The single best biking tip you ever got?
#101
Happy banana slug
Quoted: 1533 Post(s)
Liked 1,528 Times
In the distant past, when Seth's Bike Hacks (now Berm Peak) YT channel was still new, he began a series of noob mountain bike lessons, and the one that really stuck is, 'Pick your line and ride confidently.' Applicable to our occasionally chunky streets as well.
#104
Not lost wanderer.
Quoted: 885 Post(s)
Liked 990 Times
Wear dark shorts with light and bright shirts. Dark shorts to hide any grease hand prints, bright shirts to be seen.
If something is making a noise it should not be, stop and fix it.
line up the tire label with the valve stem.
Just ride! You do not need fancy stuff.
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
#105
Mainly for commuting: Build a good relationship with riding. The shortest, most convenient, and easiest ride isn't necessarily the most enjoyable.
Likes For ItalDisco:
#106
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
If you have someone telling you that you don't need more bikes, get rid of them (the person). You don't need that king of negativity in your life.
Likes For 2manybikes:
#107
Bikes: 2021 Salsa Warbird, (Specially Love my) 2021 Salsa Cutthroat, 2012 Surly LHT, 2015 Surly Cross-Check, 2008 Giant OCR A1, 2005 Leader 735R, 2005 Gary Fisher Montare, 1991 Nishiki Pueblo,
Quoted: 84 Post(s)
Liked 57 Times
for commuting: Learn the bus routes, and carry bus fare, you might need it some day, better than calling wife or uber or a friend for an emergency ride,
#108
Another taken from motorcycle advice
"Dress for the slide, not just the ride"
Mainly applies to helmets and gloves because I'm not wearing full leathers during physical activity, but I do like the idea of keeping my hands and head intact
#109
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2581 Post(s)
Liked 5,636 Times
Always wear some type of eye protection - against bugs - dirt - and in my wife and my case on our tandem - flying vanilla milkshakes courtesy of a local low life.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
#110
Quoted: 167 Post(s)
Liked 291 Times
I do think riding a featherweight bike will improve performance and demand less work.
That is why I ride a $200 bicycle that is heavy and obsolete. I get a better workout than if I had a fancy easy to ride lightweight bike.
Otherwise, I agree with everything else you said. Equipment can never compensate for lack of skill and ability or practice.
It's a common theme from some that heavy bikes = greater workouts or that it's the rider not the bike etc.
Not entirely true...
Watts are watts. Whether you ride a heavy bike or a light bike, 300w is 300w and the difference will be how fast and enjoyable that 300w will be, not the intensity of the workout - that will remain the same.
Sure, a lighter bike will be 'easier' to climb with. No doubt. For example, Rider A on the light bike may only need 280w vs rider B on the heavy bike using 300w to achieve the same time on the same gradient - assuming all else is equal, such as w/kg etc. Hence why we train with power meters today; we can see our target, we can ensure we maintain the watts required for the workout goals - regardless of bike weight etc. So the heavy bike theory is incorrect, it doesn't make a workout harder if the rider on the lighter bike matches the same physical effort. They will just go faster.
It's the rider...yes, this is mostly true. However, there comes a time when an athlete cannot lose any more weight beneficially and is in peak condition. What then? Well, at that point, it is over to the bike! A bike more suited to a particular course; weight, aero etc will provide gains over another athlete with a bike not as efficient or fast. Therefore, the bike will make a difference in terms of increasing speed.
Marginal gains are important for many athletes where they are needed to remain competitive with others who are also in good shape and have them. It becomes a bit of an arms race at the top; chasing every watt of advantage.
Anyway, to quote Eddy Merckx: "Ride as much or as little, or as long or as short as you feel. But ride".
#111
Quoted: 1397 Post(s)
Liked 1,876 Times
some of the best advice I received
stay hydrated - drink a lot of water
act like you are invisible - be prepared the motorist will not see you or your sight will not register with them (important when passing by / going through an intersection)
only go as fast as you are willing to fall
low gearing is important if your rides will involve a lot of climbing
and most important: enjoy
if your riding is mostly limited to a bunch of frantic riders doing 30 mile rides in 20-25 mph pace lines - everyone gets beat up - you return to your car and then head home to lick your wounds and feel like ***** - you might be missing out on the best parts of biking
Likes For Ronwalker:
#113
Quoted: 896 Post(s)
Liked 2,063 Times
Overheard tip while eavesdropping PBP grizzled veterans in Paris: if you want to finish fast, be brutally selfish. Make temporary alliances on the road, and abandon them if they slow you down. Make another alliance up the road. Never ever wait for anyone at a control. The same holds true if you're on the slow end of things barely making time cutoffs.
Only if you're in the middle and don't care about finish time can you afford anything else - and even that can get you in trouble.
#114
Palmer
Quoted: 1666 Post(s)
Liked 1,818 Times
"Steer into the lean." This would have been in the early summer of 1962, as the training wheels came off.
#115
Grupetto Bob
Liked 5,636 Times
Don’t eat or slurp anything sticky while riding unless you have water nearby to wash your digits (unless you are skilled and don’t make a mess).
#116
Grupetto Bob
Liked 5,636 Times
Never pass a bakery or coffee shop without sampling the baked goods. Ride to eat.
Likes For rsbob:
#117
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
The heavy bike leads to greater workout fallacy stems from the mistaken analogy to weightlifting. Unless you're riding uphill all day, such a small proportion of our effort is actually overcoming the inertia of the bicycle's weight that marginal differences in bike weight make virtually no noticeable difference in the effort we're putting out. And we also likely adapt the gearing to the weight of the vehicle to further ameliorate any resistance from weight--people on heavier bikes are just going to ride in a lower gear than the riders on lighter bikes, all other things being equal. Weightlifting doesn't involve aerodynamics or gearing, all that can be varied is the amount of weight and number of repetitions.
Just to be clear, I'm completely agreeing with you, just extending the logic.
Likes For livedarklions:
#118
If your cycling includes some cold weather rides, keep a list of what you are comfortable wearing at 5 to10° intervals. Amend as you see fit when additional clothing options present themselves. The list will take the emotion out of choosing your cycling wardrobe. What I and many people have obviously discovered is the tendency to overdress at the start of a ride, only to stop a few miles in and shed some clothing. Before starting a ride, I get the temp reading and forecast, adjust for wind when applicable, check my list and dress accordingly.
#119
Quoted: 2482 Post(s)
Liked 2,952 Times
Read this on Bikeforums over 10 years ago, and it's great advice:
When you see that a squrrel in or near the road sees you coming, ride straight toward the squirrel. Moving in a straight line toward them is what they expect predators to do, and they'll run away from you. But steer away from them, and their response will be unpredictable, often dangerously so.
#120
Quoted: 18411 Post(s)
Liked 15,531 Times
Don’t drink vodka you found in a dumpster.
Likes For indyfabz:
#121
climber has-been
Quoted: 3427 Post(s)
Liked 3,563 Times
#122
Tragically Ignorant
Liked 9,098 Times
Related--I've found that making a very loud "gobble, gobble" type noise will turn back a wild turkey, otherwise they seem to just obstinately stay directly in your path.
I have a lot more close calls with chipmunks than I do squirrels. I think they're wired to avoid being swept up by raptor birds, so it's impossible to know how they're actually perceiving us.
#123
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 414 Post(s)
Liked 912 Times
A pound off the wheels is worth ten off the frame.
#124
climber has-been
Liked 3,563 Times
Likes For terrymorse:
