A tick turns to tickety tickety tock
Old 07-08-19, 12:27 PM
scarleton
Bikes: Lynsky R240 w/ Ultegra Di2
Quoted: 20 Post(s)
I am trying to hunt down this tick sound my bike is making and after my latest changes, things have changed, maybe it will give folks some insight as to the root of the problem.
I have a Titanium frame that has internal Di2 wiring.
It started off sounding like a tick/ping sound as I pedaled with moderate to heavy power ALL THE TIME. A light metal against metal type of sound, quiet enough that I could block it out, but when I could not block it out, it drove me up a wall!
No change happened when I replaced the cleats on my shoes, which needed to happen nor when I tried flats.
Then I took the crank and BB off, cleaned them and reassembled them. Took it for a quick ride (where there are not hills) and it sounded good.
Someone suggested I check the chainring bolts, I tightened them (by hand, don't have a torque wrench), and when for a 1 1/2 hour ride with hills. What I noticed was that on the flats it was nice a quiet, even when putting down a little power, I don't think I ever tried getting out of the saddle and sprinting, but under heavy load it was quiet.
Then when I went up a hill, even with the same moderate power (around FTP) the bike makes a tickety tick tick type of sound. Before the sound was about once every one to one and a half revolutions. Now it is multiple ticks per revolution of the pedal.
I have another bike with the EXACT same crank and type of BB, I could swap those out. But I am wondering if anyone has any thoughts on what is going on with the bike.
scarleton is offline
Old 07-08-19, 01:30 PM
Steelman54
Bikes: Allegro Model 77, Gitane Team Pro SLX, Waterford R2200
Quoted: 68 Post(s)
Liked 57 Times in 38 Posts
I've been chasing a clicking sound also, sure its not the wheels/spokes?
Steelman54 is offline
Old 07-08-19, 01:31 PM
scarleton
Quoted: 20 Post(s)
That was a passing thought I had, I should change wheels and see what happens.
Old 07-09-19, 05:52 AM
dsaul
Quoted: 714 Post(s)
Liked 800 Times in 475 Posts
Does it happen when standing or just sitting? If it only happens when sitting, it could be the seat post or saddle rails.
dsaul is offline
Old 07-09-19, 06:53 AM
cny-bikeman
Mechanic/Tourist
Bikes: 2008 Novara Randonee - love it. Previous bikes:Motobecane Mirage, 1972 Moto Grand Jubilee (my fave), Jackson Rake 16, 1983 C'dale ST500.
Quoted: 486 Post(s)
Liked 11 Times in 11 Posts
You did not mention the pedals. If you have not done so, remove them, clean the surfaces where pedals meet the crank faces, grease threads and reinstall. Chainwheel bolt can also cause clicking - even when tightened - from grit, so you could resort to removing and cleaning them as well. I'm going to assume you properly torqued the cranks and BB upon reinstall.
cny-bikeman is offline
Old 07-09-19, 07:17 AM
jadocs
jadocs's Avatar
Quoted: 942 Post(s)
Liked 527 Times in 349 Posts
Yeah but what the OP is describing is more of a metallic ping if I understand correctly.
jadocs is offline
Old 07-09-19, 07:43 AM
scarleton
Quoted: 20 Post(s)
Thank you so much for your reply. I guess I wasn't really clear when I made reference to "flats" that was my poor attempt to make reference to another set of pedals designed for regular shoes. I have NOT used a torque wrench to tighten everything down, guess I should invest in one Any recommendations on the best place to get one that won't break the bank?
Also, how do you recommend cleaning things like the Chainwheel bolts? What cleaner should I use?
Old 07-09-19, 07:45 AM
scarleton
Quoted: 20 Post(s)
Thank you for your reply. You ask a very good question, I don't stand much so I am not 100% sure. When I go for a ride this evening I will look into that, I will also do some sprinting on flat roads (both seated and standing) to see how bad it is then, too.
Old 07-11-19, 09:31 PM
jfan
Quoted: 22 Post(s)
Liked 8 Times in 4 Posts
I had a ticking sound I couldn't track down, and I couldn't replicate it on the stand. It only happened with weight on the bike. It turned out to be the seatpost. The LBS mechanic put some goop (I can't remember what it was called) on the post and reinstalled it and the noise was gone.
jfan is offline
jskash
Bicycle Mechanics
6
07-10-18 05:09 AM
Cyclist0108
Bicycle Mechanics
6
05-26-18 06:40 PM
silent_chief
Bicycle Mechanics
5
06-22-17 10:41 AM
bleui
Bicycle Mechanics
5
06-02-16 08:13 AM
scarleton
Bicycle Mechanics
8
05-26-16 04:37 PM
