New Freehub body - do i need to grease it?
Quoted: 3420 Post(s)
Liked 2,111 Times
Most don't. However if you live in a high salt area (coasts and snowy places) and the bike will see outside use when the salt is about a thin film of something to inhibit corrosion is not wrong.
BTW the usual issue with cogs on splines has to do with the cogs' tabs digging into soft AL freehub bodies. No lube helps that from happening. Andy
AndrewRStewart
AndrewRStewart
Quoted: 1411 Post(s)
Liked 986 Times
I don't but I do grease the lock ring threads, and all other threaded connections. I use Tef-Gel for dissimilar metal connections.
Likes For dsbrantjr:
Friendship is Magic
Bikes: old ones
Quoted: 23308 Post(s)
Liked 6,726 Times
working on my sandal tan
Quoted: 3552 Post(s)
Liked 1,928 Times
MotuekaCascadeChinook
Bikes: '20 Tarmac Disc Comp '78 Raleigh Competition GS
Quoted: 4289 Post(s)
Liked 2,841 Times
If you lube your chain regularly, then lube is probably going to get down there anyway. Then you'll be cleaning it out when it becomes gunk, then everything will be clean, then you'll lube your chain, then there'll be gunk, then you clean off the gunk again, then you'll lube the chain again, then it'll get gunky again and then you'll clean off the gunk and then lube the chain again.......
Get the idea?
Get the idea?
