a disposable item, and places would stock them new for something a little closer to what it must cost to make them. I'm surprised nobody in eastern Europe has tumbled to this market, and started machining new ones. It wouldn't be that hard to make, if you set up and made a lot of them.
3alarmer is offline
Old 07-12-21, 10:40 AM
unworthy1
unworthy1's Avatar
I immediately thought: "is somebody 3D-printing these"? With the metal-infused stuff that's supposed to be on the market for the really high-end 3D machines, but would not be surprised if that material could be even more crack-prone than the original.
So, any engineers, or better yet metal-fabricators, think these could be CNC-made of billet aluminum to be a better product than the OEM?
What about 3D-printed wax forms and investment-casting: or is that what Cinelli did to make these in the first place?
Would some different (cast-able) alloy hold up better than what Cinelli used?
Old 07-12-21, 08:59 PM
Chombi1
Chombi1's Avatar
Quoted: 1635 Post(s)
Liked 823 Times in 532 Posts
My experience with the R1s had been, you really have to crank down on the clamping bolt to get the clamping wedge tight enough against the bar, to keep the handlebar from spinning in the mounting hole, every time you apply the brakes just moderately....
I'm really not surprised by the damage on that stems wedge.
Chombi1 is offline
Old 07-12-21, 09:50 PM
repechage
Porsche is making 3D printed pistons now for a production model. I think 3D printing could create a part with less stress risers.
now, having written that, who wants to take on the liability?
