A novel approach to superior stability?
Do you think there is a benefit to having one wheel a little closer to the one side of the frame and the other one a little closer to the other? I seem to think this could increase the bike's stability. What do you think?
Mike J
Bikes: 1975 Peugeot PX-50L, 1971 Peugeot PX-10, 1974 Peugeot PX-8
Quoted: 392 Post(s)
Liked 6 Times
I think you'll be riding sideways. I think for better stability you should try training wheels. I think bike wheels are gyroscopes and therefore inherently stable. I think some folks think too much. I think I'll sign off now.
Blamester
How would it make it more stable?
The spinning wheels keep the bike upright.
Let a bike roll down a hill and it keeps going with no rider.
Your idea makes it awkward to turn and less stable.
There are setups like you describe but they use two sets of wheel like a car or some with three like a trike.
None work as a bike.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
It would become a two-track vehicle with the wheels staggered to be in the two tracks. Most folks would call that bike bent.
Quoted: 2026 Post(s)
Liked 1,096 Times
What is your mechanism for thinking mis-alignment will somehow make the bike more stable? BTW, bikes don't rely on "gyroscopic stability" to remain upright and the spinning wheels aren't the reason they do.
With a mighty wind
Quoted: 1087 Post(s)
Liked 862 Times
Someone once told me something that I assumed was bs. He said that perfectly aligned rotational systems are more prone to wobble than less than perfect.
His theory was that the precision item doesn't sluff off outside variation and this can build into a harmonic instability and there is a wobble.
An imperfect system is less efficient but dampens the harmonic instability and doesn't allow it to build.
Like is said, I didn't believe it. However, the most stable road bike I've ever owned is a handmade steel thing, not something off a mold or with a CAD mock-up. The least stable was a mass produced Litespeed Vortex that was utterly perfect, except it sucked.
I've seen the opposite too. Tri-spokes in a cross wind are unstable. Less than round wheels above 50 are terrifying too.
I don't espouse any theory here. I wonder if this idea is where the OP got his.
BTW, it would mean right turns require a different force than left. Not a fast design.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
The physics of it wouldn't make it wouldn't be any stable and the asymmetry would make it harder to ride - braking would pull to one side, etc.
That's a good Ted Talk. The extreme of the two wheels offset is that the bike stands on its own. The theory is that a small precision offset would increase stability without being noticeably clumsy.
Liked 2,446 Times
Should be easy enough to do. Redish your front wheel to one side and redish your rear wheel to the other. There's your offset. Tweak your brakes to suit, try it out and get back to us.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Even if we're talking about a small precision offset of just 3 mm per wheel?
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Mechanic/Tourist
I think you are on to something here, but to make it even better just a 2nd wheel in back! It would not only be more stable, but each wheel and tire on such a "tri-bike would have to carry less weight, so they would be less stressed. More stable, fewer flats, longer lasting wheels - what's not to like? Of course for the ultimate in stability 4 wheels would be even better.
Liked 2,446 Times
And maybe a motor...
stability
Trail measurement is a number .. distance between steering axis line
and plumb line down from the hub..
more trail is harder to turn off it's line.. stabile
Peter Fonda's motorcycle in 'Easy Rider' had a lot of it,
my small wheel folding bike , considerably less...
Liked 2,011 Times
Engineer , British bike Designer Mike Burrows, in his book on bike design,
described a long wheelbase recumbent he made with 2 parallel wheel tracks ..
Quoted: 18373 Post(s)
Liked 4,508 Times
I don't see it standing on its own. There are still only 2 ground contact points.
https://www.youtube.com/watch?v=NtIImATBchY
I have always felt that a little flex in a system can be of benefit, so walking along even a small log with a little flex may be easier than walking on a curb or railroad track with no flex.
So, one may be able to compensate for the moving board... Although, perhaps my 50 year old body is too old for it???
However, so much of those scooter things appear to be silly toys, why not just walk, jog, or ride one's bike?
Insane Bicycle Mechanic
Quoted: 805 Post(s)
Liked 704 Times
Bill Patterson's students were required to design and build bicycle-type vehicles for his class. Some were distinctly odd looking, but those that used his formulae were rideable.
The BikeE tandem was designed using his principles:
Jeff Wills
Jeff Wills
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
OK, then here's the course materials for a college-level class on two-wheel vehicle design and stability: https://web.calpoly.edu/~wpatters/lords.html
Stayer bikes, Motor-paced racing, are very stable, at speed,
long trail because the axle plumb line is far behind the steering axis..
