Best Clamping Location on Repair Stand
Quoted: 4221 Post(s)
Liked 2,942 Times
But would this damage a carbon fiber seat tube? That would be worse than damaging a seat post. And even if not, what is the advantage over using an alloy seat post? Either way one would have to remove the actual seat post. Or is a non-round seat post the only reason to use this?
Quoted: 645 Post(s)
Liked 797 Times
The bike is a 20 year old Litespeed , titanium tubes and a Thomson seat post that I'm guessing will withstand a tight grip - I'm using a Park gripper mounted to a post in the garage , see link below.
PRS-4W-2 Deluxe Wall Mount Repair Stand | Park Tool
senior member
Thanks Litespud , I have the Tuscany , originally with Chorus 10 - changed to mostly Ultegra about 3 years ago but kept the Campy parts for now - am curious , what type of repair stand do you have ?
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
I have no idea why anyone would want to clamp a frame tube when the seat post is such a good place.
Likes For cxwrench:
Recreational Road Cyclist
Quoted: 255 Post(s)
Liked 252 Times
Verclampt
The steel bikes of long ago were safe to clamp on all of the main tubes. Quick destruction for many current light bikes. Many of the new seatposts have the same issue. What many mechanics do is have a second seatpost with a strong tube and simple swap seatposts for the stand.
I dislike clamping to the seat post because it places the bike lower on the stand and I have to get low to work on the drive train.
Quoted: 255 Post(s)
Liked 252 Times
I have no idea why anyone wouldn't want to say brifter on such a nice Spring day! Brifter, brifter, brifter. 🎶 The hills are alive, with the sound of brifffff-terrrrrr...🎶
Quoted: 3487 Post(s)
Liked 2,905 Times
Likes For smd4:
Bikes: lots
Liked 2,932 Times
Clamping the seat tube places the bike higher on the stand, which I prefer, and I don't have to remove my under-seat bag, which I also prefer.
Quoted: 255 Post(s)
Liked 252 Times
Don't know why you'd think so. It's an old word, now. I don't know who coined the word originally, but I picked it up from Sheldon Brown's website. I guess that it originated when integrated brake/shifter levers first appeared to differentiate from separate brake levers and shifters. It made sense at the time. Today, a majority of road riders use integrated shift/brake levers, so we maybe don't need the word. But I don't understand what is stupid about it.
The person on BF who brings up brifters in his every post is you. How ironic that a guy who uses stupid in his signature has an opinion on maturity. Really.
Clark W. Griswold
Quoted: 4330 Post(s)
Liked 3,954 Times
Always use the seatpost which is designed to be clamped, please do not damage your bikes with bad advice. Do not think "oh I will just do this one thing and be really careful" because you easily damage something and not notice. Certainly yes some older bikes and heavier duty bikes might have more robust tubes but they still were not designed to be clamped. Seatposts are actually designed to be clamped it is how the stay in your frame is through clamping.
In terms of bags getting in the way, remove those bags, Topeak makes the Fixer which just clamps on to your saddle rails and allows you to slide your seatbag on and off very quickly and keep it quite secure. Otherwise generally they are simply hook and loop fasteners and don't require a ton of work to remove. One should not intentionally damage a bike simply because removing something minor was just too hard or we are just too lazy (really the case). Many good rear lights these days are silicone or rubber fasteners and you still will see some one attached with a screw and plastic clamp but those can be move out of the way pretty easily with a turn of the screw or you can change the height of your seat post briefly to work on your bike great thing about that is you can find out if you have done your job of greasing it properly so it doesn't seize and might just be a good opportunity to clean it out and re-grease. you can also use a marker or a blade and just mark where your post was or measure with a tape measure and write it down in case you need it.
Likes For veganbikes:
Liked 2,905 Times
senior member
ignominious poltroon
Quoted: 2221 Post(s)
Liked 3,407 Times
I sometimes loosely clamp the top tube wrapped in a towel, loose enough so I can slide the bike back and forth, and it is held in place by balance. The clamp is only tight enough to catch it if it slips.
Likes For Polaris OBark:
Liked 2,905 Times
I have two other issues that now go to the top of the list : (1) for mounting on either the seat tube or post , who has a clever way - other than brute strength - to single handedly lift the bike , place it in the jaws , & then tighten the clamp and (2) what is a good material to lay in the jaws to reduce twist ?
Luckily most of us have pretty light bikes, so I don't have to tap into any brute strength--which I'm sorry to say I'm sorely lacking anyway. My stand also has a cam lock for the jaws (like most shops have) so I don't have to spend a lot of time twisting a clamp down.
Quoted: 645 Post(s)
Liked 797 Times
Mother Nature's Son
Quoted: 852 Post(s)
Liked 1,433 Times
The way that works best for you, whatever work you are doing, is what is best. When I am going to do more than basic maintenance, I use a fork mount stand, Feedback Sports model. The bb sits on the stand arm. If I am doing something that requires a bit of force, I use a strap near the bb to keep back end in place. It is adjustable for the size of the bike, can be moved up and down, and also spins. The stand is very stable and efficient, folds up and is pretty easy to store or move. A bit pricey, but it should last a lifetime.
Clark W. Griswold
Liked 3,954 Times
I personally respect the input from someone who also owns and works on a Ti bike and is comfortable clamping to the seat tube but I also feel the post is a safe bet - but I have two other issues that now go to the top of the list : (1) for mounting on either the seat tube or post , who has a clever way - other than brute strength - to single handedly lift the bike , place it in the jaws , & then tighten the clamp and (2) what is a good material to lay in the jaws to reduce twist ?
I guess it depends on the stand, my Park stand with the micro adjust clamp is pretty easy to close and if need be I can get it enough to not drop out and just tighten once it is more held in place.I do lift and then tighten but potentially if you have a stand with height adjustability you could lower it put the bike in the stand and then use a little bit of strength to raise it up but I find that rather difficult. If you have a really heavy bike it will be tougher but one could probably figure out solutions to getting it up or look at the new hydraulic lift stand from Topeak.
In terms of your jaws I would just use the material there assuming you have a quality stand. I wouldn't put anything in my park tool jaws unless something was super messy. The rubber should be sufficient and if it is worn out and damaged I would replace it. If the bike is properly tightened in the stand it shouldn't twist too much and a little motion is fine as long as it is not free spinning which would be hard to do. Basically a little twist isn't so bad and has never affected my wrenching.
Old fart
Quoted: 3582 Post(s)
Liked 3,394 Times
Fresh paint (i.e. less than several MONTHS old) is easily damaged by clamps, even with padding. I've seen many a frame with cloth texture pressed into the paint from clamping on a rag wrapped around the tube. And decals are easily destroyed by clamps.
Always clamp on a seat post to avoid these issues. If for some reason the clamp won't fit on the exposed post (non-round "aero" style, bolted on accessories, etc.), get a cheap steel post of the proper diameter and insert that for the clamp to grip when you work on the bike. If you work on lots of bikes with different diameter posts, get one of the internal clamps mentioned above.
Likes For JohnDThompson:
Quoted: 308 Post(s)
Liked 706 Times
https://www.topeak.com/global/en/pro...PSTAND-eUP-PRO
senior member
Not necessarily practical cost-wise, but there are stands with hydraulic lift assist for e bikes and cargo bikes and such.
senior member
Would not clamp the seat tube. Seat post always on all of my ti bikes and steel bikes and aluminum bikes and if I ever owned a crabon bike same thing.
Likes For blinky:
Liked 2,905 Times
Clark W. Griswold
Liked 3,954 Times
Please don't clamp parts of the bike that are not designed to be clamped. The seatpost is designed to be clamped and is always clamped in the frame (aside from some vintage quill posts which are few and far between) If you really have something you cannot clamp get a cheap seatpost or use one of the internal seatpost clamps as needed or use a euro style stand that doesn't clamp and cradles the BB and then attaches via your QR or Axle. Yes there are frames that are sturdy enough to be clamped on the seat tube without damage but why risk it at least in normal circumstances for normal repairs obviously removing seized seat posts and things like that but no need to damage paint and decals when you don't need to.
Quoted: 1109 Post(s)
Liked 1,200 Times
Likes For Camilo:
Quoted: 255 Post(s)
Liked 252 Times
Off topic
Sincere question: what is the commonly used word that indicates integrated brakes and shifters? The word that makes brifters unnecessary and stupid and silly?
