Decoding of Eddy Merckx frames
#251
Hello, what could you tell me about this one please? Fork seems older then the rest of the bike to me. E 7401 on the right i think, 4 (size) and i think N or M on the left. Thanks a lot.
#254
So, I have made my custom 87` Merckx "mine". From this (which aint too shabby) :
This si the bike i purchased
To this: (Upgraded wheels and saddle)
This 3TTT stem is so rad. Im in love
Likes For Holm:
#255
Quoted: 379 Post(s)
Liked 536 Times
So here is one I've only seen pix of and appears to be a 52cm tho the 50cm is possible. Chrome dropouts. Kinda not great condition. It has the early SL sticker on the frame and the rounded top fork crown with the Columbus stickers on the fork blades.
Likes For Steel Charlie:
#256
Quoted: 233 Post(s)
Liked 396 Times
Professional late or Pro (SLX or 753)... not enough data
Stickers on the fork were only used on team frames - they may not be original.
A photo of a brake bridge would be helpful
#259
Cranks look pretty close to the BB... spindle might be a bit short or cranks worn/overtightened perhaps? Worth checking.
#260
Quoted: 379 Post(s)
Liked 536 Times
It did prove to be a 50cm but I got it anyway figuring I can clean it up and find someone who will give it a good home. So here's some pix for maybe making a better ID. Drops are short Campys and chromed with the right chainstay chromed. Does have SLX steer tube and still had the cork plug in the bottom of the steerer. The tape tag on the steerer is pretty much obliterated
#261
Quoted: 233 Post(s)
Liked 396 Times
Professional 1985 (Columbus SL) - 95%
There is no difference in SL and SLX fork appearance - to distinguish these frames, you need to see the tube ends visible through BB cover
Likes For CyclesMakaron:
#264
Quoted: 379 Post(s)
Liked 536 Times
and yes the crank axle does seem short and the cranks are not wobbled. Seems a strange BB to pair with a SR crank but I'm sure there must have been some good reason, right?
#265
Hello CyclesMakaron, Can you help me identify this frame? I looked through several catalogues but am having difficulty finding this particular colorway.
the bottom bracket id is as follows:
left side:
A
right side:
Z
9436
The fork is stamped with the letter D, the dropouts are Campagnolo (from what I can tell)
I have attempted to attach images to the post to help you identify the frame but the rules of the forum restrict me from doing so since this is my first post. If you have a recommendation as to how I could share the photos with you that would be great, otherwise I hope this is enough information.
left side:
A
right side:
Z
9436
#268
Quoted: 233 Post(s)
Liked 396 Times
The frame is Corsa Extra from 1986
Modified - top tube slides are a version introduced in 1992
Painted - designs in this style were used between 1993 and 1997
A fork in this style is characteristic of the Corsa
Questions:
Do you see 'riflings' inside the tubes in BB cover?
What is on the fork crown - Eddy and Merckx lettering or EM logo ?
Questions:
#269
Smile a mile bike provide
Just acquired this Eddy Merckx non original paint so no logo's told it blue in colour
Down tube is larger diameter than top and seat tube
Bottom picture is original owner riding it
Trying to work out model i presume the G prefix on right is for 1998
Any help please
Any help please
#274
#275
Quoted: 233 Post(s)
Liked 396 Times
This is my archive of the EMC frames factory markings (collected from every possible source of information - for several years)... As you can see, it is sometimes useful
