1971 Raleigh Supercourse--Seatpost Size?
Bikes: Bianchi, Olmo
I have a 1971 Supercourse that I am in the process of upgrading and restoring. I need a seatpost that fits and am coming up empty-handed.
I looked on Sheldon Brown's site but the diameter he lists on his seatpost size chart is not compatable with my Supercourse.
Does anyone here know what size post this frame accepts? I currently have a 25.8 in use (with shim) but would like to get the correct size. Any help is appreciated!
Frame is 531 straight-guage/hi tensile tubing with Nervex lugs.
B.C. to D.C.
Location: between the Popeye's, the liquor store, the funeral home, and the strip club
Bikes: 1992 Miyata Nine 14; 1971 Raleigh Super Course fixie conversion; 2006 Jamis Nova (853 version); 2001 Diamondback Topanga (SS conversion); 1956 Rudge Sports; 1971 Raleigh Competition (processing); 199? Schwinn World Sport (processing)
I converted exactly the same bike (in green) to a fixed gear and replaced the seatpost. I'm pretty sure it's a straight-up, common 1" post. What I did was take it to my favorite LBS (Proteus, if you're still in the DC area), which has a lot of seatposts lying about until I found one that I liked that fit. I did find that the seat collar was a bit wonky, maybe not quite round, maybe bent a bit and the seatposts were hard to get in (and out), so working a bit of mojo to get it in is not out of the question.
College Park bikes was selling a '71 supercourse a while back, they might know the technically correct measurement.
If you're *really* keen on the exact seatpost OD, I can dig up the original and measure it with calipers.
I also noticed that the seat collar is a bit weird. I can't find a seat-binder bolt that fits either, so I've rigged that up with a standard sugino binder-bolt and some washers. Strange design.
Thanks for the info.
B.C. to D.C.
my seat-collar takes the usual raleigh nut and bolt. If you're in DC, I seem to recall seeing one floating around the parts bins at Proteus.
The supercourse used a 26.4. I have a couple in both the original steel and Raleigh branded SR alloy from later years. Let me know if interested. I'll be offline on Friday.
hmm... I have a 1981 Carlton Super Course, that I have all the parts for except the seat post... it looks like a 27.0, but my ruler is a piece of crap and I think I loaned my calipers to a friend... It is also straight gauge, I think, but the then-new 531c tubing.
anybody know?
anybody know?
Quoted: 3803 Post(s)
Liked 6,639 Times
The seat post on my '71 Super Course measures 26mm. I was able to find an alloy LaPrade style to replace the original steel jobber.
The '77 Super Course that I recently sold had a 26.4mm post, so sizes do indeed vary according to build date.
Neal
Neal
Seńor Member
Quoted: 1491 Post(s)
Liked 1,088 Times
Hmmm - '77 and '78 are spec'd at 26.8. I'm pretty sure they had 26.4 up until then.
Liked 6,639 Times
Neal
B.C. to D.C.
can't find the old seatpost--
the new one (sakae) measures 1"1/32 (sorry no metric calipers)
and riding...just riding
My early 70's Japanese Raleigh America Super Course uses 26.4. They come up on eBay from time to time with the straight up one working the best for me with an Ideale seat.
Quoted: 443 Post(s)
Liked 27 Times
My Super Course MK II uses a 26.2 just like Sheldon's chart shows. Why does the MK II have thicker tubes than an ordinary Super Course?
Seńor Member
Liked 1,088 Times
Originally Posted by nlerner
I'm sure you're right, John. The memory is getting faulty with age (and from parenting two small kids!).
Neal
Neal
Quoted: 443 Post(s)
Liked 27 Times
Bikes: 1975 Motobecane Grand Record, 1976 Motobecane Grand Record, 1971 Raleigh Super Course, 1983 Univega Gran Turismo, 1983 Univega Alpina Ultima, 1960s Raphael Geminani, 1994 Trek 820 Bafang ebike
Quoted: 18 Post(s)
Liked 41 Times
Bikes: 1968 Raleigh Super Course, 1972 Raleigh Professional, 1975 Raleigh International, 1978 Raleigh Professional, 1985 Raleigh Prestige, 1972 Schwinn Paramount, 1980 Schwinn Voyageur 11.8, 1960 Carlton Franco Suisse Peugeot PX10, 1972 Motobecane Le Champ
Quoted: 321 Post(s)
Liked 688 Times
26.4 is correct
Quoted: 18 Post(s)
Liked 41 Times
Quoted: 18 Post(s)
Liked 41 Times
Next option, local bike co-op for used 26.0 to see how that works
Liked 6,639 Times
I’ve had SuperCourses that took a 26.2 mm post. I probably reported on that in this thread some 16 years ago.
Quoted: 1105 Post(s)
Liked 1,326 Times
If the slot has parallel sides then likely yes - but to be sure(r) find something you know to be round and a little smaller than the hole; a socket from the toolbox may do.
Put the round thing centred in the hole and look from the top to judge the hole's circularity.
Quoted: 18 Post(s)
Liked 41 Times
Is the hole round?
feros ferio
Quoted: 1390 Post(s)
Liked 1,322 Times
That is what I was going to suggest, since my 1959 Capo has plain gauge 531 and takes a 26.4. Frames with butted 531, like my 1962 Carlton FrancoSuisse, should take 27.2.
